Old 07-11-2010, 10:59 PM   #226
YLD244
YLD244's Avatar
Just spent the last 2 hours reading from start to finish. Love this build.
keep up the good work, and looking forward to more updates!
YLD244 is offline   Reply With Quote
Old 07-16-2010, 05:34 AM   #227
Turbosteen
I was born at a young age
Turbosteen's Avatar
Thanks!
Your 740 gives me inspiration to work on the exterior of the car next year, I should start planning for that. Thinking it would be best to do the entire car in one go (paint etc.)
Been working on the exhaust and the M90 install
Downpipe is 71mm stock, so my brother welded a 3' piece on to it
Next I made the tail pipes, simple stainless steel 2,5' cut under a slight angle
M90 install....
removing the M46 wasn't really difficult, loosening the bellhousing bolts was the most difficult. Old PP and flywheel looked ok, no oil on them etc
Preparing the M90 (new oil and seals, also new clutch fork)
Fitting the new flywheel
Weight billet flywheel = 5,4kg
Weight 850 PP and disc = 7,5kg
Total = =/- 13kg
Dished flywheel = +/- 14kg
M46 PP and disc = +/- 3,5kg (maybe 4)
Total = +/- 18kg
So differences of roughly 5kg, but on the old flywheel lots of weight was on the outer edge giving a lot of energy storage I guess,
I think (hope..) it will be very driveable with the new setup
850R PP, partnumbers
It fits!
Really good clutch travel/feeling, operation is al little bit harder, but still light
Now fitting the driveshaft, shifter (thanks Blabla and Joris!) and other bits.
Going to fabricate the exhaust hopefully..
Edit:
Finished fitting the shifter assembly and mounted the driveshaft
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 07-16-2010, 11:35 AM   #228
maxman142001
I like turtles
maxman142001's Avatar
pimp.. my dream setup
as nothing is impossible with God, even turbo's fixing themselves
-2011 VW GTi
maxman142001 is offline   Reply With Quote
Old 07-17-2010, 01:42 AM   #229
YLD244
YLD244's Avatar
love that flywheel.
should rev much quicker now
Old 07-17-2010, 08:06 AM   #230
Cojones
Cojones's Avatar
Schweet! Good job!
S90 Executive
Cojones is offline   Reply With Quote
Old 07-17-2010, 06:33 PM   #231
J2_
J2_'s Avatar
you'll love the M90 ;)
J2_ is offline   Reply With Quote
Old 07-18-2010, 05:09 AM   #232
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
Sweet, that's a nice upgrade over the M46.
Any idea how much torque the 850R pressure plate can handle?
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline   Reply With Quote
Old 07-18-2010, 05:57 PM   #233
volvo78244
Ring apprentice
volvo78244's Avatar
I think my name should be written on every piece of M90 accessory you got from me .
Remember to drive it on the Ring, not only towards it . . .
Making nice progress and as always clean and good work.
2019 Peugeot Expert
2005 V70 - 2.4D
1992 740 B230FD
1982 242 B230FK
volvo78244 is offline   Reply With Quote
Old 07-19-2010, 10:30 PM   #234
aussyvolvo
Will stalk for money
aussyvolvo's Avatar
you had a b204ft and a b234f.... why did you not put the turbo stuff onto the b234f? or did you? I read only parts because I gave up reading it all after a while :P
on another note.....!this thread rules!! :P whens the turbo thats so big that it wont fit, going to go in?
she wanted me to spend all my time with her, that meant no tbricks and no gym...... so I got fat, and she found someone else...... skinnier.......... so naturally I'm back on tbricks to spread the badly spelt word :P
aussyvolvo is offline   Reply With Quote
Old 07-21-2010, 12:37 PM   #235
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Looks good Flip , See you in a few days
760 Turbo '86|Volvo 360 cup|Volvo XC90 04|
My Seller Feedback
Old 07-26-2010, 05:43 AM   #236
Turbosteen
Turbosteen's Avatar
So, worked hard the past week to get my car ready for MOT and the EU 5.0 meet..
Finishing the exhaust was hard on my back, but very happy with how it turned out. Need to lengthen the tail pipes since that would probably improve the noise.
