Old 05-16-2018, 06:40 PM   #76
EivlEvo
Something isn't right. (Also I'm mostly just talking to myself lol) The HKS should hold itself closed using boost because it's a valve, and then it blows off with vac? I guess having high crank pressure then makes it more reluctant to blow off (this might make sense with some odd driveability issues I've had).
I also know that my oil trap hose (the one that goes into the oil pan) clamped by the oil pump... is snapped about at that clamp.
Old 11-04-2018, 06:24 AM   #77
K9 240
K9 240's Avatar
Hi Eivl
Did you manage to sort this out in the end?
I have a similar problem. Car was running fine, I added a cat to the exhaust system (3"), reset LH2.4 & now surges between 1200 & 2000 rpm. All I did was unbolt the O2 sensor for the AFR gauge & a section of exhaust.
Have reset LH2.4 & have been babying car (no boost) but not showing any signs of clearing up.
Tim
K9 240 is offline   Reply With Quote
Old 11-05-2018, 02:47 PM   #78
Lord_Athlon
Just damn
How about you just leave the stock cbv in place, or set up an aftermarket cbv venting as designed and accept the fact that BOV's are indeed an air leak.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
