Old 02-17-2021, 12:40 PM   #1
mhgreen
mhgreen's Avatar
Default Exhaust manifold rattly heat shield
The heat shield that involves what used to be the warm air intake system rattles and is annoying. Is the shield itself protecting anything? Once the warm air intake system has been dismantled can I safely remove the shield that bolts into the manifold?
mhgreen is offline   Reply With Quote
Old 02-17-2021, 12:49 PM   #2
Dan
Watching the World burn
Dan's Avatar
Most people do
1985 Chevy TPI V8 740.
Old 02-17-2021, 12:53 PM   #3
Acke
B230? Yes, it can be removed.
Old 02-17-2021, 02:06 PM   #4
mhgreen
mhgreen's Avatar
^ sorry. Yes B230. I was about to take it off there and just wanted to double check. My '86 never had one so I was fairly confident it was okay. I just removed it, 3/4 bolts came out fine, one broke off but whatever no harm done
Old 02-17-2021, 03:21 PM   #5
esmth
My b21f parts motor doesn't have one from the factory. Mounting bosses on the cast iron are non-existent
1991 244 LH2.4 M46 341k miles
Old 02-17-2021, 03:43 PM   #6
shoestring
shoestring's Avatar
I sandwiched mine with fender washers.
Old 02-18-2021, 09:02 PM   #7
2turbotoys
Salaminizer
2turbotoys's Avatar
Ripping that off is one of the first things I do to a 240, can't stand rattles from useless parts.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 02-19-2021, 01:28 PM   #8
lummert
lummert's Avatar
Later models don't even have it. I removed it from my 88 765 Turbo more than 10 years ago.
Old 02-19-2021, 02:31 PM   #9
go240go
Lucky. Smog in CA requires the heatshield installed with warm air hose attached to airbox. I've failed visual inspection in the past because of this, for a 1987 240.
go240go is offline   Reply With Quote
Old 02-19-2021, 03:24 PM   #10
vwblue1967
vwblue1967's Avatar
Ive always removed mine without issue...that i know of.
We are lucky in NC i dont even need to inspect my 85 any longer. My 93 passes but they pretty much just make sure the lights and horn work.
85 245 - ipd sport springs and sway bars yoshifab torque rods, kaplhenke bne strut mounts and TAB's. Poly bushings Bilstein tourings. B cam +4. 2.25 exhaust.
93 244 stockish.
vwblue1967 is offline   Reply With Quote
