Old 09-14-2013, 09:51 PM   #1
The Full Banana
not yet good enough
The Full Banana's Avatar
Default 1980 242 GT. A reasonable project.
Most recent picture:
Current setup:
Engine
99 T5 b5234t block with liners "shimmed"
98 T5 b5234t head lightly ported, stock cams
ME7 intake manifold with plenum shortened to clear PS pump, bung for IAC, brackets for 240 b230 throttle spool
960 3" throttle body
modified S70 fuel rail
850 turbo 3 bar FPR
ceramic coated ATP C30 cast exhaust manifold
38mm external wastegate dumping into exhaust
Garrett GTX3067R with ceramic coated .82 A/R turbine housing
CX racing SRT4 2.5" intercooler
Gates Racing kevlar timing belt
Volvo 260 Diesel passenger side engine mounts
960 e-fan
full 3" TIG welded 304SS exhaust with a cat and 2 Vibrant mufflers
92+ 940 NA radiator
Mann Provent oil separator
Bosch FR7DPP+ spark plugs
Engine Management
MS3x w/ knock module, 4 bar MAP, dual VR conditioner added in
Driveline
Getrag 265 transmission
One-off adapter plate
Volvo 960 bellhousing
e46 M3 transmission mounts
Sachs 240mm full-faced clutch disc from BMW e34 M5
e36 M3 / e34 M5 guibo
lengthened m47 front driveshaft
j9fab 740 turbo driveshaft support bracket
j9fab getrag 265 shifter bracket and linkage
BMW e60 shifter
Condor racing tall weighted shift knob
Tilton 60-1100 hydraulic release bearing with custom lines
Suspension
Front
GAZ Gold coilovers
450lb x 8" springs
6" helper springs
Homerbuchka camber plates and spring hats
control arms boxed with Yoshifab plates
polyurethane control arm and swaybar endlink bushings
Kaplhenke V2 QSRC spacers with adjustable Ackerman
GT firewall braces
cravingboost big strut brace
Yoshifab lower chassis braces
STS machining 28mm drop swaybar
Rear
Shortened trailing arms (20mm shorter)
Speedway 5" adjustable spring perches
200lb x 5" x 9.5" main springs
Koni Race shocks (p/n 30-5436)
no rear swaybar
Kaplhenke hybrid torque rods with Volvo bushings
iPd adjustable panhard bar
Genuine Volvo front trailing arm bushings
SuperPro polyurethane larger trailing arm bushings
Brakes
94 Ford Mustang Master Cylinder
Front
2005 Cayenne V8 front calipers
S60R 330mm rotors
Homer's caliper adapters
iPd braided stainless lines
Bosch Quietcast pads
Rear
2005 Cayenne V8 rear calipers
iPd braided stainless lines + Homer's adapter banjo lines
S60R 330mm rotors
Wheel/Tires
Current:
BBS RC305 17x9 et32 w/ motorsporttech adapters (38mm front, 32mm rear)
245/40R17 Pirelli P Zero Nero GT
Alternatives:
BBS RC304 17x8 et38 w/ motorsporttech adapters (38mm front, 32mm rear)
235/40R17 Falken RT615K
OE BMW DS1 17x7.5 et40 wrapped in Michelin Pilot Sports w/ motorsporttech adapters (38mm front, 32mm rear)
Interior
Recaro LS-B from mkII VW reupholstered in black leather
GT door cards
flocked '87 dash
Momo Mod 69 350mm suede steering wheel on Momo hub with 2.5” spacer
Rattletrap (sound deadener) below 1/8" closed-cell foam (decoupler) below 1lb/sq ft mass-loaded vinyl (sound barrier) below carpet (comfy)
Exterior
7" round H4 ecodes with relayed 12 gauge harness
GT fogs with relayed 12 gauge harness and 100w bulbs
Previous setup:
Engine
95 b230ft - stock longblock resealed
b21f intake manifold w/ added fuel injector bungs
nathaninwa fuel rail
TD04HL-20T w/ 11 blade billet compressor wheel, T3 wastegate actuator, ported straight turbine housing with a 3" vband outlet
90+ exhaust manifold w/ ported outlet
Grainger valve MBC @ 20 psi
NGK BPR6ES spark plugs
RSI Stage II turbo cam w/ RSI adjustable cam gear (timed straight up)
91+ 240 power steering pump mounted on custom bracket
240 OE diesel engine mounts
960 e-fan
full 3" 409SS exhaust with 1 dynomax ultra-flo muffler in the rear
92+ 940 NA radiator
Yoshifab vented oil cap
Engine Management
LH2.4
954 ECU with TLAO 6800rpm chip
EZK with Buchka wasted spark board and TLAO chip
Mitsubishi J702T ignition amplifier
Bosch Motorsport 2x2 coil
012 3" MAF
Bosch 42lb injectors (S60R green giants)
Driveline
240 flat flywheel w/ 60-2 pattern
Sachs 240mm pressure plate from Saab 9000 aero
j9fab getrag adapter plate & centering ring
m47 driveshaft (unmodified)
m47 bellhousing & clutch fork w/ BMW TO bearing
clutch cable
BMW e46 330xi shifter & knob
Suspension
Front
DIY Short Strut Coilovers - 240 strut tubes sectioned 3" shorter
A1 Racing coilover sleeves & adjusters
Kaplhenke spring hats
Eibach 450lb x 8" springs
~100lb x 4" tender springs
Koni Race struts (p/n 8610-1437)
scottyd camber plates
Kaplhenke roll correction spacers
GT firewall braces
Rear
DIY adjustable 2.5" spring perches (ebay accord coil-over kit with custom machined retainer)
250lb x 8" main springs
no rear swaybar
iPd adjustable torque rods
Brakes
Front
S60R 330mm rotors
OE Pagid pads
Rear
S60R 330mm rotors
Wearever Gold pads
Wheel/Tires
Interior
GT door cards
flocked '87 dash
Exterior
black GT grille & headlight buckets
New car, new thread.
