Old 05-08-2018, 06:47 PM   #1
SenseiRice
Default How "peppy" should a rebuilt redblock feel?
So I got a 93 squirter motor for my 1991 245 (lh3.1 5spd) and I rebuilt it over the winter. This is the first overhaul I've ever done so I made sure to do everything as close to the book as possible. I got 0.005" shaved off the deck and an ipd vx3 cam for the motor. I did not overbore the motor as the bores were still within spec and the ring gap was 0.012" across cylinders 1,2,and 4 while cylinder 3 was 0.0013". I also did not get new cam shims, I checked valve lash with the head off the motor and while it was cold and I didn't write down the exact specs but I recall it being relatively equal across the board and all measurements were close to the lowest spec. (I know it's supposed to be done at operating temp but I had no way to heat it up that much at the time and the spec said it was for a cold engine) Everything else minus the valve guides and valves is new (I did lap the valves), new bearings, new valve springs, new gaskets, and so on. I just got done the break in and took my car out on the highway and it really doesn't feel much faster than my old stock b230f with 286k miles on it. I wasn't expecting a speed machine but I was in 4th at about 95mph with my foot hard on the floor and it really wasn't accelerating. It's running 87 octane gas with a bottle of stp octane booster so I don't know if that has anything to do with it still feeling sluggish or if it's because it still has the 27 year old main fuel pump, fuel filter, and injectors that have never been cleaned; at least as far as I know. It also has a code 2-3-2 in the jetronic computer but the code isn't illuminating the cel and no codes in the ezk. It also has a pretty gnarly exhaust leak because the flange that bolts the downpipe off the header too the rear of the exhaust is warped and rusted pretty badly. The car also has a rougher idle but doesn't feel like a misfire to me, it also has no problems with running and revs just fine. I'm thinking of running a compression test this weekend and maybe a fuel pressure/volume test but I wanted to know if there was anything else I should check? Or maybe I'm just delusional thinking it should be a lot quicker and I should accept my slow brick will never get to 60mph in under 10 seconds without a 16v or turbo.
Just a single man with a single overhead cam.
SenseiRice is offline   Reply With Quote
Old 05-08-2018, 06:50 PM   #2
tryingbe
Boosting along.
tryingbe's Avatar
I'm surprised you got it to 95 mph.
It's rated at 114 HP at the crank when it was new.
https://www.vlvworld.com/indexframe.html?engspecs.html
85 GLH 367whp
00 Insight mpg > yours.
Old 05-08-2018, 06:58 PM   #3
SenseiRice
Lol I've had it up to 120mph, I was just kinda hoping I'd have a bit more pull at the top end but it feels kinda lame. Was hoping for atleast 100whp but it still feels like it has about 80.
Old 05-08-2018, 07:42 PM   #4
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
You need to adjust your assometer...
That will fix it!
2013 Audi Q5
Sold- 2006 V70R
PeaceEngineered is offline   Reply With Quote
Old 05-08-2018, 08:14 PM   #5
Tentshedtrev
Tentshedtrev's Avatar
Assuming that the old engine was in decent shape, not puking a ton of blowby aka wasting bangs that could have been pressing down on the pistons...might have picked up 10hp? A bit more squish and more lift of the cam like you installed will do something, but it's nothing earth shattering in a NA engine. Chuck a decent free flowing exhaust on there to replace your trashed one, and you are at a good spot with a solid foundation to add on to later (more compression, bigger valves, boost ect.)
Life is too short to stay redblock..
1990 740 SE, Eaton m90 + Holset he351, twincharged b230F drift car
1983 242 turbo t5 whiteblock swap (in progress) (He351, MS3x, WC T5)
1983 244 (on blocks, currently parts storage)
1990 245 Mitsubishi 4D56 turbo diesel km132 transmission, water/meth
1983 245 m46 b230f Stahl header Toyota 4age ITBs MS2extra
Tentshedtrev is offline   Reply With Quote
Old 05-08-2018, 09:31 PM   #6
SenseiRice
I looked down the bore of the old motor with a bore scope and there was still minty crosshatching and no scoring, never tested the compression but it didn't burn much oil so it was in pretty decent shape (burned about a quart and a half every 3000 miles) the only thing original on my exhaust is the header and that's the only thing leaking rn but after the header it's a 2.25in catless straight pipe with a flow master super 10 at the back.
