Old 11-13-2017, 10:38 AM   #1
Dadssleeper
Dadssleeper's Avatar
Default California clutch questions. Clutchnet
Ok its upgrade time I have found the slipping point of my stock clutch. I have an m47 speed and not hard on the clutch or shifting, but will use the power of the car. The other day I went to pass someone on the highway and notice a little slipping when I put the pedal down while in 4th. To ease my mind I tried a pull in 5th and floored to see if I was correct on what I felt and yep its the clutch. As soon as the turbo spools up the rpms shot up and it felt as if the car was not pulling at all. Needless to say a few more hits and its way worse, but confirmed it is the clutch.
I pulled it apart and its just glazed nothing else wrong with it so I knew right away I have to much HP for a stock clutch to hold so I need a new one.
Through much research and reading trying to find a clutch that will be comfortable still for daily driving but able to hold a few more poneys then what I am currently putting out now I looked into the clutchnet (yellow) stage 2 pressure plate and clutch package. Their web site shows a kit option or just a pressure plate option. SO the weird thing is the specs they give. and here comes the 1st question.
On the pressure plate alone it the site says it will hold 347 ft lbs. of torque
https://californiaclutch.com/product...ch-kit-package
On the complete kit the site says it will only holds 291 ft. lbs. torque
So I figured it must be a misprint why would their kit hold less power then just the pressure plate alone? I tried a different stage and got the same results with different numbers of coarse.
So now that brings me to the assumption that maybe these pressure plates can hold more power if you have a different disk, but I am just guessing. My plan was just to get a slightly stronger clutch then what I need and be done with it but now these numbers are bothering me. Not only that but I don't even know how the yellow will feel over the red or green and now would prefer to get some input from anyone that has used their clutches.
To keep it simple I want the lightest feeling clutch available that will handle 275-300 hp. Thats a little more hps then I plan on running and feel I will be fine with it.
I was just getting ready to buy the Yellow kit but just wanted to see if anyone has used it and what they think, or recommend something different altogether.
I plan on pulling a small trailer on occasion too it maybe 1500-1800 lbs. at MAX and we have some hills to climb to get there.
Old 11-13-2017, 11:10 AM   #2
white855T
https://yoshifab.com/store/volvo-red...-2-clutch.html
This setup is good for a lightly modified car.
Buyer/Seller Feedback
Old 11-13-2017, 11:14 AM   #3
dbarton
Bored Member
dbarton's Avatar
I'll offer some from my experience with ClutchNet, but keep in mind this was back in 2004, so things may have changed.
I bought their Stage 2, 8.5 inch clutch using their recommendations back then for my turbo stroker motor that ended up putting out over 300 lbs torque and it slipped like it was greased. The disc was one that had organic on one side and a ceramic on the other IIRC. After I brought it back to them they admitted the PP simply had a stock Sachs spring that they had heat-treated to make it stiffer and it pretty much didn't work. I asked for information on clamping force and they said they were not able to test that.
That's when they offered to create a PP using TWO Sachs springs stacked (pic shown below). This created a very stiff clutch that held very well. Later Yoshifab had some clamping force tests done and what I remember is that the stock Sachs 8.5 measured 1500 lbs and then testing mine showed 3000 lbs.
I later switched to a simple all organic disc and that worked very well.
You mentioned comfort. A dual spring PP like that will be much harder on your left leg. So keep that in mind. Also it's HARD on clutch cables.
If ClutchNet is doing something differently now, then I don't know much about it.
You might also look at Yoshifab's options:
https://yoshifab.com/store/drivetrain/clutch/volvo.html
Old 11-13-2017, 11:44 AM   #4
esmth
dirty swede
esmth's Avatar
One of my friends got screwed over by clutchnet, never shipped the order and took them a couple months to refund $500. This was before they changed their name/website to california clutch (i assume due to the bad publicity) so I don't know if they're under new management or what but i'd be cautious
https://www.bbb.org/losangelessilico...and-complaints
esmth is online now   Reply With Quote
Old 11-13-2017, 11:46 AM   #5
Dadssleeper
Hmmmm well thats 2 for Yosi fab but its 100.00 more and says it holds less power then the clutchnet ...see why I have this confusion trying to find the best bang for the buck as well but willing to bite the bullet for the best option if needed. Honest people reviews have always been better then company claims.
