Old 11-09-2020, 02:15 PM   #51
Lankku
Lankku's Avatar
Originally Posted by dalek View Post
Is that the GS6-37DZ?
GS6-37DZ is generally said to hold up to 700Nm. Might be even more depending on the use. GS6-53DZ over 1000Nm. I've had around 950Nm with a 53DZ.
245 -90 "B6284T"
Old 02-13-2021, 12:55 AM   #52
dalek
Benchracer Tribe
dalek's Avatar
Good to know; https://en.wikipedia.org/wiki/ZF_S6-37_transmission claims it can only handle 370NM which is pretty close to T5 territory.
Feedback!
Old 02-13-2021, 10:27 AM   #53
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
BMW 7 speed DCT. will hold 800 NM factory clutches. adapter plates available via domiworks, and for ease of electronics, use factory shifter and run the engine on maxxecu, it will control the DCT no questions asked. guibo and mounting the same as getrag 6 speed. recommended convert to drive by wire (easy) for downshifts.
Old 02-16-2021, 01:43 PM   #54
cwdodson88
looks like tremec is offering up a TKX. 5 speed manual synchro box, 600ftlb rated and RPM good up to 7500. Biggest plus is that it comes in smaller than the tko500/600 and has higher rev ranges than the old TKO.
The Build Thread
SVEA - PUSHROD TURBO!
Old 02-16-2021, 01:53 PM   #55
I saw that, I am pretty interested. A slightly more compact, more easy shifting, tkx could be a really nice match for a redblock.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 02-16-2021, 02:05 PM   #56
cwdodson88
I'm just about to pull the trigger. My t5 is tired... I went through it, billet cluster support, bells, whistles, upgraded g-force main shaft, then ended up twisting the 1-2 selector spline far enough that I couldnt get back into first. Tore it apart, and the internal splines on the selector looked ok, but the external ones on the main shaft were twisted about 1/4 tooth. enough that the selector wouldnt slide over. I've filed it down so it works, but it aint gonna work for long.
Old 02-16-2021, 02:25 PM   #57
Stiggy Pop
Stiggy Pop's Avatar
that close ratio gear set is tasty
'79 242
943 pickup
Old 02-16-2021, 02:36 PM   #58
I need to restock my TKO adapters now that the makino is up and cutting.
Old 02-16-2021, 03:03 PM   #59
vwbusman66
Stößelstange über alles
vwbusman66's Avatar
Yes.
Dumb question.
Does the TKO have the same pattern as the T5?
1971 142 beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 02-16-2021, 03:30 PM   #60
Stiggy Pop
Stiggy Pop's Avatar
Originally Posted by vwbusman66 View Post
Yes.
Dumb question.
no such luck
Old 02-16-2021, 04:05 PM   #61
cwdodson88
what all is involved in the TKO adapter as far as bellhousing machining? just opening up the bore?
Old 02-16-2021, 04:26 PM   #62
volvowagoon
volvowagoon's Avatar
Yes.
Dumb question.
Unfortunately, the TKO/TKX has a wide pattern unlike the T5. I'm hoping to get one of these transmission within the next couple months. I just haven't figured out how to spec an HTOB for my application. The fork is a no go.
1986 Buick Grand National - Restoring to stock™
2010 C30 T5 - The boring but trusty daily
1989 245 DL - The boring but not trusty daily
IG: @v6buick
Old 02-17-2021, 05:41 PM   #63
yes, there are pictures on my website of the bell housing post machining.
