Old 05-10-2018, 03:43 PM   #1
dirtbag240
Default Best coilover setup
So im finally going to bite the bullet and do the suspension right but looking around i know theres the 2 classic sweede rigs that you can get id proably be looking at the cheaper of the 2
I know john v made some s while back dunno if thats still going on
And then theres the kalphenke setup, i was thinking this one vut its going to put me close to 1700 for front a rear where as the sweede rig is closer to 1200 and john quoted a friend of mine 1000
Anh input is much appreciated
Its for a 89 245 thats evenetually getting a stroker 16v and itll be travked and rallied as well
dirtbag240 is offline   Reply With Quote
Old 05-10-2018, 03:56 PM   #2
You should define *Best* more narrowly. best value? best performance?
Id say some 4 way adjustable dlc shafted JRZ's might be the best. bring 20k.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-10-2018, 04:15 PM   #3
dirtbag240
Fsir enough ben, im looking for somthint ajdustable and robust as it is going to be daily driven but also tracked and rallied
And looking at under 1600cad hopefully
Old 05-10-2018, 04:22 PM   #4
Stock ride height for those apps?
Old 05-10-2018, 05:39 PM   #5
dirtbag240
Nah looking at 1.75 or 2.25 lower
Old 05-10-2018, 06:13 PM   #6
Man, I have some awesome JRZ dampers w/ 180mm travel, shorter housings, etc... that would be perfect for you. Out of your price range though.
Old 05-10-2018, 06:23 PM   #7
dirtbag240
yea ive looked at those, unfortunatly 3k usd for a whole setup is a bit out of reach
Old 05-10-2018, 06:25 PM   #8
dirtbag240
i was pondering going just the basic coilovers and then the koni single adjustable
Old 05-10-2018, 06:32 PM   #9
You could go that way, You might be running out of travel if you keep a stock length housing and want to lower it 2" or more.
Old 05-10-2018, 06:36 PM   #10
dirtbag240
yeah i just saw the short strut reinforced fronts that you make, what would be the max low on those
im running a 225x45x15 all 4 corners in that changes anything
Old 05-10-2018, 08:38 PM   #11
With the shorter version. you could put it on the ground if you really wanted to.
If you are gonna splurge for the shortened reinforced stuff, you should really jump upto the JRZ.
We can shorten stock housings.
Old 05-10-2018, 10:38 PM   #12
dirtbag240
Could you also help me choose the right spring rate for what i want to usr the car for?
Old 05-10-2018, 11:23 PM   #13
SLO240
Awesome Sauce
It may be silly, but I trust Ben implicitly. Everything from him is top notch. Front coilovers may be close to the only thing I do not have from him besides the speaker grills. Itching to give them a whirl.
1985 244 B230F Sister Killed It (RIP)
1982 242 B21FT Kid Hit It (RIP)
1993 245 B230F <--You can do it!
Buyer/seller feedback. http://forums.turbobricks.com/showth...67#post4602067
SLO240 is offline   Reply With Quote
Old 05-11-2018, 07:10 AM   #14
doucheNozzle
doucheNozzle's Avatar
DD, rally car and track car?
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
doucheNozzle is online now   Reply With Quote
Old 05-11-2018, 10:51 AM   #15
Old 05-11-2018, 10:53 AM   #16
Marvelous3
Who engineered this?
Marvelous3's Avatar
You see comrade, I want to DD it through the mean pot hole streets of downtown slammed, then ralley it on Thursdays, and then track it on Sundays. All on the same set up.
Old 05-11-2018, 10:54 AM   #17
What tires? Thats a fairly uncommon size now a days... besides for stuff like hoosiers and real racing compounds.
If you are running a tire package that is that short, you definitely dont want to run a damper thats too short otherwise you will scrape on everything. The car will be lowered a decent amount from those alone.
Old 05-11-2018, 10:55 AM   #18
To be fair, a good DD setup and a good rally setup often overlap in the world of Sven diagrams.
Old 05-11-2018, 01:27 PM   #19
dirtbag240
So i got 2 tire and wheel setups, the track/summer daily is some ventus rs-3s and the winter/gravel rally are hakapelitas
Amd i agree the ventus dropped the car a decent amount but i have yet to scrap on anything so i figure i have a but of room
Plus anything is better then a totally blown Billy hd
