Old 02-18-2021, 09:13 AM   #1
pathfinder
Default 940 turbo upgrade
Hi guys
It's year 1997, 940 FT. Low pressure turbo. TD04H-13C
I have Rica chips and manual boost controller. Plan to up some power. Standard power is 130bhp+
Is it ok if i use TD0H-16T ? (standard turbo from S60-T5 2.3 ,250bhp version).Plan to get 200bhp only, considering mileage is 300,000km
Will there any big turbo lag by using 16T ? it's automatic
Thanks
pathfinder is offline   Reply With Quote
Old 02-18-2021, 09:22 AM   #2
Marvelous3
Who engineered this?
Marvelous3's Avatar
16T is a great turbo for that power level.
Lag will be minimal. Similar to the 13c you have now. It’s still a small turbo.
Old 02-18-2021, 09:38 AM   #3
pathfinder
is it complicated to install the 16T to B230FT?
Old 02-18-2021, 09:42 AM   #4
Marvelous3
Marvelous3's Avatar
Complicated is relative. I’m assuming this is off of a fwd Volvo, if so it will need to be reclocked which is not hard. There’s lots of postings on here about how to do it. Otherwise it bolts to the manifold and everything.
Old 02-18-2021, 11:11 AM   #5
Fa182
Stage 1
Fa182's Avatar
If you don't have 2 left (or right...) hands it's not complicated.
See: https://forums.turbobricks.com/showthread.php?t=83929
Old 02-18-2021, 11:19 AM   #6
Sethvolvo
Sethvolvo's Avatar
If you have a TD05 exhaust housing Im pretty sure the 16t fits..? But no its not difficult to clock.
There also really isn't much lag at all with any of the TD04/5 series turbos
-1983 240 DL wagon
-1985 740 GLE
-1986 740 GLE
-1994 940 turbo
-1995 940
-1986 740 GLE (rip); 1988 740 GLE wagon (rip)
-1987 740 TIC wagon (rip)
Sethvolvo is online now   Reply With Quote
Old 02-18-2021, 12:22 PM   #7
thessejway
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
thessejway's Avatar
With switching to a 16t I think the most difficult part will likely be the connection to the exhaust.
Someone correct me if I'm wrong, but the 16t turbos out of the fwd Volvos use a different exhaust flange, so you will likely need to weld a different connection on your downpipe if you aren't changing your exhaust
____________________________________________
1993 945t Build Thread
thessejway is offline   Reply With Quote
Old 02-18-2021, 12:43 PM   #8
shoestring
shoestring's Avatar
Unless you want to swap in the 16T, it's not necessary for that power level.
Old 02-18-2021, 12:50 PM   #9
oldschoolvolvo
oldschoolvolvo's Avatar
You can use a conical exit turbine housing from a TD04HL turbo on a 16T. IIRC these were found on the TD04HL-15G turbos on early 850s. The turbine housings then changed to the more typical straight exit variety. The conical exit housings are getting harder to find, however in the past I've had luck with asking around on the FWD forums, etc.
The stock 13C is a "non-HL" version and the turbine housings are not interchangeable between 13C and 15G/16T/18T, etc.
However, to the OP, I would start with upping the boost on your 13C before worrying about swapping the turbo. Either a MBC or a different wastegate actuator. (ex: https://www.ebay.com/itm/MAMBA-Adjus...EAAOSwefRbYm2K)
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 02-20-2021, 05:39 PM   #10
lummert
lummert's Avatar
Install a HPT wastegate actuator.
Old 02-21-2021, 10:21 PM   #11
pathfinder
Thanks
with all original parts, using mbc, how much boost the 13C could handle? estimate what bhp i should get?
Old 02-22-2021, 03:46 AM   #12
Fa182
Stage 1
Fa182's Avatar
Originally Posted by pathfinder View Post
Thanks
http://forums.turbobricks.com/showthread.php?t=355788
He made 184whp with a 13C at 14psi and his chips.
Old 03-01-2021, 05:55 AM   #13
pathfinder
what is 13C max bhp can generate?
what's the CFM value of the 13C ?
if with Rica chips and mbc, what max safe boost can i get?
thanks
Old 03-01-2021, 07:30 AM   #14
Swedbrick
Swedbrick's Avatar
The 13c will flow about 0.14m3/s = 300 cfm of air, if you dare spinning it to the edge of the compressor map. Given that for turbo's a guesstimate of hp per cfm is about 100hp/150cfm, 200 is around the max of what it will make.
As for the chips Redblockpowered and me sell, 1.0 bar is maximum as tested, I would assume the same to hold for the Rica chips. Any link to those, cannot find anything about them
Volvo 745 - IPD springs, 25mm/19mm swaybars, K-cam, LH2.4, M90 swap, 3.54 \w racingdiff lsd, track/daily
Old 03-01-2021, 07:36 AM   #15
pathfinder
Thanks bro
How about original injectors and fuel pump? could hold 180-200bhp ?
Anyway, what are original injectors cc and fuel pump lph?
Old 03-01-2021, 07:55 AM   #16
Swedbrick
Swedbrick's Avatar
Thanks bro
Original injectors are 335cc, good for 220hp as well at 90% duty cycle. The pump in the tank is just a lift pump, the underside one is a bosch 039 or 068 and good for the same power. You can replace it by a 040 for 200lph or a 044 for 300lph
Mind that crank-hp and wheel-hp differ by a percentage depending on driveline losses
Old 03-01-2021, 12:38 PM   #17
Fa182
Stage 1
Fa182's Avatar
Later 940 Turbos do not have an inline pump under the car AFAIK.
My 97 certainly doesn't have one.
Old 03-01-2021, 01:13 PM   #18
Swedbrick
Swedbrick's Avatar
Ah okay, never had one of those
Old 03-01-2021, 04:22 PM   #19
shoestring
shoestring's Avatar
Aren't the Motronic cars single fuel pump?
Old 03-01-2021, 05:10 PM   #20
Fa182
Stage 1
Fa182's Avatar
A 1997 940 is LH 2.4.
Old 03-02-2021, 05:17 AM   #21
pathfinder
so, conclusion no problem 200bhp at engine with using 13C, ori injectors and ori fuel pump? Will install Rica ignition and fuel chips, use mbc to set 1 bar?
how about original intercooler? sufficient enough for 200bhp?
thanks
Old 03-02-2021, 07:30 AM   #22
Fa182
Stage 1
Fa182's Avatar
No problem, correct.
You will likely not reach 200bhp with the stock components, as mentioned more times in your other threads.
Yes and no.
Stock intercooler is fine for that power, but an upgraded intercooler will give you great benefits due to more air flow and less restriction.
In my case, I use the KL Racing intercooler. I am very happy with it.
http://forums.turbobricks.com/showthread.php?t=343520
Depending where you are in the world, people use so called "NPR" Intercoolers from certain small Isuzu trucks too.
They are almost a drop in replacement with very little work necessary to make it fit.
Here in Austria, we do not have these Isuzu vehicles, so I bought the one from KL.