This will be the continuation of my wagon project which you can see here --> http://forums.turbobricks.com/showthread.php?t=257147. Pretty much everything from that car will be swapped into this shell. The primary difference is that now I incorporate the goals of having a nice interior and body.
My goal:
The car needs to do everything as I personally expect it should to make for an enjoyable driving experience. If something stands out as being subpar, I will attempt to fix it to make it good. This is my all-inclusive, wholly subjective metric.
-It needs enough power to get out of it's own way and justify the suspension. ~230-250rwhp should be plenty, but that yet remains to be seen.
-It must handle well, but also be street-able enough for me to happily drive to work in the summer, around town casually, and on a long trip to iPd.
-It has to look 'good', but in doing so also give minimal concessions to drivability (no scraping, no rubbing, etc).
-The interior needs to be a nice place to be (quiet-ish, comfortable, and pleasing to look at).
Anyways, this was Brian's (2fast242gt) old shell that was graciously donated to me. A huge thanks to him for this, and for saving me from wallowing in my rusty-shelled misery.
Here is my starting point, after rolling off the trailer and a quick wash.
With that, the work begins.
Pulled the front apart to begin prepping the engine bay for paint. It was rattlecanned black, and was in really poor shape.
Spent a good portion of the day removing the paint. Not fun.
I pulled the dash the other night. I will be swapping in the dash from the 87 after I fix it up.
And now it's time to replace the destroyed window scrapers. Thanks Ken for shipping so quickly.
-Tom 1980 242 T5
Old 09-14-2013, 09:59 PM   #2
slow240
Home Schooled
slow240's Avatar
I'm excited to see Brian's 242 live on, but I reeeeally love your wagon.... That color/wheels/ overall fitment, it's just right.
Good luck with this beastie, ill keep an eye out for this
I'll polish your face
'89 780. Fine Corinthian leather.
Old 09-14-2013, 10:38 PM   #3
fortbrick
fortbrick's Avatar
This is gonna be good.
fortbrick is offline   Reply With Quote
Old 09-15-2013, 12:33 AM   #4
2fast242gt
Do you have a cobalt?
Yeah the rattle can job sucked. I just touched it up as I scratched it.
That car is a engine slut. Is this your basic goal? It was a fun setup.
1983 242dl
*6.0 lq4 swaped* Build thread
Old 09-16-2013, 01:18 AM   #5
doucheNozzle
doucheNozzle's Avatar
Subscribed
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 09-16-2013, 09:46 AM   #6
Old Iron
I Roll
Old Iron's Avatar
This will be a cool project! What's wrong with the wagon.
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 09-16-2013, 10:34 AM   #7
Benjam83
Moar Volvos than Queen B
I like the shave-ed-ness on the exterior.
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 09-20-2013, 01:47 PM   #8
smith_t240
Abnormally Aspirated
smith_t240's Avatar
Great angle in the pics. Keep that hood up and fender off, haha.
Let me know when you need a hand with the engine and stuff!
Also, what happened to 50 shades of grey as the thread title?
Smith T.
83 244Ti white project car
07 S60R 6spd black the better DD
Originally Posted by Ktown_Brick View Post
I stubbed my toe while getting a beer this afternoon. I feel both your guy's pain. What a crappy day, ohh well, tomorrow can't get much worse for me
smith_t240 is offline   Reply With Quote
Old 09-20-2013, 10:34 PM   #9
The Full Banana
not yet good enough
Rust and just a generally haggard shell.
Yeah, that just reminded me to order paint. Thanks for your help with the initial work in getting the car. I'll let you know when I'm thinking it's time for the engine to go in--probably a couple weekends from now. 50 shades of grey was swept under the rug after I decided to make paint a higher priority.
