Old 02-16-2021, 12:54 PM   #1
StuSims
Question m46 P-Type Laycock OD slippage??
Hey all, Ive been having some mechanical gremlins plague my m46 transmission on my 1986 740 Turbo. One day I did a burnout at my house, and it worked no problem. Two weeks later after sitting since the last burnout, I decided to do another burnout to celebrate my birthday. There was a lot of noise and no spin, I had assumed I fried the clutch! It was still able to drive, but only very slowly with low throttle input (and for some reason, reverse worked like normal). Any more than 40% throttle, the car would rev up and not go anywhere. I replaced the clutch with a brand new Sachs clutch kit, and re surfaced the flywheel. The problem persists. . ive been told it is the cone clutches in the m46 OD unit? This would explain why reverse works fine, with the unidirectional sprag clutch. But after talking to a few transmission techs who are familiar with the Laycock OD system, they find it quite odd that all my forward gears are slipping. They think that a worn out cone clutch in the OD would only cause slipping in 5th gear. So, I have come to the all mighty TurboBricks for an explanation. Is anyone experienced with the Laycock overdrive systems in these cars? is my problem due to the cone clutch? Or did I pop an O-ring on one of the hydraulic pistons? Perhaps the internals of my trans have decided to run away? In search of a better life. Any help is appreciated.
StuSims is offline   Reply With Quote
Old 02-16-2021, 01:30 PM   #2
The Librarian
The unidirectional clutch transmits all the power in 1st-4th. The cone clutch inner surface is for reverse and engine braking. The outer surface is strictly for over drive. You either broke the unidirectional clutch or broke/stripped the splines on the main shaft.
Old 02-16-2021, 06:06 PM   #3
tintintin
^+1^
That wouldn't cause this problem, as those pistons convert the hydraulic pressure to engage OD only.
Old 02-16-2021, 10:40 PM   #4
StuSims
Alright thanks guys! Anyone know if the P and J type OD units are interchangeable? My car is a 86 turbo so I’d assume it’s a P type. A buddy of mine has a J type. Could I swap some parts over to make vroom vroom??
Old 02-16-2021, 11:14 PM   #5
The Librarian
I believe the P type main shaft is larger so you can't mix and match.
The P type is supposed to be stronger than the J so I find it curious that yours broke. Your car should have come with a P type but it may have been swapped with a J type in the past.
