#51 | |
![]() Quote:
Post back when you get the thing running.
No Start Thread |
#52 | |
![]() Quote:
#53 |
![]() Woohoo! It runs. Turns out the ECU was the issue. Thank you to 2manyturbos for getting that replacement to me so quickly. Sounds to run a fair bit better than before, as well.
#54 |
![]() Cool. Your test results pointed to the ECU. I'm glad you have it running now.
#55 |
#56 |
![]() Drove it home finally. Bit sketchy with all the guage cluster lights out and the blower motor that died on me. But its home now, so time to get to work on all those smaller issues.
#57 |
![]() Good diag. Glad to help. Thanks for posting back.
#58 |
LH-Jet & Carb Free Zone
![]() LH ECU is the same for high and low compression. 1983 is a 503 number, 1984 is a 510 number, I'm assuming because of the added circuit on 1984 cars for the heated O2 sensor. OP's car is an Aw70 car, if I remember correctly, so it's already a flat top piston B23F engine in there, unless swapped. Ignition box is different on low compression engines. More aggressive advance curve. |
#59 |
![]() ECU table suggests 503 is for NA 1983/1984, but I've wondered if engine program was twitched between AW70 and stick versions...since engines mated to AW70 were higher compression on 1984 (on engine I own).
Increasing the compression ratio changes the mixture density, but knock sensor may compensate so lower/higher compression engines work ok with 503 LH ECU. I do know a rebuilt 1984 B23F that was mated originally to AW70 works just fine when installed in a 1993-940 with Rex-Regina, using Bosch 0 280 155 746 injectors ; of course, a CPS was installed on B23F. |
#60 | |
![]() Quote:
Suggests is a good term. That ECU table is a crap shoot. Here is just one example of what I mean. LH 2.4 -016 0 280 000-556 B230FD 1989 (EGR) 1989-1990 (EGR) - California / EGR Model: -937, -967 and -954 are suitable. The B230FD didn't appear until 1993. A 556 is an NA 240-740 ECU with EGR. The suggested replacement ECUs are all 740-940 Turbo ECUs. The 937 and 967 are both non-EGR turbo ECUs. Suitable replacements would be a 933 or 946 NA ECU with EGR function. John is correct. 1983 US market NA 240s got the 503 ECU and 1984 got the 510. |
