Old 04-26-2018, 10:30 PM   #26
pat244ti
pat244ti's Avatar
I agree with ditching the rear bar
Originally Posted by brendon_ak View Post
I drove this car when I worked for the shop that built it. Head tilted about 65 degrees towards center to fit [Im 6'5]
I also sat in it a million times to hold the wheel for another tech while the centerlocks were torqued. Did lots of weird manuvering going in and out of the car to avoid my feet hitting the door panels. Helped pull the trans on 3 occasions. Glad they finally got it out of the shop
- Patrick
83 244ti - road race
83 244ti - rally
73 1800es - resto
08 c30 T5 6spd - daily
97 dakota 5.2 4x4 single cab short bed - apocalypse mobile
Old 04-26-2018, 11:32 PM   #27
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Here's some shots of the weekend
Drool.
Originally Posted by pat244ti View Post
[Im 6'5]
Why, hello there.
Old 05-01-2018, 05:45 AM   #28
Janspeed
Originally Posted by EivlEvo View Post
A number of people run sans rear bar. This typically promotes understeer in all situations but it also prevents the turn exit spins (of both the tires AND the car lol)
It can be beneficial for a novice I suppose... that said, it can be beneficial to learn when to saw the wheel and balance the power at the rear end as well.
This said... the 25mm bar at the rear is no joke. I've spent a fair amount of time going sideways, dealing with various definitions of over-steer. Putting a 25/25 on my 245 and I almost spun (dangerously spun btw) my car with a 50-60mph transition that required throttle modulation. I would suggest putting the stock bar back on in lieu of the 25mm until you find a desirable corner balance (like corner weights) FR for the car.
2x Ford/Lotus Cortina , cars with front engine/RWD/ solid rear axel setup, much like a Volvo 240
notice how both Cortinas have their inner front wheel in the air.
This is caused by a big front s/bar and small/NO rear s/bar. This setup keeps the inner rear tire on the ground. That way there is no 1 tire wheelspin when exiting a corner. This picture was taken some time in the 1960's , these cars might not have had an expensive LSD fitted.
Just take some tools to the track and experiment with/without rear s/bar. It can be easily removed/installed provided you lift both rear wheels at the same time. (if you lift 1 side there will be springload on the s/bar)
It's fun and educational.
It is also possible to change front/rear balance with different tire pressures. But that's only for fine tuning.
found a similar pic of a 240 racecar.
[IMG][/IMG]
Old 05-02-2018, 12:50 PM   #29
2manyturbos
It's too bad you didn't come out to the Autocross. Marc Williams brought out his 142 track car and another friend of mine brought out his 242 autocross car. You would have been in good company. We actually had great weather, despite the forecast of rain.
Old 05-02-2018, 02:16 PM   #30
LC4CARL
Aero challenged
LC4CARL's Avatar
IIRC:
Adding pressure to the front would have the effect of (within reason) reducing understeer. And vice / versa?
Life begins at 10PSI.
Old 05-03-2018, 03:42 PM   #31
shoestring
shoestring's Avatar
Simply put, more front bar improves transitional (left-right-left) steering and more rear bar improves steady-state turning. This is relative to each other, of course. Most people (across the board, regardless of car) require much less rear bar than internet heroics would assume.
Old 05-03-2018, 04:04 PM   #32
EivlEvo
You mean to tell me that I don't need a holset and coilovers to commute to work? *gasp*
WHAT BLASPHEMY IS THIS!!?!?!?!?
Old 05-03-2018, 04:14 PM   #33
benski
Post
Heresy, I say! Eikers, poly bushings, Kerker 1 piece aluminum racing seats, side-draft Webers really aren't needed to go in a 30 mph commute? I've been mislead!!!!
Old 05-04-2018, 05:33 AM   #34
Happy Mew Year!!!
You do if you want to do it TB stylr and win the commute. Front wheel drive cars are the opposite and need stiffening in the rear and softening the front.
Old 05-07-2018, 06:42 PM   #35
Trevor57
Trevor57's Avatar
We have used pretty much every race pads for oem 240 brakes. We now use carbotech xp8 pads. If your car is in good shape, all you should need is pads, good fluid, and tires you don't mind ruining.
14 Mazda 5 6spd / 86 245 24hol racer / 92 245 / 86 245 lsx ( http://forums.turbobricks.com/showthread.php?t=321150 )
If you start threads, and do not reply to those threads with a resolution, you are a human analog of photobucket.
Trevor57 is offline   Reply With Quote
Old 05-07-2018, 06:46 PM   #36
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I don’t want to live in that world.
1980 242 Turbo
2004 V70R
Old 05-07-2018, 06:52 PM   #37
Uncleknucklez
bruspeed
Originally Posted by LC4CARL View Post
IIRC:
Really, tuning tire pressures is in excercise in add and subtracting tire “grip”
You change the contact patch, and spring rates to some extent when you start with tire pressures. As well as ride height and corner weight as well.
Chassis tuning is a game of give and take, ideally you would use 100% grip all the time, but because we expect cars to handle specific ways, (oversteer, under steer) we spend time changing the available grip to suit our needs.
I have been to a number of chassis setup schools, for dirt oval and road, read tons of books, have some class wins and a second overall autocross championship and I still only pretend to know anything about it.