Old 05-08-2018, 09:37 PM   #7
Mogly
280WHP Regina
Mogly's Avatar
How many miles on the fresh up?
For sure fix those exhaust leaks.
403whp, profile picture
Ford Colonge V6 in the works.
Mogly is offline   Reply With Quote
Old 05-08-2018, 09:47 PM   #8
SenseiRice
Odometer said 230k miles
Old 05-08-2018, 09:59 PM   #9
Can play the blues
I've never known an M cammed engine to feel 'peppy' except for maybe from 1500-3000 rpm. A small zone of peppiness.
Exhaust leak messes with the computer. The code means the computer senses something isn't ok. Take care of the multiple issues and it'll feel better.
A good thing to do is change to LH2.4 and get a cam and chips for the ezk and jetronic. Then you will have peppy.
Old 05-08-2018, 10:42 PM   #10
tryingbe
Boosting along.
tryingbe's Avatar
How many miles did it take to get to 120mph?
Old 05-08-2018, 10:45 PM   #11
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
Though Iíve never had my na car this fast, I donít think it takes very long to do. 3rd gear takes me right to 100mph IIRC and it doesnít take long.
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
Old 05-08-2018, 10:51 PM   #12
GeneralBurrito
GeneralBurrito's Avatar
It should feel like a V8 cut in half. Jokes aside, it should feel better and more responsive than my worn out RB.
GeneralBurrito is online now   Reply With Quote
Old 05-09-2018, 09:35 AM   #13
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
it's NA and it wasn't whooped to begin with. you're not likely to feel much of anything until you put a manly man cam in there
Megasquirt Tuning!
Old 05-09-2018, 09:39 AM   #14
quillc
yv1a.com
quillc's Avatar
You are running a (relatively) low compression 4 cylinder motor. The VX3 likely does a decent job as compared to the stock M cam, but you still don't have enough compression to take full advantage of it. LH3.1 also does a great job of keeping you at stoich (read more efficiency - less power).
Chris
www.yv1a.com
Old 05-09-2018, 09:30 PM   #15
SenseiRice
I guess I'm on the hunt for an lh2.4 parts car.
Old 05-09-2018, 10:29 PM   #16
culberro
culberro's Avatar
Or shave the head for a total of .030-.040in off of it...
Old 05-09-2018, 10:47 PM   #17
deadken
I'm not positive, but I think you are going to want to dial in the cam (aka: adjustable cam gear) if you shave that much off the deck and head.
I guess I'm on the hunt for an lh2.4 +T parts car.
Fixed that for you...
deadken is offline   Reply With Quote
Old 05-10-2018, 08:57 AM   #18
Happy Mew Year!!!
It would be difficult to duplicate that torque push you get from a turbo with an n/a engine, my Toyota makes 180hp but only 136ft/lbs of torque over 8250rpms with a 4.56 final drive and 6spd manual. It's a relatively quick car but it never really feels the same as when the turbo spools in the 242.
Old 05-10-2018, 09:00 AM   #19
Happy Mew Year!!!
Adjustable cam gear and 2.0 pinto timing belt.
Old 05-10-2018, 12:05 PM   #20
culberro
culberro's Avatar
Pinto 2L belt isn't really needed until ~ .060in. I should say, I'm pretty sure you can't even stretch a 2L pinto belt on until there's .060in or more off of the head
Old 05-10-2018, 04:19 PM   #21
SenseiRice
Not trying to duplicate a turbo power necessarily, was kinda hoping for like a low 17 second car. If I wanted something genuinely fast I wouldn't have bought an NA 240 wagon lol.
Old 05-10-2018, 06:31 PM   #22
Mogly
280WHP Regina
Mogly's Avatar
How man miles are on the freshed up engine? Not how many miles it had before the fresh up.
Old 05-11-2018, 09:51 AM   #23
SenseiRice
Oh my bad, about 550 miles.
Old 05-12-2018, 06:01 AM   #24
Janspeed
in your original post you mentioned a leaking exhaust manifold and a 2-3-2 error.
You need to fix those. any leaks between cylinder head and lambda sensor will throw off lambda sensor readings and those false readings will be fed back to the ECU. It might even cause the engine to run in some sort of limp-home mode.
after you have fixed those things, try again.
Old 05-12-2018, 08:43 AM   #25
Happy Mew Year!!!
Also 550 miles the engine is still going to be tight, once it's broken in it should spin a little easier.
