Old 02-09-2021, 07:57 PM   #26
apachechef
Burnt Sierra Madre
follow culberro's line. If you used injectors from a turbo 740 in your car, without adding a resistor pack to your harness, you have fried injector drivers in ECU.
this will cause a rich state, very rich.
Sounds like you don't know about the difference between high res and low res injectors if you just know the color, which is not enough to tell.
don't swap in and ruin another ECU until you clear up and rule out this potential f up.
Dammit, Lummert.
Old 02-09-2021, 08:04 PM   #27
apachechef
Burnt Sierra Madre
Originally Posted by culberro View Post
Nope, but the sensor is near the gauge one. You're looking for a sensor under the intake that has an injector style connector on it. The body will be black plastic and brass.
it is possible to mistakenly swap I think the temp sensor, knock sensor, and perhaps the idle air valve and maybe cold start injector? have similar Bosch 2 wire plugs. Don't recall exact details, but check out this as a potential screw up too. the wire harness should fit as before, without "stretched" or weird routing. ultimately, check the harness colors to diagram to confirm
Old 02-09-2021, 08:21 PM   #28
culberro
culberro's Avatar
Definitely a possibility. I did that exact thing on my first lh2.4 swap
Old 02-09-2021, 08:37 PM   #29
Cwazywazy
Single jingle
Cwazywazy's Avatar
Originally Posted by abelbushey View Post
I have a set of yellow/ cream injectors.
These? Are you using a resistor pack or no?
I don't know what I have
Old 02-09-2021, 08:49 PM   #30
abelbushey
This is very informative....
Yeahhhh. When I bought the car it came with a 95 percent complete turbo swap. Those were the injectors. I believe they came off a 850 but I could be mistaken. Next time I'm by the car I will see if there is a number on them. Als
abelbushey is offline   Reply With Quote
Old 02-09-2021, 08:52 PM   #31
abelbushey
Those look like what I have except mine would be faded a bit and no I am not using a resistor pack. If I do need one, is there a link to another form that goes over it?
Old 02-09-2021, 09:07 PM   #32
apachechef
Burnt Sierra Madre
Only a moron would screw up the high-low res thing on their first swap
yeah, I've done both these f'ups
Old 02-09-2021, 09:07 PM   #33
Cwazywazy
Single jingle
Cwazywazy's Avatar
I believe those should work without a resistor pack?
Old 02-09-2021, 09:09 PM   #34
apachechef
Burnt Sierra Madre
add turbobricks to your google searches, and you will find all you need
Old 02-09-2021, 09:16 PM   #35
abelbushey
I assume if they needed a resistor pack and didn't have one the car wouldn't run at all.
Old 02-09-2021, 10:06 PM   #36
culberro
culberro's Avatar
I had the resistor pack, but I didn't label the 2-pin JPT sections of the harness. It doesn't run well when those are all mixed up.
Old 02-09-2021, 10:08 PM   #37
culberro
culberro's Avatar
It would run exactly as you have described, which is why I asked.
If you have thin plastic injectors, they are probably high-z (high resistance, around 13-15 ohms), and you probably dodged that bullet.
If they have a fat black or silver body and a plastic part on top, you may have low-z (low resistance, ~3ohms).
Old 02-10-2021, 11:55 AM   #38
shoestring
shoestring's Avatar
Originally Posted by Fa182 View Post
The NA engines don't have a resistor pack? Unless I misread what you're saying.
No they do not. The resistance is in the injector.
Old 02-10-2021, 12:11 PM   #39
shoestring
shoestring's Avatar
Is this rich condition and chugging at part throttle, WOT, etc? Do you have an exhaust leak pre O2 that's pulling a bunch of air?
Old 02-10-2021, 03:22 PM   #40
2manyturbos
I would not at all be surprised if the problem is the 560 ECU. Those are notorious for failing, resulting in all kinds of issues, including rich conditions. I have not encountered one in 15+ years because they were always replaced with a later version 939 EGR Turbo ECU. See if you can borrow a known good 939, 937, 954, 967 ECU to check whether that is the problem.
Old 02-10-2021, 04:14 PM   #41
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
I have a functional 560 sitting right here, also. Looks like it was repaired under warranty.
I sell chips for LH 2.4!
Old 02-10-2021, 04:23 PM   #42
Is this the same sensor that will send a signal to the gage?
No, it is the sensor for each computer. It is actually a dual sensor with a signal readout to the EZK computer and the LH computer.
Old 02-10-2021, 06:15 PM   #43
apachechef
Burnt Sierra Madre
seriously OP, CHECK injectors by # BEFORE Assuming they are ok, as it will ruin the ECU too if inj are wrong
Old 02-10-2021, 11:10 PM   #44
abelbushey
They are definitely the thin plastic injectors. They look nothing like the short fat ones that came off the car. I will check the resistance of the injectors next time I'm by the car.
Old 02-10-2021, 11:12 PM   #45
abelbushey
The car runs rich at every rpm. The car shutters a little under very light acceleration. At WOT it bucks/ chugs very badly and the afr gauge will max out rich.
Old 02-10-2021, 11:13 PM   #46
abelbushey
Foolish of me to assume they were correct I bought the car with a good pile of turbo parts but I never thought to check on the injector numbers.
Old 02-11-2021, 05:28 AM   #47
Fa182
Stage 1
Fa182's Avatar
Yes I know, I was just correcting what was said earlier
OP: Check resistance or number on injectors and compare with this table: http://users.erols.com/srweiss/tableifc.htm
NA 240 engines use hi-z injectors, Turbo engines use low-z (usually the black/green 0-280-150-804) with a resistor pack.
