Old 10-11-2019, 10:21 PM   #1
Redheaded sailor bum
Redheaded sailor bum's Avatar
Default Rough idle? 940
So I just cleaned the MAF and still has a rough idle I'm not sure if it could be a vacuum leak be cause most of the vaccum ports have been capped
It starts and runs great no problems there but at idle it'll only itll flutter up and down and run rough along with if I go from high boost and I put the clutch in to either coast or putting it in neutral itll drop down and the engine will stall
Any ideas?
Redheaded sailor bum is offline   Reply With Quote
Old 10-12-2019, 11:51 AM   #2
shoestring
shoestring's Avatar
Is it a rough idle or is the idle "hunting"?
Old 10-12-2019, 03:16 PM   #3
More hunting it is either 600 or 1000 idle but the engine shakes a little not like a a misfire but more like a caammed feel I guess
It also doesnt have a o2 sensor but I doubt that's the issue
It has a megnaflow cat and muffler as well
Old 10-12-2019, 03:18 PM   #4
Like I said it runs and drives just fine but doesnt run smooth
Old 10-14-2019, 11:48 AM   #5
J_pelchy
Turd Blow Bricks
J_pelchy's Avatar
Having what sounds like the same issue with mine and can't figure it out for the life of me. I feel like we've gone through anything it could be and it hasn't always done it.
Compression is good, tried different MAFs, different injectors, changed crusty vacuum lines, checked plugs and wires and swapped dizzy all without luck.
Flint, Mi
*Volvo Enthusiasts of Michigan*
Instagram // 810_volvos
Feedback
J_pelchy is offline   Reply With Quote
Old 10-14-2019, 01:27 PM   #6
iHateVolvoPeople
Clean the inevitably filthy throttle plate and throttle body, and check IAC motor for functionality. I have cleaned them with a solvent/lubricant with good luck.
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
Old 10-14-2019, 02:30 PM   #7
2manyturbos
The O2 sensor is a critical part in maintaining the correct fuel/air mixture, yet, you doubt that could be the issue. Think again.
Old 10-14-2019, 04:23 PM   #8
iHateVolvoPeople
Yeah I missed this. I have direct experience with this too. Some cars you can (somehow) get away with not having your narrowband hooked up. These cars are not one of them.
Old 10-15-2019, 08:48 AM   #9
hessam69
Throttle body clean #1
Replace all vacuum hoses #2
Old 10-15-2019, 12:02 PM   #10
Step 1: fix all hack work.
Old 10-18-2019, 02:02 PM   #11
Ahaha wish it was that simple
It's just a track car for drifting if it's the 02 sensor I'm not worried to much about it I'm gonna try and clean the iac and throttle if that doesnt work then I'm gonna gonna assume it's an 02
Old 10-18-2019, 03:02 PM   #12
iHateVolvoPeople
Why not just connect the o2 sensor? Itís literally 3 wires man.
Old 10-18-2019, 04:06 PM   #13
redblockpowered
redblockpowered's Avatar
With such an obvious defect in your system you're wasting your time chasing this issue. The oxygen sensor is effectively the building block of LH 2.4.
1991 245 B230FNA/M47 no thread: secret LeMons car technology abounds
1991 245 B230F/M47 no thread: very boring (320k!)
redblockpowered is online now   Reply With Quote
Old 10-21-2019, 09:06 PM   #14
You're absolutely right my biggest problem is pretty much just waiting to find one at a scrap yard and not wanting to pay the 60$ for a new one on rockauto
Old 10-21-2019, 09:16 PM   #15
iHateVolvoPeople
Get a universal NTK and wire it up or just pull a used one one from the JY. Pretty sure Iíve been using a universal on at least one of my LH2.4 cars for a few years without issue.
Old 10-21-2019, 09:38 PM   #16
I'll probably hold off for another paycheck and if they land one there in my year range I'll nab it
I have credit at my local pick n pull and money's just tight band all they have is 99 and up mines a 91 so they wont match but i might know where another 240 wagon at a scrap yard a little ways out I might run by on my day off cause I still need to get a dome light
Old 10-21-2019, 09:38 PM   #17
Never thought about nabbing a universal one though not sure on my connector situation though
Old 10-22-2019, 01:08 AM   #18
iHateVolvoPeople
I mean honestly probably any 3 wire will work from just about any car. Unless it’s one of those weird ones like Regina cars. Those operate at higher voltage I think.
Old 10-24-2019, 04:46 PM   #19
So I snagged a o2 sensor and the things was practically brand new
And still have the hunting idle
So I cleaned throttle body and the iac
Still have the issue you can still feel the engine running rough the idle spikes between 750-900 bouncing slowly
Old 10-24-2019, 05:04 PM   #20
shoestring
shoestring's Avatar
Did you check to make sure the throttle blade was properly seated in the throttle bore when you had the throttle body off? When Cam got his 940 it had a constant incorrect idle issue until we reset the throttle blade. Since then, mint.
Old 10-24-2019, 05:38 PM   #21
lummert
lummert's Avatar
No O2 sensor? How is that working out? Running in open loop only? Never running in closed loop?
Old 10-24-2019, 05:42 PM   #22
lummert
lummert's Avatar
Dome light should interchange with 88-90 760, 92-94 960, maybe even 95+ 960/S90/V90. I installed a dome light from a 92 960 in my 88 765.
Old 10-24-2019, 05:55 PM   #23
Fa182
Stage 1
Fa182's Avatar
Check the intake manifold gasket. Those can get hard and crack, which leads to a vacuum leak.
Mine crumbled apart when I changed it.
Old 10-27-2019, 02:30 PM   #24
Just an update
Figured out the issue
It was the #2 spark plug not sure how but it loosed up and was making me lose compression I guess
Never seen anything like that before but thanks for the help guys
