#26 | |
not yet good enough
![]() Quote:
#27 |
cone dodging dilettante
![]() I interpreted it as earlier car designs in general, not specifically early 240s.
1993 944 B230FT/M90 thread here: http://forums.turbobricks.com/showthread.php?t=345277 2x 1991 245 B230F/M47 (LeMons car, street car) I sell chips for LH 2.4! |
#28 |
![]() I know drip rails are great for making a bunch of wind noise on the highway..
Took a quick look under the car in storage and the exhaust/muffler is the lowest point in the rear. Might be able to pass under the axle, but not sure if its worth the effort. Probably something I'll get started in March, unfortunately. |
#29 |
![]() Never too early to start on some sweet 242 CFD modeling for your aero package.
#30 |
Aero challenged
![]() ![]() ![]() Chicks dig down-force.
![]() @PDXvolvo on IG |
#31 |
junkman
![]() This
#32 |
junkman
![]() Did you just discover bing image search ?
F40 has a drag coefficient of .34. 850r sedan is at .29 (93 sedan is .34 which shows how much a little smoothing out with the right spoilers can do) 75 244 is .47 75 245 is .45 Last edited by Jack; 02-03-2021 at 12:02 AM.. |
#33 | |
junkman
![]() Quote:
Big reason why newer cars are so quiet (not counting the tire noise) Interesting read by volvo https://www.mech.kth.se/courses/5C12...erg_2012_1.pdf Last edited by Jack; 02-03-2021 at 12:04 AM.. |
#34 |
![]() Good stuff there. I never realized how much benefit comes from lowering the car.
Stiggy Pop, do you have a rear spoiler? Assuming that the Group A cars were stable at speed, they could make a good pattern for a solution: smallish (for today) front lip and some rake to help keep air from going under the car, and a smallish (again, for today) rear spoiler to reduce lift at the back. Some input here: https://scholarcommons.scu.edu/cgi/v...text=mech_mstr |
#35 | |
![]() Quote:
![]() Looking at the bottom of the car I think the whole front 2/3 is going to be pretty straightforward. The exhaust/axle area will be fiddly. ![]() Last edited by Stiggy Pop; 02-03-2021 at 12:54 PM.. |
#36 |
![]() No need to fiddle, relocate the gas tank and open the trunk up as the Mother of All Diffusers :-)
#37 | |
Dann sind wir Helden
![]() Quote:
"i will destroy all of you!" -Sheldon Plankton Booty Scooty https://youtu.be/i4oAOZ8nbq4 |
#38 |
junkman
![]() 3 inch won’t fit over the axle.
#39 |
![]() it's 3". Not sure if it would work as well with a higher ride height, but with the short konis I can hang the axle at full droop and it doesn't interfere
#40 |
junkman
![]() My 3 inch
https://i.imgur.com/aZeWk07.jpg?s=sms If you’re going to reduce your exhaust size to go over the axle why even bother with the larger stuff |
#41 |
![]() that felt like a risky click on the work computer
#42 |
junkman
#43 | |
![]() Quote:
http://www.siliconeintakes.com/dsm-i...RoC4rQQAvD_BwE Last edited by VB242; 02-03-2021 at 02:00 PM.. |
#44 |
junkman
#45 |
![]() Join Date: May 2007
![]() Mike, going over axle will make your life a lot easier.
#46 |
not yet good enough
![]() Time to tuck that exhaust up over the axle!
3" fits over axle, you just have to be careful. I just did it in my reasonably low 242 and so have quite a few others. ![]() I could have tucked mine closer to the body for more clearance. I would just take your time to get it pretty close and you'll be fine. |
#47 |
![]() ehhh not sure if the juice is worth the squeeze on that one. I'd have to relocate the muffler, then I'm most of the way to building a new system from the DP back, and there's really no other driving forces so it's tacking a lot of cost and complexity onto a "for fun" project.
I'm slow rolling another project involving computer models, custom end tanks and welding so I want to keep this one simple-ish ![]() |
#48 |
![]() If you plan on doing a true front mount intercooler, I'm interested in that too, lol
#49 | |
All idiot, no savant
![]() Quote:
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months) dd: 940 | 1992 | B230FB Husaberg FE450 70 degree '12 mx/supermoto swapped |
#50 |
![]() The JT with 2 mufflers is what I have too. Very easy to fit. Wish it was 409 SS but for the convenience I can't complain. Center muffler mounts to seem to transmit a lot of vibration from the engine with stiff motor mounts. It's a bit loud at idle but mostly great for the price.