Made a bracket to support the downpipe using the original clamp. It's just a piece of square tubing painted silver
Summit bullet and first muffler in place
Over axle bend (mostly made myself but also using stock Simons parts)
Last muffler, needs to be adjusted still
Added a third bung on the downpipe since the M90 left no room for the O2 sensor..
Did all the weld myself btw, second time ever i welded with TIG, first time ever I made and placed an exhaust on a car without any help.. it took a long time to finish this but certainly learned a lot about welding and stuff!
So the car was ready for the meet!
The meet was great, also found a nice picture of my car
The drive went ok, lots of fun. Four people in the car and still faster accelerating then a fast honda civic haha
I also rewired the headlights (directly from the battery so more light now!) and installed a relay to feed the fuelpump and wideband directly from a main positive terminal in the car. Now the white volvo fuelpump relay doesn't get really hot anymore.
Old 08-14-2010, 04:25 PM   #237
Turbosteen
Turbosteen's Avatar
Few more things I did in the last few weeks
Got a new oil line for the turbo, the original one is still ok, but I don't like the stock line, this is going to be much better:
I also fixed a lot of stupid little things like a leaking tail light, loose plastic housing of mirror etc.
I removed the back windshield, since it wasn't sealed properly anymore, it was possible to push it open along the entire top side (like 5mm!)
Getting it out was dead easy, cleaning etc. went ok and got someone to glue in another one (I actually grabbed a winshield from a 87- 740 that had the one with the heating lines in between the layers). Looks very nice, need to polish it a bit etc.
At least I don't get any water in the car anymore (solved this with ductape for +/- 7 months....)
I also had good looking door cards for my car, bought a few years ago. The ones I had when I bought the car were severly tanned by the sun.
This also gave me the opportunity to install electric window regulators, finally it's becoming a 760.... wiring was already in the car for this btw, just need to give it a main positive via a relay. All regulators together weigh in at 10kg (21lbs?)
I also cleaned the doors from the inside, used tape and zipties to stop rattles and gave some new rust protection (but very happy with how well they were looking in terms of rust, there was none!)
Tadaa
(Installed speakers in the rear doors as well! Also installed wires, just need to fix up an amp for the speakers on the rear shelf, the volvo radio only has 4 channels.. This means I soon have 10 speakers:D)
Talking about the speakers I have in the back (under the rear windhield), I opened them to see what 28 years of sun had caused..
Only the small tweater like speakers failed, the other ones are still pretty much ok. I need to find out what I can put into them, maybe just get rid of the filter that's in it?
But it's an impressive piece of stuff, the housings are made from aluminium, weighing a lot (think about 5+kg).
Just need to install all the interior parts again that I removed for the replacement window, and do some other small stuff and then I'm done for the next few months..
And the other picture I found of my car on the Nordschleife
About the M90 install, everything works perfect, except the gearbox is making the famous noise of clicking gears..
I talked about this with Martijn (blabla) who had the same. It's supposed to be ''normal'', 850 drivers also have it sometimes.
I hope it will become less anoying...
Not really a logic order in this post..
Old 08-14-2010, 08:00 PM   #238
morganpartee
Damn I love this car.
Almost out of the Volvo game!
2011 Ford Ranger
1997 Miata, Supercharged
2002 Suzuki DRZ-400S
2013 Yamaha FZ6R
morganpartee is offline   Reply With Quote
Old 08-14-2010, 11:14 PM   #239
ButterflyBrakeChecker
ButterflyBrakeChecker's Avatar
what's up with that allignment! looks like you're driving strait...
ButterflyBrakeChecker is offline   Reply With Quote
Old 08-16-2010, 03:18 PM   #240
slipstream3d
slipstream3d's Avatar
Hot damn. I've never seen a 700 with manual windows or, for that matter, a manual transmission (Edmonton, Alberta, Canada).
Green interior on the green hell. I am jealous (won't make another green pun).
Driving: 2012 Subaru WRX STi hatchback, World Rally Blue
Second car: 1991 940 Turbo - needs some work
Written off by a deer: Magic Blue 2005 S60R
slipstream3d is offline   Reply With Quote
Old 08-20-2010, 05:35 AM   #241
YLD244
YLD244's Avatar
Nice work mate.
yeah toss those speakers and get a nice set of 6.5" splits
Old 09-13-2010, 03:06 PM   #242
odinthewanderer
i want that interior. and now i want a 700
ask me what kind of stupid i am today?
