#51 |
#52 |
![]() I'm thinking about drawing one up right now. For what size of gauge? 52mm?
EDIT: I'm drawing the 3D model now, I'm assuming you mean for the lefthand vent on the drivers side. It looks like that slot is more suited for a 38.1mm gauge, if that's acceptable, there doesnt seem to be a reasonable way to fit a 52, and still have it "drop in". EDIT: I found a way and it looks pretty damn good. Last edited by aaronllewellyn; 12-13-2015 at 07:44 AM.. |
#53 |
#54 |
Amateur hour!
![]() Nathan already makes a 4-gauge pod for the center vent section. Maybe just a small one for the drivers side gauge.
#55 |
![]() Oh this is awesome.
Now where is our top dash 240 gauge pod ![]() ![]() |
#56 |
#57 |
![]() If you managed to fit a 52mm with your metal plate god bless you, but I cant for the life of me fit a 52mm gauge and keep it "drop in" like using the factory metal clips which is what I'm doing, I'm making a 38.1mm one right now and but I'll definitely see what I can do about 52's, I have a drop in solution in mind but I'm going to print off a 38.1mm as a prototype to test fitment, I'm printing two so somebody may get lucky if I'm feeling generous.
![]() Last edited by aaronllewellyn; 12-12-2015 at 07:35 PM.. |
#58 |
![]() ![]() They're not a finished product but in 8 hours we'll see what I end up with ![]() Last edited by aaronllewellyn; 12-12-2015 at 08:20 PM.. |
#59 |
![]() When I open the driver door from the inside of my 240, what's the plastic piece called that sits behind the handle? Mine is cracked on the drivers side, and the one on the passenger side was so broken I just removed it. I think this piece could be made on one of those machines.
#60 |
![]() Post a picture if you can.
#61 |
![]() http://www.vlvworld.com/photo_pieces/z24doorcolor.jpg
Part number 6 on that picture. I think it's called a door handle casing. |
#62 | |
![]() Quote:
#63 |
![]() True probably would cost you much more than a used one and it wouldn't match.
#64 |
![]() Here's a vent-gauge pod update. I had to use a phone without a flash to take this one so it's pretty crappy. But it's nearing completion and I will update you guys fully in the morning, tomorrow I'm making the 52mm ones so look forward to it. these ones are 38.1mm as a test (or if anyone wants one) either way I'll see how they fit in the morning. So far they are FAR stronger than the factory vent plastic, and a familiar color
#65 | |
F*ck Edgar
![]() Neat.
I might start drawing up a dash top pod. Luckily, the gauge bezel is already done, so I can just snag that design and clone it a couple times. The rest shouldn't be too hard. Printing it would be a challenge though.
K-Jet to Megasquirt Article The Departed: 1981 245, 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855, 2004 V70R |
#66 |
![]() Do you mean a 3 gauge pod that's dash mounted? if the face could be printed flat it would cut down on print time although anythings possible if you want to use support structures. My girlfriend just left for work so I just got up and made the 52mm vent gauge pod, The overall dimensions of the first prints were perfect , I made some size adjustments to the face of it and I'm printing it out now. propav8r I dont want to upload it to thingiverse for the world but I will gladly share the .stl with you if you would like one assuming I can reserve the right to sell them (these single gauge vent pods) myself, which is what I plan on doing.
#67 |
![]() OK guys, this is the final design, once it's done printing the first one I'll run out and make sure it fits correctly with a 52mm gauge mounted in it.
![]() ![]() It can be mounted with a small piece of normal strength double sided tape or you can use one or both of the factory metal clips after bending the barbs in so they do NOT dig into the walls of the vent hole. If you install it with the barbs unbent you will NOT be able to remove the pod, probably ever, so please be aware of that. I'll post in the FS section later today once everything's finalized and I have enough light to take good pictures. EDIT: you can probably get away with bending the barbs in nearly completely but leaving the tiniest amount to bite the walls of the vent if you want a more solid hold, but using both clips with the barbs bent down allows easy removal if you want/need to. Last edited by aaronllewellyn; 12-13-2015 at 08:37 AM.. |
#68 |
Double Dutch
Flying Dutchman - Build and goodies thread ;P ======================================= Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition B230-FK Turbo - 90+ ported - 15G Ported - Airintake Erland Cox Regrind - Blabla Chips - 3 inch exhaust MBC on 0.95 - Wasted Spark - Sponsored by my wife ======================================= |
#69 |
#70 |
![]() Was someone printing 240 defroster vents?
'90 245 340k mile DD '79 242DL '02 Trans Am WS6-Konis+Stranos, full exhaust, 353rwhp/373rwtq, Fikse FM5 '76 BMW R75/6 |
#71 |
Family's fleet manager
![]() Found these the other day when i was searching on speaker brackets.
Volvo 240 armrest cupholder https://www.thingiverse.com/thing:3304639 Speaker mounting bracket: https://www.thingiverse.com/thing:3309900 I dont have a.printer.....yet
Feedback thread: https://forums.turbobricks.com/showthread.php?t=353892 91 245 re-christened “The Mistress” 012021 93 244 "Lars" 92 245 "Astrid" Past 88 245 "Margit" sold 93 244 completely disassembled - It died, so many of its parts could help others live. 97 855 T5 97 855 NA |
#72 |
Stage 1
![]() I remember someone on here advertising his new website with 3D printed parts a few months back and the dash top defrost vents were amongst them.
I just can't for the life of me find the thread here. EDIT: Just found it! https://forums.turbobricks.com/showthread.php?t=357667 or https://printbrick.com/
#73 | |
![]() Quote:
Click below: Buyer/Seller Feedback My Volvo parts for sale on eBay Volvo parts for sale on forum - Post are regularly updated |
#74 |
Double Dutch
![]() Hi, I`ve designed and 3D printed a "Piston install jig" fo easy installing your pistons with piston rings in to your engine.
The tool is tapered so the top is wider then the bottom. In this way you can easily fit the piston rings, slide it down and drop it in the bore. Tested it and works great. The "bubbles" on top are for easily recognizing the top of the jig ![]() Here we go, pictures are self explaining: ![]() ![]() ![]() ![]() ![]() And an other piece of 3D that I`ve drawed lately, cuz the speaker caps are mostly gone... The supports are different left and right and are trapezoid shaped so keep that in mind. ![]() |
#75 |
![]() So if i wanted to be able to get into this. Anyone wanna recommend a printer that could do most of the things in this thread.