Anyway I did notice that the clutchnet I am looking at looks a lot different then the one you showed me.
So maybe they did change things.
Old 11-13-2017, 11:55 AM   #6
Dadssleeper
BTW I am not a gambler so it looks like this clutchnet/California clutch thing maybe out if no one has anything good to say. I still have to save up a few bucks to get a clutch so have a little time before I decide glad I polled you guys before just researching and comparing specs.
Old 11-13-2017, 12:58 PM   #7
culberro
culberro's Avatar
What clutch and FW are you currently running (flat fw or dog-dished)? That's going to have a pretty big impact on clutch selection.
Old 11-13-2017, 12:59 PM   #8
Happy Mew Year!!!
Southbend clutch has always been good to me.
Old 11-13-2017, 03:37 PM   #9
gsellstr
gsellstr's Avatar
Same here. Awesome service and product so far. Clutchnet never even responded to my VM or emails, so I never went thru them, Spec was the same way. SB was on it, price was good ($390 for an organic/kevlar 8.5", beefed up plate, spec'd for 275ft.lbs, plus pilot, t/o, and alignment tool for a T5 swap, and shipping). Had it within 2 weeks of giving them a credit card, most of that was ground shipping.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 12-19-2017, 04:53 PM   #10
Dadssleeper
Update: I went with the Yoshifab. Yoshifab clutches are made by clutch masters. Had I of known that I would have had no questions about it, I been using clutch masters back when I was into V8's. BTW the one they are selling though their site is the fX250.
I also inquired about the larkspeed or aka drivetorque clutches but once I found out that Yosi offers clutch masters my mind was set. I thought that white style pressure plate looked familiar
http://www.clutchmasters.com/fx250-1/
Old 12-19-2017, 09:56 PM   #11
soclosenotnear
Fwiw, my 940 has a spec "stage 2" clutch and m47. My car doesn't make that much power, but has a 16t, and it hasn't ever slipped in any gear. Also very comfortable.
Old 12-19-2017, 11:16 PM   #12
Cwazywazy
Cwazywazy's Avatar
My car started slipping in 4th so I just slapped in a California Clutch smooth lock pro disk, same Sachs pressure plate. I believe the most I put through it was 16psi, which cracked my ringlands. Clutch is still fine.
YMMV.
I don't know what I have
Old 12-20-2017, 11:58 AM   #13
LeedomtoFreedom
LeedomtoFreedom's Avatar
Just to throw in my $.02. I'm currently dealing with californiaclutch because I've recently done the same thing, but while swapping to a T5 tranny. I bought a red pp with an organic disc, 215mm. I gave him very high hp figures because I wanted this to hold. After installing it, and giving it time to break in, it slips very easily with my leaking 15g. He is in the process of making me a new setup using a ceramic disc. Given this scenario might not be the case for everyone, it's possible that it could be occurring due to other variables than his work.
Old 03-10-2018, 09:16 AM   #14
Dadssleeper
Default 750 Miles on it and 250 more to go
Making sure I break this 500.00 clutch in right. They say drive 500 city miles on it though many heating and cooling periods and that I am am doing. I reset my trip odo. when I put the clutch in and I am now at 750 miles so another 250 more and I will get on it to see how it feels.
Will keep you updated.
https://www.facebook.com/nancy.l.ars...9177179099330/
Teaser video , still driving like a grandpa
Old 03-10-2018, 09:21 AM   #15
Dadssleeper
YMMV.
I was only pumping 12 PSI when my stock clutch started slipping in 3rd 4th 5th , only mods at that time were exhaust and intake and a boost vavle to get to 12 psi.
