Old 02-11-2021, 06:44 PM   #1
DavePolyakov
Default how to plug holes drilled in cat
The previous owner drilled 4 holes in the catalytic converter. When idling you can really smell the unfiltered exhaust coming through the shifter hole. What should I use to try to plug it? Any advice is welcome, thanks in advance
Old 02-11-2021, 06:58 PM   #2
Pay an exhaust shop to weld it back up.
Old 02-11-2021, 07:02 PM   #3
carver
Redblock for life.
carver's Avatar
If you still have the stock exhaust I have a NIB 740/940 cat I'll sell you for $100. (Bosal Brand)
Old 02-11-2021, 07:15 PM   #4
spock345
spock345's Avatar
Why would someone drill holes in the catalytic converter?
1967 122s, B20F, M40
Old 02-11-2021, 08:13 PM   #5
Khrrck
Professional Amateur
Maybe it was plugged and they added holes to let the exhaust out?
Could also have been trying to beat smog. When my exhaust had a hole in it pre-cat I got some unbelievably good numbers at the smog station. It's been fixed since.
'87 240 budget wagon.
Old 02-11-2021, 09:43 PM   #6
DavePolyakov
This seems like the most cost-effective route. They probably won't charge more than $25ish?
Old 02-11-2021, 10:49 PM   #7
If you know what they like to drink and grease the wheels a bit.
Old 02-11-2021, 10:53 PM   #8
HiSPL
HiSPL's Avatar
Weld it.
Or JB Weld if you're Tbricks cheap....
Beets taste like buttfeet.
88 244
06 XC90 V8
03 V70
Old 02-12-2021, 12:49 AM   #9
DavePolyakov
Now I'm also kinda worried it might actually be clogged. Why else would someone do this lol. I don't want to pay for it to get welded and then have it run like absolute crap and have to buy a new one. I don't hear any noises and plenty of exhaust still comes out the tailpipe. Is it probably in ok shape?
Old 02-12-2021, 12:56 AM   #10
carver
Redblock for life.
carver's Avatar
At least they didn't drill into the core....
Old 02-12-2021, 01:14 AM   #11
spock345
spock345's Avatar
That isn't as bad as I thought. For some reason I pictured big half inch holes.
The easy answer is to weld it shut with a cheap harbor freight flux core machine. Then realize you can't seam seal and paint away the **** welds and then go buy another cat.
Also what is the temperature limit for JB weld?
Old 02-12-2021, 01:18 AM   #12
Temporary and TBcheap would be 4x stubby fat sheet metal screws
Old 02-12-2021, 09:45 AM   #13
nel621
Do this first to see if it runs ok. You can always have it welded later.
Old 02-12-2021, 01:07 PM   #14
Khrrck
Oh wait, that's perfect. Put a fat blob of exhaust sealant over the hole, then screw in the appropriate sized screw. <$10.
Old 02-20-2021, 08:12 AM   #15
dalek
Benchracer Tribe
dalek's Avatar
If you are willing to disassemble that joint, run the largest bolt you can from inside out through each hole and then seriously crank down from the outside a nut with a washer made of softer material (Chinesium? Cheap exhaust gasket?) to help seal.
I would suggest this only if the metal screw approach (do add cheap gasket in between) does not work out for you and cat is not clogged with porn.
Some people sniff paint. Others glue.
Feedback!
Old 02-22-2021, 07:58 PM   #16
I've got an even easier way to find out if it's clogged and it will cover the holes. Buy some of the stainless steel metal tape from a good heating supply place. We have one in our area called Ferguson. Wrap the pipe with the tape to seal it up and find out if the cat is clogged. They do have the internal substrate fall apart or get filled with carbon. They can break loose internally and cause a lame exhaust rattle.
