Old 05-13-2018, 09:21 PM   #1
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Default Hydraulic Clutch MC thread size?
Hopefully easy question that has been eluding me. I figure someone else has run into the situation I am in for hydraulic clutch lines.
What is the thread size/pitch for the 7/9 Turbo clutch master cylinder outlet?
I need to run 4AN line from the clutch master cylinder to TO bearing and nothing I have on hand fits the Volvo clutch master cylinder.
Thanks!
#79WDP
Old 05-13-2018, 10:49 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
I had a custom line made a while back I never used. But for the life of me I can not remember what the thread was.
Old 05-14-2018, 12:45 AM   #3
2 minutes worth of searching on Google turned up this thread that identifies the clutch master and slave thread as M12x1.0.
http://www.turbobricks.com/forums/sh...d.php?t=234399
Another 2 minutes on Google turned up this adapter fitting.
https://www.ebay.com/itm/AN3-to-M12-...-/332151286284
Old 05-14-2018, 06:53 AM   #4
DET17
Reformed SAABaholic
Google force, strong in this one........
Old 05-14-2018, 10:31 AM   #5
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Thank You!!! I was stuck between the M10 and M12 debate and the only reference I could find was from Dave B's site which was for a 260 setup and not 7/9.
I ordered this: https://www.ebay.com/itm/1-Steel-Ban...MAAOSwdIFX1ziF
Steel Banjo Bolt Fittings M12 x 1.0 (Metric 12mm) to 4AN -4 AN4
I chose a banjo to get the 90 degree angle as there is not much space to spare with the shock tower.
Once fitted, I will report back.
