Old 09-18-2019, 03:56 AM   #226
ogamer777
Loading...
ogamer777's Avatar
1979 B23E BW55 VIN: 2428M1161875
Aussie car through and through. Rare auto conversion upon import to Australia. Slick top.
84 242 DL M46 212000Mi
82 244 GLT (15G) M46 243500Mi 23 Aug 2019
79 242 GT 1 of 600 Aussie RHD BW55 312223Km
83 245 TURBO M46 "117000Mi"
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
ogamer777 is offline   Reply With Quote
Old 10-03-2019, 09:06 AM   #227
bgpzfm142
crossmember
bgpzfm142's Avatar
Picked up an orphan, hereby christened Rudie by me, but known by Mother Volvo as
2428 M 1 162392
Location (now) = Launceston, Tasmania (along with my other GT)
Rudie is missing some parts, and has other parts which no 242GT should ever have - like, a 160 head. And an LPG conversion. And 244 seats which don't fold back.
But see this ID plate, which has 242-844-5182-46 on it?
That bolded '8' indicates it's supposed to be a BW55 - which were fitted by Volvo Australia or dealers for those buyers who didn't like 3 pedals, and so they also modified the plate from a '2' to an '8' - but Rudie has 3 pedals and M46 semi-fitted! (Semi-fitted as in ... front tailshaft section missing)
Yes; Rudie is RUDE. And he needs to be fully un-rudened.
_______ THE FLEET (AKA good luck trying to park around here)
71 1800E | 73 144 | 74 142 | 74 145 | 79 242GT | 85 244 | 88 780 V6 | 93 945T | 2010 S80 V8
plus a Holden Commodore VT SS 5.7
feedback thread
Last edited by bgpzfm142; 10-03-2019 at 09:08 AM.. Reason: ID plate can now be seen
bgpzfm142 is offline   Reply With Quote
Old 10-03-2019, 02:19 PM   #228
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
^Is the block still a B23, or did they just swap in a B21A or a B21E from the 244 that everything seems to have come from? Re: the 160 head, all North American GTs came with them, but then again, those cars had the lowly B21F. Lambda-Sond on US cars, nothing on Canadian cars.
@1982_volvo_242_turbo on IG
Old 10-03-2019, 10:21 PM   #229
LC4CARL
Aero challenged
LC4CARL's Avatar
I think I need a GT...
@PDXvolvo on IG
Old 10-04-2019, 03:30 AM   #230
bgpzfm142
crossmember
bgpzfm142's Avatar
Good question. The engine number isn't really visible, so an answer will require more investigation. The PO has plugged the K-Jet injector holes, so the head has likely been sourced from a B21E.
AFAIK, OZ market GTs got the 405 head with high compression B23E K-Jet engines and an H cam.
Old 10-04-2019, 04:34 AM   #231
John242Ti
John242Ti's Avatar
Volvo did finally improve the engine part number engraving in 1983, when they started using a dot matrix, instead of punching thin numbers into the side of the block, just below the head.
Yup, Ethan's car is so equipped. Same engine as what you'd find in a Swedish version, just with a longer throttle cable to reach the pedal in its RHD location. The more desirable B23E, too, since forged internals, whereas the 1981-84 B23E had cast pistons, but at least a forged crank for most of its production. Had one of the Canadian 1981 engines in an '81 242DL for a while. So, K cam with Pulsair. I did delete the EGR parts, mainly since the exhaust manifold nuts were seized on the headpipe, so I had to reuse the Lambda-Sond B21F manifold on the 405 head.
Old 10-07-2019, 06:49 AM   #232
bgpzfm142
crossmember
bgpzfm142's Avatar
These numbers (which only became visible when the inlet manifold and the whole LPG carburetor mess was removed) are not dot matrix ones. I thought I'd have to look up the engine prefix in the parts book, but it wasn't necessary; under all that strange koolaid, there was something proudly embossed on the block:
Volvo B21
Oh dear.
An LPG conversion equates to about 10% loss of power, and this dude puts in smaller engine with less power than OE?
Seems poor ol' Rudie has ended up more molested than one of Cardinal Pell's alter boys. And I thought the LPG tank in the boot (sorry, trunk) was the only thing which didn't belong there....
Project Rudie should make for an interesting build thread eventually.
Old 10-07-2019, 01:36 PM   #233
John242Ti
John242Ti's Avatar
LS swap time, sounds like. Since it's already kinda bastardized, might as well join the LS crowd...
Old 10-08-2019, 04:06 AM   #234
bgpzfm142
crossmember
bgpzfm142's Avatar
Nah, the Commodore already has a factory-fitted LS 5.7*, so I'm already satisfied in the GM V8 department.
An 8V B230F+t with a 531, JVAB rods, CP pistons, and MS3 or similar may putter along nicely. I already have a spare L-block B230F with a 531 on it, plus a spare 90+, which need a home.
Old 10-08-2019, 03:25 PM   #235
John242Ti
John242Ti's Avatar
There you go... That would fit the bill.
-J
Old 10-12-2019, 09:20 PM   #236
Bready
board deviant
Bready's Avatar
Originally Posted by Volvo0815 View Post
Finally was able to travel to sweden and photograph the lost GTs
1979 2.3L off the road since 2000, VIN: 2428M1147749
1979 2.3L VIN: 2428M1147766
To the right in the picture with the front facing the camera
1978 2.1L off the road since 1995, VIN: 2424L1135755
I have photographs from 2016 from a friend which shows the cars still in saveable condition, but now unfortunately they are all completely destroyed by vandals.
