Tuff240
240 Ninja
- Jun 27, 2002
- Central California
Fuel pump relays.
Fuel pump relays.
Beautiful interior!
So, I got the fuel sending unit out of the tank today. That is definitely at least part of the fueling problem I am having, as the piece of rubber hose that is supposed to connect the lift-pump to the feed line for the primary pump was completely gone. I can only assume that it rotted enough that it fell off into the tank. So, there was NOTHING connecting the lift pump to the main line that feeds the primary.
In addition, the sending unit as a whole looks fairly crusty, and the fuel sock is torn and in really bad shape. So, I'm thinking that a new sending unit from IPD is in order.
In addition, shining a light into the tank revealed a fair amount of scale on the surface that I could see, so I'm wondering if I'm better off to just grab a new tank and replace it too. I've seen some aftermarket ones on eBay for about $145.00 shipped. Does anyone have any experience with these?
(Here are a couple of pics showing the scale in the tank.)
