Old 05-06-2018, 01:35 PM   #1
GeneralBurrito
GeneralBurrito's Avatar
Default DIY Cherry Turbo lower brace?
From this picture: https://imgur.com/L8J7rwF
It looks like the Cherry Turbo lower brace is simply just flat bar steel that has a truss going across. Is the steel bar specially tempered or is it possible to make my own with some spare flat bar?
Old 05-06-2018, 02:11 PM   #2
Chumley360
I've seen DIY versions of that brace on the forums before. I think 3/16" mild steel was used,
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 05-06-2018, 02:21 PM   #3
GeneralBurrito
I'm just wondering because the design looks so simple, they might have done tempered steel or something. I have access to plenty of spare flat bar, so I think it's possible to make my own.
Old 05-06-2018, 02:57 PM   #4
240wagonguy
I was going to build a couple out of 1" tube of my own design for my 740's
Old 05-06-2018, 03:16 PM   #5
GeneralBurrito
I suppose some round tubing with crushed ends could possibly work too, might be lighter too, but then they won't have the bar that goes across like on the Cherry Turbo one.
Old 05-06-2018, 03:23 PM   #6
Chumley360
Easy enough to weld in a cross bar if you go the tube route.
Old 05-06-2018, 03:25 PM   #7
GeneralBurrito
That's true, I think I might do it with some tubing then. A simple design that might have more strength than flat bar since flat bar can bend and it probably weighs a bit less than a solid flat bar.
Old 05-07-2018, 06:28 PM   #8
Happy Mew Year!!!
I made mine out of 3/4 schedule 40 pipe
Old 05-14-2018, 08:53 AM   #9
photoman327
photoman327's Avatar
the flat one is easy to built. I have put off building one for years because when I find a used one for $40-50 delivered, its hard to justify running down the flat stock to built it. the round one is even simpler but in my mind not as effective.
Old 05-14-2018, 09:50 AM   #10
Looks like extra weight to me.
The cross bar is fairly useless unless it runs diagonally.
Also as I said in the other thread 7/8" EMT is sufficient as tubing is very strong when end loaded.
Old 05-14-2018, 07:24 PM   #11
GeneralBurrito
Okay, quick question. Is there a difference if I brace the cross member to the frame instead of drilling and bolting onto the rear bushing holders of the control arms? Yoshifab's braces go to the frame, while the cherry turbo braces attach to the rear bushing holders.
Old 05-14-2018, 08:16 PM   #12
Happy Mew Year!!!
7/8 emt wall thickness .0456"
3/4 schedule 40 steel pipe .824"
Old 05-15-2018, 08:17 PM   #13
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
Are you comparing wall thickness or outer diameter? Where did you get the sizes? Both pipes you listed (assuming 1/2" pipes not 3/4" or 7/8")should have similiar outer diameters if comparing rigid conduit to schedule 40 and will have a wall thickness of ~1/8". Now EMT- light duty conduit- is thinner with a respective reduction in the outer diameter and 3/4" would fall close in outer diameter to the other two.There is not much of any steel part that thick on the front of these cars from the factory that is 1/8" thick. You know it would not be the piece that fails.
2013 Audi Q5
Sold- 2006 V70R
PeaceEngineered is offline   Reply With Quote
Old 05-16-2018, 03:15 AM   #14
tintintin
That's hard for me to believe. Are you saying 3/4" steel pipe has a wall thickness of almost 1 inch? How can that be?
Old 05-16-2018, 05:11 AM   #15
Happy Mew Year!!!
Oops I used the wrong dimension, it's .113" , regardless it's an order of magnitude thicker. Might as well use butterfly wing bushings with snake skin reinforcements if you're using emt.
Old 05-17-2018, 12:53 PM   #16
Jack
Banned
Jack's Avatar
Volvo Gt lower braces attach to the control arm bushing brackets - they have to be drilled.
There was a noticeable difference when I installed mine
Old 05-17-2018, 03:58 PM   #17
GeneralBurrito
Yeah but yoshifab's braces bolt on to existing threaded hole on the frame about 2 feet from the cross member. The reviews on those claim to feel quite a difference too.
Old 05-17-2018, 04:08 PM   #18
You don't understand how tubing works, 1/8" wall is just extra unneeded weight.
A plastic soda straw can be imbedded in an oak tree in a tornado.
Old 05-17-2018, 07:43 PM   #19
PeaceEngineered
Sarcastic Optimist
Look at the thickness of all the members it would be connecting. None are that thick. If the EMT thickness is too thin for your taste, then get some .060" chromemoly tubing. Fairly cheap and easily shipped. FFS leave the schedule 40 for the plumber...
Old 05-17-2018, 07:55 PM   #20
Lando
Arthur Digby Sellers
Lando's Avatar
The area moment of inertia of the 3/4" schedule 40 is higher than the EMT, which means it has more flexural ridgitity assuming the same material). However depending on the other members of the system it may be overkill and just unnecessary weight.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is offline   Reply With Quote
Old 05-17-2018, 07:57 PM   #21
If you stacked the car up hard enough to buckle the EMT it would be a moot point anyway.
Old 05-17-2018, 08:00 PM   #22
Lando
Lando's Avatar
Probably true. The torque rods and trailing arms are thinner walled than schedule 40 and hardly larger in diameter and those links see far more stress than a lower chassis brace.
Old 05-17-2018, 08:20 PM   #23
Jack
Banned
Jack's Avatar
Just providing info. josh is one of The few Volvo vendors that has never disappointed me with their products
Old 05-17-2018, 08:42 PM   #24
GeneralBurrito
Yeah I'm just wondering because the cross members to the subframe are pretty much straight, while cm to the bushing holders are slightly more diagonal. Don't know if the angle of the brace helps with flex.
Old 05-17-2018, 09:49 PM   #25
Cwazywazy
Cwazywazy's Avatar
I made some with about $10 worth of hardware store crap.
A cross brace would be pretty easy, if you have a welder.
I don't know what I have
Cwazywazy is online now   Reply With Quote
