Old 02-15-2021, 01:05 PM   #1
CooperV
Default How much boost can I run?
So I have a 1987 Volvo 760 turbo intercooler, and I know my car has the smaller rods. But I’m wondering how much boost it is safe to run until I get a engine with the bigger rods? Is 12-13 psi still safe?
CooperV is offline   Reply With Quote
Old 02-15-2021, 01:33 PM   #2
holtzboy
Still have my first car
holtzboy's Avatar
In before how PSI a stock can support.
If your car is at a good stage zero state, running healthy and you run quality premium fuel, running 13 psi *should* be safe. I would invest in getting a second o2 sensor bung welded to the lower part of your downpipe and running a wideband gauge so you can monitor your AFRs.
1. '86 244DL- 1st car & owned for 18 years, 500k miles, 94 B230FT mild build in the works
2. '93 244DL - Daughter's DD, mostly stock with Hydras
3. '07 Vette Z06 - Early mid-life crisis vehicle
4. '17 CRV - Boring DD
My feedback thread
holtzboy is offline   Reply With Quote
Old 02-15-2021, 02:20 PM   #3
240240
$600 Volvos
240240's Avatar
if your car is filthy inside with a bunch of fastfood wrappers in it stock 6lbs of boost is too much. if your grandma drove it 69k miles, then died and gave it to you then you can run 25psi on stock internals until you blow it up.
Originally Posted by churd9 View Post
He's not his policy is the liberals agenda gun control silence the media......
Originally Posted by dalek View Post
Crush it as is and then buy a 240 with rusted through floors and frame, rotted out cooling system, rat pee smell, bad wiring, Chrysler ignition, and 9mm rods. And then +T it.
Old 02-15-2021, 02:23 PM   #4
CNA Sprout
Old 02-15-2021, 03:54 PM   #5
Dicktater
Cretin
Dicktater's Avatar
plug the hose and run all the boost!
**** off loser. I will **** you up. I back up the **** I talk. I don't back down because I am not wrong. You want some? Bring it mother****er.
Originally Posted by CaliMeatWagon View Post
I hope your treehouse gets cancer
I buy a few when foodstamps get here because I have an investment strategy.....
Originally Posted by volvo740b234/531 View Post
I smoke my weed and dream of an awesome life
Feedback >http://forums.turbobricks.com/showthread.php?t=197700
Dicktater is offline   Reply With Quote
Old 02-15-2021, 04:51 PM   #6
Jussi Alanko
The rods will bend something about 250hp, which can be make at 13psi or a 24psi, so it is kinda hp thing, not boost thing.
It depends lot's of what head you had and what cam you had etc etc. But i say if it's totally original i won't run it above 15psi.
Jussi Alanko is offline   Reply With Quote
Old 02-15-2021, 06:48 PM   #7
mikep
The MP
mikep's Avatar
It’s a torque thing. HP is torque times speed. Boost spikes at low speed fo more damage, as well as hard detonating at low/mid speeds.
Brady's schooling the kid.
just like here on tb?
Old 02-16-2021, 03:40 PM   #8
In proper stage zero I wouldn't run a small rod engine over about 11-12psi. Those engines also have the worst pistons for wear and causing slap. As suggested above get a wideband O2 gauge to monitor the engine mixture.
Old 02-16-2021, 04:36 PM   #9
240240
$600 Volvos
240240's Avatar
I bet you I can bend a rod at 108hp
Old 02-16-2021, 04:40 PM   #10
I tried but the 'M' rods wouldn't give.
Old 02-16-2021, 06:30 PM   #11
LC4CARL
Aero challenged
LC4CARL's Avatar
@PDXvolvo on IG