Anyways, cleaned up and painted the valve cover. This was in this car the last time it had a 8v redblock in it. Brian modified it to work with a 530 head years ago.
I took Redwood Chair's advice and ordered SprayMax 2k primer and clear coat. I used the POR Prep & Ready to take care of some flash rust that showed up in the past couple days. I'll reapply it to prep before priming.
I used the clear coat on the GT grille and headlight surrounds after repainting them black just now. That stuff is pretty great.
Tomorrow I'll finish prepping the engine bay, and then lay down the SprayMax 2K epoxy primer.
Old 09-20-2013, 10:36 PM   #10
doucheNozzle
Sand off the Volvo letters. That'll make that valve cover bitchin'
Old 09-20-2013, 10:49 PM   #11
The Full Banana
not yet good enough
I'm thinking about it.
I like the letters sanded on the newer style valve covers with the larger lettering, but on these old covers with small lettering I think it might be best as-is.
Old 09-20-2013, 11:54 PM   #12
Old Iron
I Roll
Old Iron's Avatar
Dang, whats the address, I am shipping you a valve cover for you do do for me! Look forward to more from this thread!
Old 09-21-2013, 01:54 AM   #13
2fast242gt
where did the car get flash rust? engine bay? i have some ooolldd pictures of this car and I when i was like 17, so I may photobomb this thread sometime. if you need help anytime or just want to hang out let me know! id love to help.
Old 09-21-2013, 02:22 AM   #14
The Full Banana
not yet good enough
Maybe if I get bored I'll use the extra paint on a spare 530 valve cover. If I do, I'll shoot you a PM.
Yeah, just a tiny bit in the engine bay which was to be expected. I will be finishing up the rest of the engine bay prep and priming tomorrow. I would definitely appreciate some help when it gets to be time to drop the engine in the car, but that will be a little while yet. I'll probably be working on it pretty much every weekend, with a little tinkering on weeknights. Stop on over!
I've been ordering so much stuff for this lately. Lots of little stuff, but quite a steady stream. Excited to get everything in!
Old 09-21-2013, 11:53 PM   #15
The Full Banana
not yet good enough
Car is now safely tucked away in the garage.
Almost time to put that Spray Max epoxy primer to work.
The pile of parts in queue is growing:
Old 09-22-2013, 03:48 AM   #16
2fast242gt
Awsome! Did you score a new grill? Or did you paint my old one? Looks very nice I like the progress.
Old 09-22-2013, 11:22 AM   #17
smith_t240
smith_t240's Avatar
The foundation to greatness.
Great progress on stripping the bay and getting some stuff painted. Should we do a double header engine swap weekend? I am finally getting what I need for the new longblock.
Old 09-22-2013, 12:19 PM   #18
volvobrage
Really nice job!Keep on going!
The rust/crash fix on the driver side doesnt look so nice, planning on changing that while your at it?
volvobrage is offline   Reply With Quote
Old 09-22-2013, 01:06 PM   #19
The Full Banana
not yet good enough
Same old grille, just cleaned up and painted
Thanks. Double header sounds rough... but yeah, let's get cranking. The whole non-running car thing is lame.
Thanks! I would like to change it, just trying to figure out the best way to go about it. Some day I will have to buy a welder and learn to use it.
Old 09-23-2013, 02:19 AM   #20
volvobrage
Look how I did it in my project threadIf you take good time dismounting and have a donor car its actually a quite easy job!
But ofcourse you need a welding machine first
Keep on going!
Old 09-23-2013, 02:36 AM   #21
2fast242gt
If you get a new innerfender I'd be glad to repair that the right way for you. Its always bothered me, that repaor was done when I was 17 by a local guy I knew. It would be easy to make it look like nothing ever happend.
Old 09-24-2013, 12:56 PM   #22
550
Diggin it!
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 09-26-2013, 08:53 AM   #23
The Full Banana
not yet good enough
This stuff showed up:
50 sq ft of Fat Mat Rattle Trap & 100 sq ft of Mass Loaded Vinyl.
Started on the passenger door. 25% minimum coverage is all I am shooting for with the Rattle Trap.
Old 09-26-2013, 09:03 AM   #24
Josepilove
http://www.youtube.com/watch?v=NMwB5uIWOOI
Josepilove is offline   Reply With Quote
Old 09-29-2013, 10:34 PM   #25
The Full Banana
not yet good enough
More progress this weekend.
Measured and cut out the strut tower opening to make room for camber plate adjustment.
Finally wrapped up the prep and sprayed the engine bay with Spray Max 2K epoxy primer. For an aerosol can, this stuff is pretty great.
Then I pulled the dash out of the wagon. This is in way worse condition than I realized. Not sure what I'll end up doing with this.
I'll be using some of the blue interior trim from the wagon for this car, so I tried out Duplicolor interior paint. Seems to be pretty good.