92 240 wagon, aw70, (tool box, prepping to be driver) new mexico clean!
92 745tic mild stuff done(7s and 9s are not 240s, pulling engine to build for the 77, ask for parts, body is clean) for sale?
92 245 modified (sold)
77 244 dl (almost done with resto... SOOON)
91 245 m47, rust bucket winter beater (driver, now parts)
90 234 aw70, side swiped winter beater (driver)
72 ford highboy, farm rig
95 chevy g20, family pet pig.
odinthewanderer is offline   Reply With Quote
Old 09-13-2010, 03:28 PM   #243
Hagar17
Hagar17's Avatar
700's are the new 200's
Keeping late 80's Swedish metal alive!
Hagar17 is offline   Reply With Quote
Old 09-14-2010, 01:11 PM   #244
Turbosteen
Turbosteen's Avatar
Was a fast corner, not much steering required.
Haha, the green suits the exterior so I like it, and we have plenty of manual window volvo's over here.
Meanwhile, whilst mounting the TCU correclty (the mounting bracket actually fits the 1982 mounting points!) I swapped it for another unit, just because I was lazy to swap the bracket from one unit to the other..
Drove a bit, car felt slower then on the Ring (on the Ring it easily did 200 km/h on the straight). Started wondering what was wrong, but then I remembered the TCU swap...
Seems like I mounted the TCU for a 950 ecu (white label one). Hopefully this solves the problem.. will test it in the next days.
Also ordered a aluminium IC from KL-racing in Sweden, so preformance wise I'm good to go for a while (although I also want a truetrac). I now need to start looking at some rust prevention and the exterior for next year.
Still in doubt how I'm going to solve the exterior, touch it up or do a respray...
Choices, choices...
Old 09-14-2010, 02:31 PM   #245
VolvoForLife
VolvoForLife's Avatar
nothing to gain performance wise so choose what's best for the least amount of money OR buy my 740 GLT blackline with perfect exterior and 9" borbets and swap everything over
Use the talents you posess, for if no bird sang, the forest would be silent.
'06 V70 D5
'06 S40 1.6d
'13 Cannondale CAAD 10 Ultegra
VolvoForLife is offline   Reply With Quote
Old 09-14-2010, 02:50 PM   #246
volvo78244
Ring apprentice
volvo78244's Avatar
I was thinking of upgrading mine too, I was at a local shop and they quoted about 500€ for custom one (they do lots of rally cars) but that's rather pricey.
Which one did you order?
Old 09-14-2010, 03:12 PM   #247
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Bell Intercooler /plug
Old 10-11-2010, 05:31 PM   #248
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Hi,
those noises you mentioned are totally normal cause theres no pilotbearing which is the same problem also on the 850 when this noise occurs...
BTW thats the reason why volvo installed a 2massflywheel together with gasoline engines on the M90.. The m90 diesel95+ doesnt mattered cause it was overnoising the grindinglike sound..
I for my self also have this loud noise.. what you can try is.. pull the clutch and listen to the noise disappearing.. man youre driving a volvo.. if theres a noise turn up the music :D
Old 10-11-2010, 05:38 PM   #249
Mr.Borrie
Mr.Borrie's Avatar
you sir are correct! my solution for noisy cars, girls, kids, cops..
Old 10-13-2010, 03:16 PM   #250
Turbosteen
Turbosteen's Avatar
Borbets? Why weren't you at the EU5.0 meet?
The ''60mm med AC version'' comes in under €250,- (with shipping)
I've read that yeah, but it is still annoying.. You don't hear it when you drive at a constant pace
Best solution for all volvo rattles
Meanwhile, the KL-racing IC arrived:
Needs a little bit attention with a small grinder, but seems like a solid unit. We'll see when it goes in.
Also have a 2nd cam cover that is getting blasted, so when that's ready I can look into swapping the cams. During all this we're also trying to get LH2.4 to do what we want..
The clutch is doing perfect, very good bite when shifting fast so I'm happy
