Old 05-16-2018, 10:07 AM   #1
billkaz
Bomber Dream
billkaz's Avatar
Default 240 Manual Swap-Firewall plate question
Question about swapping the firewall plate for a 240 manual swap.
How has everyone handled the steering column portion of the swap?
1992 240 Wagon
2006 Mazda6 Wagon
billkaz is offline   Reply With Quote
Old 05-16-2018, 10:27 AM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
Why does the firewall plate need to be changed for a 240 manual swap?
-Mike
1998 V70 T5
|Feedback|
Old 05-16-2018, 10:53 AM   #3
EivlEvo
I handled it by not swapping it, and drilling a hole for my clutch cable.
Old 05-16-2018, 01:50 PM   #4
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
- Justin
1980 242 DL
240 Junk for Sale
Feedback
SlowRide is offline   Reply With Quote
Old 05-16-2018, 02:25 PM   #5
JohnMc
JohnMc's Avatar
Me too. Ain't NOBODY got time fo dat.
Well, maybe if you were going to do an OMGSOJDM LHD/RHD swap.
One little bitty pilot hole, then a bit of hogging out with a cone bit until it was big enough.
I didn't even swap the whole pedal bracket, I just cut off the outer piece and bolted that in to support the outer edge of the clutch pedal - the middle part of the auto pedal bracket had all the holes in the right places. Also swapped the brake pedal.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 05-16-2018, 02:29 PM   #6
propav8r
F*ck Edgar
propav8r's Avatar
Yeah, just drill it. a 9/16" bit or a unibit works, and you can get a drill up under the dash. As long as you get the hole in the ballpark, it'll work fine.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 05-16-2018, 04:52 PM   #7
EivlEvo
I drilled mine engine bay side. My "ballpark" was a little bigger than it needed to be, which was extremely convenient because the SECOND hole I made was only really able to be like 10% closer lol... it works though.
Old 05-16-2018, 05:23 PM   #8
unibit in engine bay using a 90 degree drive adapter on a drill
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-16-2018, 09:51 PM   #9
SLO240
Awesome Sauce
All y'all extra fancy. Hand crank and extensions. Just kidding. I attacked some of the holes from the inside and some from the outside. Which ever I thought I had the most control even if it was at quite an angle. Not to close is close enough in this case.
1985 244 B230F Sister Killed It (RIP)
1982 242 B21FT Kid Hit It (RIP)
1993 245 B230F <--You can do it!
Buyer/seller feedback. http://forums.turbobricks.com/showth...67#post4602067
SLO240 is offline   Reply With Quote
Old 05-16-2018, 10:05 PM   #10
esmth
dirty swede
esmth's Avatar
another +1 for drilling the panel. I went with the gymnastics method and did it under the dash after the old pedal-box was removed