Old 03-10-2018, 07:58 PM   #16
LeedomtoFreedom
I just finished installing the saab 9000 disc with a dual surface, couldn't be happier with the results so far.
Keep us updated on how the clutch goes, many of us have used clutchnet with bad experiences, so all of the accounts help us determine whether to use them or not.
Old 05-07-2018, 07:41 AM   #17
Dadssleeper
ok so now I have had some break in time and have got on it a few times. Yoshifab/clutchmasters clutch holds fine. Feels great , no shimmy, sounds or anything odd and the pedal feels great.
Old 05-07-2018, 02:05 PM   #18
LeedomtoFreedom
What turbo are you running ?
It's good that we get recent reviews on these clutch companies, mainly clutchnet, because as you've heard, some places aren't what they used to be.
I believe clutchmasters/southbend clutch have held their reputation throughout the years.
Otherwise glad that everything worked out.
Old 05-07-2018, 03:11 PM   #19
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
For the record, my car runs a disc from California clutch, called the dude, told him what I was doing, asked for something with some grip, and a few days later I had what I needed.
Setup is Flat flywheel drilled for LH24, Saab PP (shimmed a couple mm), 8" clutch disk with T5 input (I vaguely recall this being for a SVO thunderbird?).
1980 242 Turbo
2004 V70R
Uncleknucklez is online now   Reply With Quote
Old 05-07-2018, 03:22 PM   #20
oldschoolvolvo
oldschoolvolvo's Avatar
I have a similar setup to ^^ also using a Saab Viggen PP and a Clutchnet SM9721 SVO disc. Working fine so far.
-Mike
1998 V70 T5
|Feedback|
Old 05-07-2018, 03:28 PM   #21
Uncleknucklez
bruspeed
Yes! I forgot we have the same setup, I am very happy with mine thus far, seems to be a good compromise between clamping power and pedal feel for my modest whp goals. (my car has hydraulic clutch setup fwiw)
Old 05-07-2018, 03:30 PM   #22
LeedomtoFreedom
I think John V once stated that Clutchnet is decent for discs, but not to be trusted for pressure plates. Hence the repainted sachs pp's they sell.
For the benefit of all, I started a thread a while back that talked about Saab 240mm pp with a mustang T5. It contains a lot of recent part numbers where old ones were dead.
Old 05-08-2018, 06:29 AM   #23
JerryJS8
der Junge
JerryJS8's Avatar
I once ordered stage red pressure plate and stage yellow fiber disc from Clutchnet. All I got was a red painted Sachs pressure plate that didn't even fit my application and this disc that had these copper pucks on one side and a normal organic disc surface on the back was almost 9mm thick.
At that time I didn't know I would have to shim it out 2mm to make it fit the stock flywheel so all I got was the fun of installing half of a performance package and a clutch setup that would hold less than stock... never again, never again...
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 05-08-2018, 07:36 AM   #24
Dadssleeper
Well guys the yoshifab/Clutchmasters is a repainted Sach clutch. Much like other company's they don't actually stamp and manufacture the clutch. They buy a clutch kit get it in house take it apart and upgrade the clamping area paint it add their logo and sell it to you.
I am 100% fine with that if I get a good clutch all said and done. My guess is Southbend clutch does the same. Reason I ordered the Yosifab was because I used clutchmasters clutches before back in the late 80's on a 5.0 mustang build and the clutch was pretty die hard.
This car has a M47 in it with a stock turbo @ 12 psi so I know its not a true test of the clutch but its mated to an m47 so I am not going to see what will give first. It feel great as a daily driver and do plan to put a 15g on it now that I got the clutch issues sorted out.
Next car I am building is going to get a whole different transmission all together so I will be soul searching once again.
Old 05-08-2018, 02:59 PM   #25
gsellstr
gsellstr's Avatar
My Southbend was a repainted Sachs but you could see they swapped out some stuff in it, painted it red, etc. Been quite happy with it though I'm not pushing it hard...yet...
