Old 05-14-2018, 01:11 PM   #1
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Default Stock 7/9 fuel lines to AN underhood
Honest I searched... And could not find a definitive answer except for fuel rails.
Has anyone used an adapter fitting from the drivers side under hood hard fuel line to AN?
It looks like the fitting is a M12x1.25 bubble flare compression, like a brake line..?
The closest I could get to an adapter is this GM TBI fitting: https://www.jegs.com/i/Russell/799/640800/10002/-1
Russell part number 640800
I would assume all 7/9 and even 240s may have the same under hood fuel line connection and that there would be an adapter available???
Any insights are appreciated.
Thanks!
#79WDP
Old 05-14-2018, 01:43 PM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
https://www.adaptall.com/products/Me...-06-L08-14.php
http://forums.tbforums.com/showpost....5&postcount=32
*Edit: OP is asking about a different fitting.
-Mike
1998 V70 T5
|Feedback|
Old 05-15-2018, 12:31 AM   #3
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Here is a video of the fitting in question: https://youtu.be/aUTwB4gt2go
Old 05-15-2018, 12:49 PM   #4
I'm pretty sure that's a ½"-20 SAE (45°) flare fitting. I don't think there's an adapter made to go directly to AN.
https://www.mcmaster.com/#50635k378/=1cur2qi
Old 05-15-2018, 02:25 PM   #5
apachechef
Burnt Sierra Madre
How much of the fuel system are you replacing?
Are you fixing a leaky junction?
Dammit, Lummert.
Old 05-15-2018, 05:07 PM   #6
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Let me check the threads for 1/2"-20 tonight. I figured metric and it did line up with 1.25 pitch like a glove.
This is for using the stock supply line for a LS swap. On the LS side I can easily get to -6AN, but looks harder on the Volvo side than I ever imagined.
At worst I can tube cut the flare off and then place a compression fitting on there to get to AN. But I would rather not cut it up if I don't have to.
Huge Thanks! I thought this would be easy, but no.
Old 05-15-2018, 07:07 PM   #7
lummert
lummert's Avatar
The fuel rail inlet tube will survive cutting. The compression fitting size that fits the tube is 5/16 inch. I cut off the fitting and installed a tee fitting and a Schrader valve. Installed the end fitting back into the inlet of the tee fitting using compression fitting hardware.
