Old 05-06-2018, 04:24 PM   #1
sekokupu
Default 6-pin JPT male connector
Does those things exist? Would be easy way to do MAF extension but is the only way to butcher old MAF only for connector?
sekokupu is offline   Reply With Quote
Old 05-06-2018, 04:57 PM   #2
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Bosch 1928402603 might be it.
Old 05-07-2018, 01:18 AM   #3
sekokupu
If google image search shows me right pictures, that is female side. I need connector that is on the MAF side
Old 05-07-2018, 08:38 AM   #4
MDVLN
MDVLN's Avatar
OH! Wow, apologies, I read that totally wrong.
I'm coming up with no male side results for now, but I'll dig around a bit more.
Old 05-07-2018, 03:16 PM   #5
OttoB
No need for extension. You just need to dig out AMM wires at grommet, if this is a 240 w LH 2.4 ?
Old 05-09-2018, 11:58 AM   #6
Homer
OEMplus++
Homer's Avatar
That connector does not exist. You CAN find a 5 pin JPT connector and just transfer the pins or grab the gray connector on the DS strut tower from an 850. The pins will swap into that.
-Jacob:
2006 A4 - Comfy DD
Old 06-25-2018, 02:09 PM   #7
sekokupu
I just didn't want to broke or cut that connector, still not sure where maf will be located on my setup.
But my solution was to extract those JPT pins with special tool (stole some bobby pins from bathroom, great things for that job), and bought newer style sealed connector which still uses same JPT pins for extension (used old pins for new housing): http://www.finjector.com/verkkokaupp...-p-522159-231/
