![]() Hey all. I recently finished up the turbo swap on my 92 240 wagon complete with a fresh bottom end, and t5 swap. Sense I did the swap I've had a pretty consistent rich condition (pegs the aem gauge at the minimum 8.49) and a hard shudder under acceleration. I've done a little reading and it seems I may have the incorrect maf for my setup. I have the 0280212016 maf that came off the car when it was Na. after some light reading it seems I need the 0280212007 out of a 1990s 740 turbo. Before I go and throw down some money to get one coming I figured it would be best to consults the pros and make sure the 007 maf will fix this issue.
I have the 3bar regulator and the orange injectors running around 15psi |
![]() Join Date: Oct 2004
![]() The 016 in there is correct for your car. The 007 is an LH2.2 MAF and is not correct, also will not be from a 90's anything for Volvo.
RIP Doug Williams "Mr. Doug" 4/15/2009 Pete Fluitman "fivehundred" 7/14/2013 Mick Starkey "TrickMick" 1/10/14 Mark Baldwin "blue850t5" 7/19/18 Nick Fengler "fengler" 8/6/18 Thomas Fritz "stealthfti" 10/11/18 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
Single jingle
![]() Does it run rich cold? hot? always? I'd suspect bad MAF sensor or massive boost leak first.
I don't know what I have |
#4 |
![]() I swapped out the ecu and timing box when I did the turbo swap with a 91 turbo 740. It is consistently rich. I have checked for boost leaks but haven't been able to find anything major. It seems to run a little better when the engine is cold but not much.
#5 |
#6 |
Single jingle
![]() You sure you used the right ecu? I believe the number on it should end in 563 or 937.
#7 |
Redblock for life.
![]() Did you remove the the WOT wire on the TPS? Believe it's the blue and white wire on position 3.
#8 |
#9 |
Redblock for life.
#10 |
![]() I will go give that a try and grab the number off the ecu.
#11 |
#12 |
#13 |
Single jingle
#14 |
#15 |
#16 |
![]() Did you install high-z injectors or a resistor pack?
#17 |
![]() Did you check for codes?
#18 | ||
Cretin
![]() He said it had a stock 016 amm and is a 92 so I assume lh2.4 which would have the resistor pack to match the injectors on the donor engine. Should be at least running the b230f/t green injectors.
#19 |
Stage 1
![]() The NA engines don't have a resistor pack? Unless I misread what you're saying.
#20 |
Cretin
![]() Opps' thought all lh2.4 did, my mistake.....I'll shut up now
#21 |
![]() The chugging could be spark blowout from too large of a plug gap. Check your plugs and reduce the plug gap to .026". I'd also check the engine coolant temp sensor and make sure it's working. If that sensor is open circuit or too high a resistance it can make the engine run rich all the time because the engine will never go into closed loop operation.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 430k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
#22 |
#23 | |
![]() Quote:
#24 |
#25 |
