Old 11-08-2017, 08:31 PM   #26
quillc
yv1a.com
quillc's Avatar
Depending upon your budget, sky is the limit.
However for a more realistic approach....
I currently run an 83 242 as my DD. 83 is the factory high compression 10.3(ish):1 motor than can actually use some camshaft.
I shaved a little bit when I replaced the HG a while back, so I'm a shade higher than that I suspect. I cleaned up the ports (carefully) with a carbide bit, mostly taking a tiny bit off the short turn. Lapped in the valves and installed new springs. New Elring HG with head studs (because I dislike TTY bolts).
Volvo H cam (largest factory cam). No hushers, just shimmed as tight as possible.
Stahl header, 2 1/2" exhaust with a Flowmax muffler.
Bosch bluetop 24# injectors (stock orange/yellow tops are 19#). Injectors are from a Ford 460.
M46. 3.31 rear axle (stock). Stock flat flywheel clutch.
Based upon my 84 242 TI car, I would estimate in the range of 130hp with this combination. Idle is lumpy for a 4 cylinder car. Many people ask me if I have a V8 in the car. At WOT above 3000 RPM, this combination gives a 11.5:1 AFR. The combination is fun to drive as it is. If anything I'd go to a 3.73 or 3.91 rear gear with a TruTrac to give it just a little more get up and go.
I'd agree on the manual conversion. The autotragic trans sucks a lot of HP to pump all that fluid that you just don't have to give.
The comment about the rev limiter is spot on with LH2. It fuel cuts at 5500 RPM. If you want to rev higher than that, you have to go to LH2.2 and pay someone to edit the bin on a removable chip 541 computer.
That or aftermarket EMS.
Not sure about the focus on revs. Any reason for wanting to rev it to the moon?
Chris
www.yv1a.com
Old 11-08-2017, 09:28 PM   #27
culberro
culberro's Avatar
Because 8k and a glass-pack doesn't sound like a tractor.
Old 11-08-2017, 11:17 PM   #28
John V, outside agitator
Banned
This would probably be the best head for a NA B23. 8000 rpms, 231 hp (69 hp more than B230FT). Who says NA can't make power?
By 1992-93 season the typical good 240 with 2300 engine was making between 230 to 235 hp..8 valves, 7100 rpm..
That is 25 years ago...
And the were NOT on 45s...that limits the fun to around 210 max
48 DCOEs or Del-snort-os
Old 11-08-2017, 11:40 PM   #29
dirtbag240
Mmm but how many torques?
dirtbag240 is offline   Reply With Quote
Old 11-09-2017, 08:20 AM   #30
tryingbe
Boosting along.
tryingbe's Avatar
He gave you the HP and RPM figure, do the math.
HP = Torque x RPM ÷ 5252
85 GLH 367whp
00 Insight mpg > yours.
Old 11-09-2017, 10:08 AM   #31
12david34
This all sounds like a beautiful song to my ears, but can a stock b23 shortblock withstand 7100rpm? Or it will fall apart after few hi rpm runs?
K-Jet über alles.
12david34 is offline   Reply With Quote
Old 11-09-2017, 01:59 PM   #32
Tuff240
240 Ninja
Tuff240's Avatar
Stock original motor you will probably spin a rod bearing eventually.
-Patrick
Old 11-09-2017, 02:29 PM   #33
culberro
culberro's Avatar
The b230 with "big" rods spun to 8k on a regular basis and lived most of the time over 5k.
Probably 1000-1500 rally stage miles like that.
After 3 years of rally abuse, that 180k mile motor is now going into another rally car.
Old 11-09-2017, 05:19 PM   #34
12david34
so, one can assume its safer stay around 6000-6200rpm with stock internals..
Old 11-09-2017, 06:14 PM   #35
Tuff240
240 Ninja
Tuff240's Avatar
You can bounce one of the limiter at 6200 for 500k miles. You start pushing things past 7k rpm you should have everything balanced, blue printed and in tip top shape if you expect it to last for a long time. Stronger H-beams are pretty cheap and pistons aren't too bad if you want some extra insurance/less rotating mass.
Old 11-09-2017, 06:58 PM   #36
classicswede
Volvo upgrades
They take high RPM use fairly well. The rods are strong but heavy as are the pistons. On a budget just getting the engine balanced and make sure bearing fits are spot on etc. Valve springs will need to be strong enough for the higher RPM's. Many B23's have been subjected to high RPM use and they normally survive very well. On a higher buget longer H beam rods and shorter pistions would be a good bet. For a B230 I would strongly suggest H beam rods
Old 11-10-2017, 08:40 AM   #37
12david34
no matter how much i would like to rev it past 6000rpm..i cant, or at least i see no point as my engine gets out of puff around 5500rpm.. probably because of the D cam.
Old 11-10-2017, 03:01 PM   #38
culberro
culberro's Avatar
I found that even a k-cam will still make power up to 7k if it's retarded a few degrees.
Old 11-10-2017, 06:25 PM   #39
12david34
that makes sense.. i do have a adj cam gear, but im lazy to install it now, with the d cam.. maybe one day with some more serious camshaft..
Old 11-11-2017, 10:51 AM   #40
Mogly
280WHP Regina
Mogly's Avatar
Cheap lazy people would say that.
403whp, profile picture
Ford Colonge V6 in the works.
Mogly is offline   Reply With Quote
Old 04-30-2018, 07:52 PM   #41
Yaboy_chun
Kjet revs to over 7000, 45's will have no trouble at higher RPMs. Dont forget suitable valve springs with the cam. Its a B23 so reving is no issue
Can I swap the lh system for k-jet?
Yaboy_chun is offline   Reply With Quote
Old 04-30-2018, 07:59 PM   #42
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
No. I mean you could. But you shouldn’t.
Hello My Glorious!
Old 04-30-2018, 08:03 PM   #43
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Do it. Spend a lot of money and Intentionally make your life harder for no reason.
Old 04-30-2018, 09:31 PM   #44
Fred Gwynne
Fred Gwynne's Avatar
Been there
Doing that.
Fred Gwynne is offline   Reply With Quote
Old 05-02-2018, 10:36 AM   #45
tryingbe
Boosting along.
tryingbe's Avatar
Electronic fuel injection offers infinite tuning possibilities. Keep the LH.
Old 05-03-2018, 01:11 AM   #46
Tentshedtrev
Tentshedtrev's Avatar
ITBs, portwork, header, cam, bigger valves, lighter rotating assembly, engine management to actually take advantage of it all....
There's a reason everybody tells you to turbo it, you can slap it together crude caveman style and still have some great results.
Or spend a bunch of money and end up putting it in the sandtrap on a sharp learning curve...not trying to dissuade you, just giving you the highest chance for success.
Life is too short to stay redblock..
1990 740 SE, Eaton m90 + Holset he351, twincharged b230F drift car
1983 242 turbo t5 whiteblock swap (in progress) (He351, MS3x, WC T5)
1983 244 (on blocks, currently parts storage)
1990 245 Mitsubishi 4D56 turbo diesel km132 transmission, water/meth
1983 245 m46 b230f Stahl header Toyota 4age ITBs MS2extra
Tentshedtrev is offline   Reply With Quote
Old 05-09-2018, 02:40 PM   #47
freevolvos
freevolvos's Avatar
troll
