Old 02-04-2021, 03:22 PM   #1
rearwheelpeel
rearwheelpeel's Avatar
Default 240 Ratcheting armrest repair help
I have an early 240 ratcheting seat mounted armrest that no longer ratchets or stops where I need it to. I can’t figure out how to take it apart or if I would even need to do that. It looks like I’m probably missing a spring or something inside, but I’ve never had another one to compare to. Does anyone have experience fixing one of these, or is there a blueprint I can look at that will show me what I might be missing?
rearwheelpeel is offline   Reply With Quote
Old 02-07-2021, 10:28 PM   #2
DD Ranch
DD Ranch's Avatar
Free Bump -
I have the same problem with the one in my 244, so I too would like any info to help fix it.
Florida Chapter VCOA
DD Ranch is offline   Reply With Quote
Old 02-07-2021, 10:46 PM   #3
rearwheelpeel
Does anyone have one that works like it’s supposed to, and wouldn’t mind sharing a picture of the inner mechanism like I did?
Old 02-07-2021, 10:47 PM   #4
2turbotoys
Salaminizer
2turbotoys's Avatar
Dam, I just sold mine a month ago since I decided to use my Husco armrest instead
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 02-11-2021, 12:47 PM   #5
philski o'flood
philski o'flood's Avatar
here you go
philski o'flood is offline   Reply With Quote
Old 02-11-2021, 12:56 PM   #6
rearwheelpeel
That little spring inside - what is the other end attached to?
+ thanks for the pics!
Old 02-13-2021, 12:47 AM   #7
The Librarian
I also have a ratcheting armrest missing that spring that doesn't lock. The other end of the spring appears to go into a hole in the pawl. When I push the pawl towards the pin it will lock.
Edit: Now that I think about it I'll bet there used to be a similar pin that in that hole in the pawl and the spring hooked on to it.
Unfortunately it looks like the pawl is missing on your armrest.
Old 02-13-2021, 12:58 PM   #8
rearwheelpeel
Awesome! Thanks so much for the help. Now that I know I am missing something I’ll probably never find, I may try to just rig this thing so it can swing up and down and stay in place.
