unbalanced chemical
![]() Join Date: Jun 2002
![]() Ok so lets just say that as I am making more power I am starting to rethink my tranmission.
Currently power is around 400+bhp at the engine and as I am working on a few more minor upgrade (GT3582R and new exhaust header) I plan on the car making a bit more power in the future. In doing so I am starting to tire of my 200R4 in the car. Besides the entire annoyance of the kickdown cable and the NIW intake manifold, Nevermind the way that the transmission shifts under light throttle input (boost runs away) I am just not happy with it anymore. While I love the smoothness of the autotrans when under full load I just have to many little issues with it (the entire GM transmissions loving to leak fluid). I am looking for the next options for these kind of power levels. While I do happen to have a CD009 adapter setup here (this is my number 1 option) as I know it will hold the power and manually shifting that kind of power just sounds fun. I know I could go with say a built Th400 to ditch the kickdown I feel like I wouldn't enjoy the car as much as I love the ratios's (4th gear) on the 200r4 as the car is still a daily driver in winter so I enjoy being able to use it on the highway. So saying that I would think that my next options if I wanted to stay Auto would be a 4l60e (not know for holding HP) or a 4l80e (5spd auto might be nice) these are computer controlled tranmissions and add an extra layer of effort. The car does have a MS II setup so if there are options to control one of these tranmissions with MS then I would be interested to hear. So there is my rant for today, what other tranmission options do I have for this kind of power level while still being able to enjoy the car on the higway? CD009 or maybe a 4l80e? |
Salaminizer
![]() 700R4 can take it, the 500hp Grand National I posted in OT has been running that for years. The shop car (Twin turbo Grand National) ran a bunch of flat 10s on 200R4 with a noob driver, and it was a daily driver.
Feedback thread https://forums.tbforums.com/showthread.php?t=144924 1978 242, 5.3 L33 1979 242, MS, R brakes 2006 V50 T5 AWD @ 17 PSI |
![]() I'd say CD009 with a 3.31 final drive. That's what I'm going for but I'm also swapping a B6284t thereso it's a little different than your setup.
![]() 1990, Volvo 740 16v +T 1991, Volvo 745T 16V - crushed build thread: http://forums.turbobricks.com/showthread.php?t=249553 |
#4 |
unbalanced chemical
![]() Does the 700r4 have good options for ditching the TV cable? I need to talk to a local trans builder here to see if there is a good option for losing it on my current setup. My current trans also has a manual trans brake. While great for drag racing is also a huge problem as my 1-2 shift is around 5500rpm. Stupid v6turbo.
#5 |
![]() This would control a 60e/80e and allow you to ditch the kickdown cable. No clue how well it works though.
https://www.efisource.com/wp/shop/4l...-control-unit/ |
#6 |
![]() I believe to loose the TV cable on a 200r4 or 700r4 you have to install a full manual valve body
#7 |
![]() There are full-manual kits for the 4l60/4l80, IIRC. No computer required. This one is DIY.
https://atracom.blob.core.windows.ne.../2015_3_32.pdf A basic 'Poi-shift' box could also control the transmission, IMO. It would be full manual then, but you'd need a way to switch the gears.
1984 244/ AQ140A / M46 |
#8 |
![]() Join Date: Jun 2003
![]() 80e with an extra microsquirt box to control the trans linked to the main ecu via can.
#9 |
Hunting for a turbo
![]() Join Date: Dec 2003
![]() What about a TKO600? They seem like they will take the abuse, but don't like RPM past 6k...
One Volvo left. 1982 244ti (313chp), 2020 Nissan Leaf daily driver, 2016 Kawasaki 650R (76chp) |
#10 |
![]() This would be my first option if the trans is well supported.
I don't know who I am when I am somebody else. |
#11 |
k-jet groupie
![]() Do a built 4L60E with a stand alone controller. The 4L60 is just a 700R4 with no tv and electronically shifted. A 4L80 is always a better option and can take around 800 ft/lb stock but its alot of transmission to put behind a 4 cylinder.
The 80E is simply a TH400 with overdrive, has a really tall first gear and only came in 3/4-1 ton trucks and is very heavy. The 60E has a much more performance oriented gear spread and came in everything from vettes to Holdens etc. But anything much over 6-700hp the 80E makes more sense.
82' 242t 16v-Every mod known to man kind 72' 162E-B30 (no the 2 isn't a typo) 83’ kjet with 245 attached 98’ s70x2 95' s10 awd LS 1000+club VFBG Last edited by 242Bleek; 09-28-2019 at 09:08 AM.. |
#12 | |
![]() Quote:
1991 Regina 745. Dead. 1993 945 dead 1988 244 |
#13 |
They see me trollin'
![]() I run the EFI source pnp microsquirt kit for the 4l80. 4 wires to hook up (power, ground, and 2 CAN lines). Aside from setting the tire size in the TCU, I haven’t touched it in 3 years. About as easy as it gets for a tcu controlled transmission.
'88 245 - 2JZGTE VVTi | MS3X ECU, MS2 TCU | GT3582R-HTA | Staged simultaneous dual fuel | 590whp 580ftlbs 1968 Furd Rustang fastberk | 2JZGTE VVTi | MS3X ECU | PT6776S | 4L80e Microsquirt TCU Sloppy Transbrake | 3.73 8.8" rear end 1981 Piper Cherokee Archer II | All stock |
#14 | |
k-jet groupie
![]() Quote:
I think in a Volvo thats what 3500 lbs? With a 4 cyl that has a progressive torque curve you would be surprised how well a stock 60E or 70E would do in that application. The V8's are brutal on them. |
#15 | |
![]() Quote:
#16 | |
![]() Quote:
#17 |
![]() Join Date: Jul 2009
![]() I second this, my micro controlled 80e has been great. I think the micro kit is like 450 bucks. Really hard to beat. If youre still going to drag race it, no reason to make it slower and swap in a stick
1974 AMC Gremlin, lq4, 7875 billet, ss2 cam, 80e, 3600 stall converter, Holley Terminator x 1984 Volvo 245 1995 Porsche 993 2013 VW Passat TDI |
#18 | |
Prius Owner
![]() Join Date: Jul 2008
![]() Quote:
93 245 LS Engine Swap Project |
#19 | |
![]() Quote:
#20 |
Prius Owner
![]() Coming from some one with no real long term experience with one in his car, I don't believe that statement one bit.
#21 |
![]() Got 10 bucks on that 60e ****ting the bed within 6 months of the first drive with the blower
#22 |
![]() I mean how much bigger does everyone think a 4L80E is? He's already got a GM auto trans in there, it's really not much bigger.
1985 740GLE sedan winter beater Cali car. |
#23 |
![]() my 2 cents:
my 700r4 had 250k on it before I put a shift kit, boost valve and corvette servo in it, have put 25+psi from a t04e and a 75 shot on it for a while now and it still shifts perfect. Just took it to the track again this last saturday and its still going strong. my "built" 60e behind a completely stock 4.8 with twin 52s has been trying to give me 4 neutrals since day 1 and on the gate it probably doesn't make much more power than my redblock |
#24 |
#25 |
![]() Join Date: May 2004
![]() There are a lot of 4l60 Sloppy Mechanics memes.
