Old 05-06-2018, 02:37 AM   #1
will740turbo
Question TCS/TRACS in the 80s? Someone hitting the pipe when they wrote that?
So I came across a wikipedia article that says Volvo introduced a TRACS/Traction Control System on a 760 in 1985... Seems wrong. Really wrong.
But after spinning a tire combined with a road seam on an undermaintained overpass resulted in me totaling my 740, I've been trying to figure out a solution to stop wheel spin at freeway speeds. Seems like a TCS is what I want.
So is this some horrible typo and it was introduced in 1995, or was there actually a TCS on the 760s in 1985? Or is there some chance I could find a rear axle that has sensor rings on each axle so I could use an aftermarket version?
will740turbo is offline   Reply With Quote
Old 05-06-2018, 04:05 AM   #2
740atl
educator monkey
740atl's Avatar
I'm not aware of any traction control available from volvo for these vehicles.
That being said, I've never had a problem with wheel spin at freeway speeds in any vehicle unless it was raining or snowing and in either case, I just slowed down.
Old 05-06-2018, 04:47 AM   #3
Acke
Most texts about it seems to have disappeared, but I remember reading about it. Here's something:
https://www.volvoforums.org.uk/showthread.php?t=194875
Old 05-06-2018, 05:50 AM   #4
eabras
ETC (electronic traction control) was an option on 7-series. Better tires, a limited slip diff or just better driving would be cheaper and easier to implement... I've used my right foot as traction control in all rwd vehicles I've driven/owned. Works pretty good.
eabras is offline   Reply With Quote
Old 05-06-2018, 07:53 AM   #5
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
If the car had ABS, it could be plausible to have some type of TCS. Like the ABS, I believe it would not be what is expected today. Retarding the timing with wheel spin wouldn't be that difficult.
2006 V70R a turbo finally!
PeaceEngineered is offline   Reply With Quote
Old 05-06-2018, 12:31 PM   #6
ovlov760
ovlov760's Avatar
I don't remember having a TRACS button on the dash of my 760TIC but I could just have a bad memory. The 850 series did get TRACS/ABS.
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
Old 05-06-2018, 05:37 PM   #7
Having good tires and proper LSD will keep you from spinning your tires at high way speeds.
Having good dampers also would have helped prevent you from loosing control.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-06-2018, 07:45 PM   #8
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
This.
#1 Performance upgrade is tires. Choose wisely as that is what makes contact with the pavement.
#79WDP
Old 05-06-2018, 11:22 PM   #9
will740turbo
It does have ABS, but only three sensors. The rear wheels are controlled with a single sensor on the driveshaft. Maybe if a system could be based on how fast the driveshaft changes speeds...
Old 05-06-2018, 11:25 PM   #10
will740turbo
AFAIK, all LSD stop working above about 25mph. I had looked into them and decided they wouldn't work because of those limitations.
Old 05-07-2018, 03:50 AM   #11
JW240
All idiot, no savant
JW240's Avatar
A true clutch LSD like found in the pre 1991? Cars works at all speeds. Only the G80 is disabled to start locking above 25mph. Something like a truetrack or the offerings from Kaplhenke would be the best solution, together with good tires and suspension. My car isn't exactly fast but with the truetrack and stuff i can really precisely aim where it goes and it's easy to correct when it wants to step out.
About the traction control, yes, it was sold. I remember those cars had the abs pump in the trunk. Two sensors near the diff pumpkin where there are some pre cast holes and a switch on the dash. Recently Skandix still sold those wheel speed sensors.
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
Old 05-07-2018, 10:30 AM   #12
Thats incorrect. The g80 diff does not work above 25 unless its modified.
Dana Powr-lok, true trac, and the wave trac work at any speed.
https://www.kaplhenke.com/collection...p-differential
Old 05-07-2018, 10:32 AM   #13
Pretty neat, I wonder if those were popular on the 16V turbo cars?
Old 05-07-2018, 11:39 AM   #14
eabras
As far as I know it was only available on cars/engines with motronic (b230et).
Old 05-07-2018, 03:09 PM   #15
OttoB
System had two extra sensors at half-shafts. They were located near differential. Never seen such a thing, but system was explained in green book about new features for MY '86.
Old 05-07-2018, 08:14 PM   #16
will740turbo
I'm thinking the easiest solution might be some kind of microcontroller that can calculate acceleration of the sensor in the driveshaft and ground the TPS "idle" pin. The LH2.4 ECU responds by ceasing ground pulses to the injectors until the switch opens.
Anyone good with Arduinos or PIC processors? It could be strictly on/off and run in parallel.
Old 05-08-2018, 10:36 AM   #17
easiest solution is fixing the stuff on your car thats making it sketchy.
Old 05-08-2018, 10:42 AM   #18
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
How PSI a stock can support?
Old 05-08-2018, 10:39 PM   #19
will740turbo
Thumbs down
Sorry, not rich enough to repave the bridge.
In other words, the car was stage zeroed years before this happened and I drove it for years without issues. It happened at three am and in a split second. Not my fault, not the point.
Old 05-09-2018, 11:49 AM   #20
Stage zero is not what you need to keep this from happening.
neither is repaving the roads.
Old 05-09-2018, 01:44 PM   #21
Stiggy Pop
Stiggy Pop's Avatar
What's with Turbobricks and blaming their accidents on overpasses
'79 242
943 pickup
Old 05-09-2018, 02:44 PM   #22
Happy Mew Year!!!
The easiest solution is just stay home and don't drive.
Old 05-09-2018, 04:42 PM   #23
Bring your big boy checkbook.
http://www.bosch-motorsport.com/medi...chure_epdf.pdf
http://www.vgs-motorsport.com/en/pro...-m4-kit-1.html
Seems like a good diff would be a lot cheaper.
Old 05-09-2018, 08:17 PM   #24
will740turbo
Wrong on both counts. I'm done talking to you.
