![]() Does anyone have on their car, or pictures available of a 240 with flat undertray panels? I know, "it's a flat sheet", but curious if anyone with some experience did anything interesting I can draw ideas from. Not finding much with the goog.
I'm looking to increase high speed stability without adding any heavy visual aerodynamics, I thought this might be a place to start. Would have to figure out appropriate rear treatment without going all time-attack diffuser. Also thought rather than dealing with a bunch of sharp aluminum, maybe I could make panels out of kydex and hang them with something like a dzus fastener for easy removal. this kinda thing ![]() |
![]() Kydex or poly would be simplest and similar to the ABS used by many OEMs for the same purpose.
IMO it seems unlikely to solve a problem, though. Assume you've looked at tires, alignment, bushings, tie rods, rake, and the like? |
#3 | |
![]() Quote:
Edit: Think my last alignment was ~ -2° camber, +4° caster, and ~1/8” toe in. Tires are Dunlop zii Last edited by Stiggy Pop; 01-30-2021 at 10:05 PM.. |
#4 |
Single jingle
![]() Why not go full time-attack diffuser?
I googled kydex and it said "Maximum recommended service temperature is approx. 180 – 195°F" so you'd probably have to figure something out around the exhaust. Hater pipe out the hood, maybe?
I don't know what I have |
#5 |
Burnt Sierra Madre
![]() why and where you drivin130
#6 |
![]() With the exhaust and driveline I’d probably have to run two panels down the floors and leave the tunnel open. Then try to box out behind the axle/around the tank.
#7 |
#8 |
Dann sind wir Helden
![]() I just replaced my bensin tank, I was looking at that big hole where the rear muffler used to be end was trying to figure out some kind of diffuser to stick in there to make some down force.
"i will destroy all of you!" -Sheldon Plankton Booty Scooty https://youtu.be/i4oAOZ8nbq4 |
#9 |
Single jingle
![]() My car certainly doesn't feel stable above 120mph or so but I kinda just uhh, go with it. Adds a little extra sense of fun. Or danger. I can't tell.
#10 |
![]() I don't have anything to offer, but I'm going to follow this to see where it goes. Twitchy in the front or rear? Are you looking to do full undertray? Do you want to retrofit some OE piece or fab your own?
#11 |
![]() The rear lift is very apparent on gravel over about 70mph.
The rally car uses a 4x8 sheet of LDPE split down the middle to keep the tunnel free. No issues with melting at all. The flaps extended to just a foot or so in front of the rear axle. With your car being low, could a flat panel go from the floor to the gas tank without fouling on the rear axle?
#12 |
![]() This guy on YouTube has couple of videos about making them. There might be better.
https://youtu.be/L9WCVlWPcys |
#13 |
![]() Check Lankku and his 245.
#14 | |
junkman
![]() Look at hypermileing 240s on google. There’s been a few.
Aero stuff makes a difference above 30 mph the way the panels fit makes a huge difference. Your biggest gains will come from under the engine and smoothing out area behind the axle Also the less holes in front of car the better ... ie gaps between headlights and turn signals (Look at a 240 vs 850 and then look up their drag coefficient all little things add up) When you start modifying for aero your car will loose a lot of wind noise One of the worse things on early cars are the roof drains. Here’s some simple equations for aero stuff. Found this at my old school F1 engine builders shop https://imgur.com/a/vwO72Yy?s=sms
85 245 | 82 242| 75 245| 69 145 |66 122| 67 220 ![]() Quote:
#15 | ||
![]() Quote:
- I thought I'd try to make something from the front lip down the actual floors, then make a tray behind the axle/covering the tank. - I'll make my own, probably be more fun that way. Even if it doesn't help I just kinda want to do it, if nothing else it will protect my paint job on the underbody! ![]() Quote:
You'll notice I only make threads like these in the winter time, when it's single-digit weather here and I'm stuck inside lazy and bored looking for ideas. thanks for the suggestion. Found pics of a front tray he made. Looks like he's got a low lip on the car. ![]() |
#16 | |
![]() Quote:
#17 | |
junkman
![]() Quote:
Oem ones have more round corners where the ipd one has sharp corners and then a stupid logo hole. Adds noise and turbulence I’m working on a few small aero stuff on my 850 but will be moving on to my 240 at some point The hyper mile crowd tends to just stick stuff on without worrying about accessing anything... to me that’s the challenge, you can “easily” cover the underbody but making it easily removable and not cobbled together is the hard part. The older the vehicle design the harder it gets |
#18 | |
![]() Quote:
Can't say it feels unstable without the lip up to 156mph(250km/h). Gradual turn on a local track on WOT ~130mph isn't a problem. And with 215/225 semi slicks.
444 -55, 242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -92 B6294, 245 -90 "B6284T" |
#19 | |
![]() Quote:
#20 |
Aero challenged
![]() On a very remote road, with a two mile line of sight, we saw 110 before I backed off. It was getting “uncomfortable.” I’d sure like to tighten things up.
![]() @PDXvolvo on IG |
#21 |
junkman
#22 |
![]() Join Date: May 2007
![]() Subbed. More to shut it up at high speeds but reducing ass end lift would also be good.
#23 |
![]() ![]() ![]() It's not that low, around the same level as crossmember. The rideheight overall means that the lip does scrape sometimes. Doesn't limit where I drive though. Last edited by Lankku; 02-01-2021 at 07:22 PM.. |
#24 |
Aero challenged
![]() Dayuum.
#25 |
Aero challenged
![]() ![]() ![]() Chicks dig Porsche's... ![]() |
