Old 05-07-2018, 12:06 PM   #1
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Default 7/9 Alternator setup on a 240
I need to move my alternator to fit my turbo and specifically the wastegate, plus just to free up some room on that side of the engine. I've only found a few pictures of ones that may have been done years ago but lacking some details. The car is a 77 240 with no a/c and manual steering. I'm trying to keep the alt/crank and water pump with the shared belt(s)
Is the 7/9 bracket cut in half and then just moved down? And will it still clear the engine mount?
From an old thread
https://forums.turbobricks.com/showp...44&postcount=9
This is my block today.
IMG_20180506_165616 by Brandon Porter, on Flickr
The 7/9 bracket would bolt to the pair of diagonal holes below where the ground cable is now?
Hello My Glorious!
Old 05-07-2018, 12:17 PM   #2
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
I'm Helping someone with the same on their planned race car but we haven't reached this point yet.
I've got a spare 7/9 accessory bracket that has the AC compressor holes broken (please don't ask) so I suppose I could sacrifice that one for the sake of science.
Old 05-07-2018, 01:44 PM   #3
thelostartof
unbalanced chemical
thelostartof's Avatar
While I think there is a bracket that you can use iirc the 7/9 bracket with material cut off is the quickest way.
thelostartof is online now   Reply With Quote
Old 05-07-2018, 03:21 PM   #4
pat244ti
pat244ti's Avatar
This
On the Lemons car I am running the stock PS/AC bracket off the b230 from the 9 series with the bottom half cut off, than dropped in the lower position by making the rearmost hole a little larger
- Patrick
83 244ti - road race
83 244ti - rally
73 1800es - resto
08 c30 T5 6spd - daily
97 dakota 5.2 4x4 single cab short bed - apocalypse mobile
Old 05-07-2018, 04:51 PM   #5
CAPT_BLOTTO
#Crush It
Did you have to do anything with the engine mount? I'm about to mock it up
Old 05-07-2018, 05:11 PM   #6
CAPT_BLOTTO
#Crush It
Yeah I just test fitted it. It's pretty straight forward. Cut in half and then put it on. Clears the engine mount and intake bracket.
Old 05-07-2018, 07:51 PM   #7
MDVLN
MDVLN's Avatar
Stayed late so you beat me to it, haha.
Had a junk Denso 100A on hand and that cleared like the pic in the 1st post; I'd think even the Bosch 100A should clear the mount/support bracket in 240's but that's an eyeball guesstimation. That unit is heavier and you're trying to race this so I doubt you even care for that alt.
One more thing off the list at least. Cheers!
