Old 01-26-2021, 11:03 PM   #1
tog244
Default cutting IPD lowering springs 240
does anyone know how many coils you can cut off of ipd lowering springs with bilstein b6 shocks before you have to worry about the spring popping out of its seat? i cut stock springs on stock shocks awhile ago and the hose clamps holding the bottom of the spring to the strut tube made me fail inspection. I want to go lower with my springs and struts but not so low that i cant pass inspection in a year
tog244 is offline   Reply With Quote
Old 01-28-2021, 09:33 AM   #2
volvowagoon
volvowagoon's Avatar
You can't cut any coils without that problem. Notice how the tops and bottoms of the springs have a nice flat so that they can key into the seat? Once you get rid of that, all bets are off. Coil overs, uncut springs, or sketchy junk. The choice is yours.
1986 Buick Grand National - Restoring to stock™
2002 Camaro V6 T5 +T - The trashy car that's fun to drive
2010 C30 T5 - The boring but trusty daily
1989 245 DL - The boring but not trusty daily
IG: @v6buick
Old 01-28-2021, 02:29 PM   #3
Sure he can. Just move the bottom perch up!
Old 01-28-2021, 02:37 PM   #4
Cut them right in half, sell the other halves and profit again.
Old 01-28-2021, 03:39 PM   #5
tog244
funny guy
Old 02-03-2021, 06:28 PM   #6
quillc
yv1a.com
quillc's Avatar
you might get away with ~1 - 1.5 turns. there isn't a lot of compression in the IPD springs as it is. If you are wanting low and adjustable, a set of Ben's coil over conversion struts are the way to go.
Chris
www.yv1a.com
Old 02-03-2021, 07:11 PM   #7
Jack
junkman
Jack's Avatar
You really think he can afford that
I love you even more Jack.
Old 02-03-2021, 07:45 PM   #8
Texas240
Prius Owner
Texas240's Avatar
I wouldn't. Just buy length specific coils from speedways motors or from Ben.
93 245 LS Engine Swap Project
Old 02-03-2021, 11:55 PM   #9
quillc
yv1a.com
quillc's Avatar
Isn't that what stimulus checks are for?
Old 02-04-2021, 12:10 AM   #10
Jack
junkman
Jack's Avatar
Any day now
Old 02-04-2021, 04:34 AM   #11
Fa182
Stage 1
Fa182's Avatar
Honestly best advice in here so far.
Old 02-08-2021, 02:58 PM   #12
MikeSr.
What, me worry?
MikeSr.'s Avatar
I have cut 1.5 coils off of IPD coils on several 240’s- gives an even stance. Coils will be loose at full droop, but seat on compression.
I coulda had a V8!
Old 02-10-2021, 01:04 PM   #13
badvlvo
Bad for Babies
badvlvo's Avatar
I've done the same. Rear lower are held in place by the retainer, fronts didn't unseat, just unloaded. It made the car sit properly, and it handled well. I replaced them down the road when I went to a higher rate spring, but there's nothing wrong with adjusting your coil length a bit.
Died at age 35
