Old 05-03-2018, 10:23 PM   #1
stl522013
Default IRS Swap for Volvo 240??
I understand that this is not going to be cheap or easy, but if I wanted independent rear suspension in a Volvo 240, how would I go about it?
stl522013 is offline   Reply With Quote
Old 05-03-2018, 10:54 PM   #2
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Cutting out a bunch of stuff, welding in a bunch of stuff, a lot of sleepless nights, and most importantly, a lot of money.
Where are you sourcing the IRS from?
Why do you want to do this?
Why not just buy a car that has IRS and mod it to your hearts content? Unsure where you are in the world but E36 and MX5s are dirt ****ing cheap these days and have a lot more aftermarket support than some Frankenstein Volvo ever will.
Old 05-04-2018, 12:03 AM   #3
stl522013
I know I could just slap an LS into a Miata and it would be fast, but that has been done before. Idk what I want to source the IRS out of, that is why I came here. What cars have an IRS that would best fit a 240?
Old 05-04-2018, 01:32 AM   #4
Mueller
Mueller's Avatar
I'd copy how the hot rod guys are adding IRS to older Muscle cars like the Camaros and Mustangs.
Measure your rear end axle width and hit up the wreckers and see what other cars have a similar width. Start with 3 series BMW and go up from there. Latest generation Mustang has IRS as well. I've seen complete drop out assemblies on eBay for $400... with suspension and brakes.
Old 05-04-2018, 03:59 PM   #5
EivlEvo
Question still stands though... why?
If you just want to do it because it hasn't been done... I can get on board with that. But if you're trying to make the car handle better or some other odd thought it'd be interesting to know.
You're new so maybe you're one of the ones that still sees Volvo's from the outside looking in but everything has been done in these cars too. RBs 2JZ LSx 302.
But it'd still be interesting to know what your logic is.
Old 05-04-2018, 11:03 PM   #6
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
You’re not going to find a cut and dry how to. I think one or two people have done it. There’s some info on here if you search, but the people who have done it already had some idea of how to do it.
Hello My Glorious!
Old 05-04-2018, 11:38 PM   #7
cwdodson88
Look into the winters quick change IRS options for a 350z. The winters IRS center section, paired with the Porsche cv axles, and the geometry is looking super promising. High torque capacity, great geometry and if you don’t like the ratio, 5 minutes and 1/2 pint of fluid ( if you’re sloppy) and you have a new ratio. Problem.. expensive. Expect to drop 2-4K to get it right.
The Build Thread
SVEA - PUSHROD TURBO!
Old 05-05-2018, 01:16 AM   #8
Mueller
Mueller's Avatar
http://www.turbobricks.com/forums/sh...=289884&page=2
No idea if he ever finished the car or not, however there are pictures of an IRS install in thread above.
Old 05-05-2018, 08:46 AM   #9
benski
Post
Maybe a 760? But crumb, what a ton of work for so little real gain, IMO.
Old 05-05-2018, 02:15 PM   #10
M.H. Yount
M.H. Yount's Avatar
Unlimited $ to throw at it --- https://www.fuelcurve.com/1978-volvo-262-c/ Art Morrison rear subframe.
Old 05-05-2018, 05:13 PM   #11
Chumley360
Sexiest Dana ever.
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 05-05-2018, 09:06 PM   #12
mark244turbo
mark244turbo's Avatar
Erik Olsson aka Poik used an BMW E39 rear suspension in his incredible volvo 242 build!
http://www.eric-o.com/wordpress/
http://forum.savarturbo.se/viewtopic.php?f=21&t=80972
http://www.turbobricks.com/forums/sh...d.php?t=289884
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 05-06-2018, 12:24 PM   #13
Mueller
Mueller's Avatar
That is one nice 262, that shop is only 10 minutes from my house! Might have to go drive over to that area next week and see what else they are building.
Old 05-08-2018, 07:10 AM   #14
M.H. Yount
M.H. Yount's Avatar
Originally Posted by Mueller View Post
That is one nice 262....
Likely a 6 figure build. Jeez, they custom cast 17" wheels to look like the original 14's/15's....no substitute for cubic dollars.
Old 05-08-2018, 04:54 PM   #15
vertigosity
vertigosity's Avatar
I'm only counting ~40k before labor - $15k for an LT1 connect-and-cruise, about $15k for an Art Morrison IRS subframe, the wheels are probably in the $4k range, and the JRZ shocks are $2kish from Kaplan. Definitely out of even a well heeled Turbobricker's budget, but not quiiiiiite six figures, I bet. What I /really/ want to know... is what's hidden in that Bosch breakerless ignition module
I've had this conversation with myself - if I've gotta break out a grinder and welder to fit a Toyota or Explorer stick axle when I snap my 1031, I might as well adapt an IRS subframe from something. The shortlist of cars that are roughly the right width, have off-the-shelf diff + 5-lug upgrades, and qualify as "multi-link" (vs. "semi-trailing arm): NA/NB Miata, FD RX7, GD Impreza, E36 BMW, S13/S14 240SX. And... I've got a spare Miata subframe from a friend's parts car sitting next to a '74 145 with rusted out framerails and a demolished panhard rod mount. Miata is always the answer - in this case, for how to make a car I was going to crush anyways even *more* unroadworthy
80 245 8VNA / 93 245 5.3L LSx / 90 Miata / 92 Spec Miata
Old 05-10-2018, 07:52 PM   #16
mikezohsix
I have a complete 2004 GTO IRS take out with all the sub=frame mounts that I saved for something like this.
You would have to shorten the half shafts, and struts.
Was behind an LS1 and 4L60, so should be fairly stout.
Rotor to rotor, with brake calipers and e=brake cables, $250, in western MA.
Not sure where you are, but shipping could be just as much so pick up if possible would be the smart bet.
97 V90, gone but not forgotten,
- it's a driving car now with a 350hp all aluminum LS1 with T56 six speed manual transmission, and it hauls ass! Check the for sale section if you're interested in the car - http://forums.turbobricks.com/showthread.php?t=235015.
mikezohsix@yahoo.com
mikezohsix is offline   Reply With Quote