Btw
50: Volvo0815: 1978 VIN:2424L1 128289 - Sweden
is in Switzerland not sweden
-Volvo0815
Saddest post in history
Originally Posted by Pennybridge Pioneer View Post
Just because you didn't experience something growing up doesn't mean other people didn't. Case in point: I can't remember ever being a total moron, but that doesn't mean you aren't one.
Keep your minds out of my pants.
Originally Posted by centason View Post
Bready is right.
Originally Posted by OldGrandpaTune View Post
You are 100% right.
Kalazdar - (3/23/83 to 5/12/03)
MUST READ!!! https://cleantechnica.com/2017/04/24...-adds-screwed/
Bready is offline   Reply With Quote
Old 10-13-2019, 08:39 PM   #237
bgpzfm142
crossmember
bgpzfm142's Avatar
Thought I'd ask here first -
Would there be much interest, from those here present, in getting some reproduction rear vent window seals made? I mean like the unobtanium 676923 and 676924 Tätningslists? I've just open a dialogue with a place that does custom car rubbers, and he may ask about numbers. I need 3 for my cars (the GT, the recently acquired Rudie, and the acquired-a-long-time-ago-but-still-to-start-a-project-thread 142).
Old 10-13-2019, 09:15 PM   #238
John242Ti
John242Ti's Avatar
^Probably. Even though mine is a turbo and not a GT, it'd be nice to have fresh quarter glass seals.
Old 10-14-2019, 12:23 AM   #239
Forg
Forg's Avatar
Hmmm, mine seem to be pretty decent … but depending on cost, I might stick my hand up for a set of spares. But it does depend on the emmachizzit.
You've got a W427?!
Officially more comely than Paul Buck.
When I'm cruisin' in overdrive ...
Don't have to listen to no run-of-the-mill talk jive.
Shatner: The Colonel is breakdancing ... gimme a break!!
Rollins: Credit terms raised!
Shatner: I can't get behind any of that!
Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ...
Rollins: Well, I can't!!
Forg is offline   Reply With Quote
Old 10-14-2019, 01:00 PM   #240
bgpzfm142
crossmember
bgpzfm142's Avatar
You've got a W427?!
Nope, I made a mistake.
Old 10-14-2019, 04:18 PM   #241
alschnertz
Enough already!
alschnertz's Avatar
Geeze, that last one (...755) looks like it's been sitting at the bottom of a lake since 1995.
Old 10-14-2019, 06:16 PM   #242
Forg
Forg's Avatar
Way to cold-spoon me!
Old 12-12-2019, 04:55 PM   #243
DWBF1
Checking in! Just starting a full restoration on VC 24245 M 1 158416. You can follow the progress here.
2000 V70R +M66 etc.
1979 242GT *Under Construction*
DWBF1 is offline   Reply With Quote
Old 02-21-2020, 10:43 AM   #244
Flying Brick Performance
So, I will post a pic over the week, but I’ve got a 1979 242GT in Perth, Australia.
Pretty sure it is 2428 M1 155558.
I also know of another 3 that another guy has here in Perth. If you want to have a look at his progress, follow Loud Projects on Instagram. His is a full ground up rebuild for a daily driver and advertising piece for his business.
Mine is getting the 16v, twin 45 DCOE Weber’s. Another ground up rebuild (just a little too much rust in horrible places), but will be built to do historic “Around the Houses” racing here in Western Australia. You can follow my build on Instagram (Flying Brick Performance) and if you Google Albany ‘Round the Houses, you’ll find a link to the racing.
I’ll see if I can get his VIN numbers and maybe some pics as well.
1979 Volvo 242GT
1986 BMW 325e Turbo Frankenstein
2003 Ford Pursuit Ute Tow Car
Flying Brick Performance is offline   Reply With Quote
Old 02-23-2020, 04:27 AM   #245
GerwinVdw9
All these lost GTs are quite hurtful to see.
Do you know what the story behind this car graveyard is?
GerwinVdw9 is offline   Reply With Quote
Old 06-15-2020, 07:04 AM   #246
RichGT
RichGT's Avatar
Once upon a time, blah blah rust, the end! Don’t let it be you, oh no.
'80 GT, M46
'89 740ti, M90
RichGT is offline   Reply With Quote
Old 07-08-2020, 11:53 AM   #247
Moyni
Moyni's Avatar
We saved this one from its forest grave near the Chesapeake bay for $400. Its currently on its way to Poland for a full restoration by its new owner. M46 car, was able to get a extra set of seats and a bunch of other goodies from a local guy to send with it.
Classic Vehicle & Marketing Manager @ Hailey Import Service
2012 S60 T6 R-Design w/ Polestar Tune
1997 960 Wagon
https://nordcarolina.com/
Moyni is offline   Reply With Quote
Old 07-08-2020, 07:33 PM   #248
RichGT
RichGT's Avatar
Need those headlight surrounds! Doesn't look bad. Warsaw 1, Chesapeake 0
Old 07-09-2020, 04:23 PM   #249
Moyni
Moyni's Avatar
Oh its bad. The entire underside of the car is straight up RUST. Not a little, but like "wow this car is barely safe to move" bad.
Old 07-09-2020, 08:36 PM   #250
RichGT
RichGT's Avatar
so what was the point in shipping to Polska?
