Old 02-20-2021, 08:39 AM   #1
ortho stice
Default G80 does not lock up
1994 940 Turbo wagon with ~240k miles on it. Only modifications are a 16t at 12psi and T5 blue injectors. I’ve owned the car for almost one year exactly and it has always made a strange knocking noise on deceleration from the rear end, not sure if that’s related.
Anyway I got stuck in my driveway the other day and had my girlfriend in the car while I pushed. I noticed that it just spun one rear tire and made a sort of crunching/clicking noise. What fails on the G80 typically? Is it serviceable or should I be looking for a new differential?
ortho stice is offline   Reply With Quote
Old 02-20-2021, 12:06 PM   #2
dbarton
Dejected by Volvo
dbarton's Avatar
A "new" (used) G80 is certainly not expensive, so I would replace it. I don't know what breaks in there if anything did, but I do know using the incorrect lube will destroy the clutches and create one-tire-fire. So if a previous owner used lube with an LSD friction modifier, that would do it.
Replace it and take the old one apart and post pics of what you find.
Dave B
'84 242ti, fourth owner, mine since 2003. Always garaged since brand new. Old-school rounds because I like. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, hydro clutch, 3.91 diff with unmodified G80.
Old 02-20-2021, 10:21 PM   #3
ortho stice
I hadn't thought of that, that's a distinct possibility. I admit I still don't totally understand how these things work and didn't even realize there was a clutch pack in there. I'll start the hunt for a G80. Hasn't been a '91+ 940 in the local yard in almost a year.
Old 02-20-2021, 11:24 PM   #4
sbabbs
sbabbs's Avatar
THe clutches are metal and your not supposed to put any limited slip additive in there or it will slip then. Straight gl-5 gear oil synthetic.
OTHer then that check the little paw gears break then it won't ramp up and lock so you'd need new little paw gear thingy. Gotta take it out to check or might be able to see if you take the back cover off and turn the wheels to see. The paw gears are near the counter weight thingy. I've seen them stripped out before. Also there is a beefier G80 it's the 1041K found in the rear of early 960 wagons.
Old 02-20-2021, 11:51 PM   #5
ortho stice
I'll drop the $100 or whatever the going rate for a G80 these days is before pulling the diff. If there's carnage, I'll be able to put that in and hopefully have no down time for the car.
I'd never heard that about the 960's, there's a sedan at the upull right now but of course that will have the independent rear.
Old 02-21-2021, 02:02 AM   #6
MasterBlaster
MasterBlaster's Avatar
Ah, Youtube...
508,000 km so far...
Old 02-21-2021, 02:26 PM   #7
I have a couple GM G80's on the bench. I wonder if the clutches are compatible with our old Volvo ones....
Old 02-22-2021, 12:58 AM   #8
FreeEMSFred
FreeEMSFred's Avatar
So, I'd read that in the past, and tried to cross check it and had people say it was rubbish. Is there any proof that it's in any way stronger and if so, what is that proof? I have one, but I have my doubts about it being any different.
Old 02-22-2021, 01:58 AM   #9
Khrrck
Professional Amateur
If anyone has a Volvo one outside the car, you could take some dimensions and compare notes.
I've heard that products designed for the Jeep Dana 30 can be made to fit but I've not seen specifics.
'87 240 budget wagon.
Old 02-22-2021, 04:58 PM   #10
swedishiron.com
I sell Volvo parts!
I have a spare working G80 that I removed from a '93 940.
Message me if you want it.
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old Yesterday, 06:44 AM   #11
Janspeed
Originally Posted by MasterBlaster View Post
Ah, Youtube...
nice video. I always wondered if the G80 can engage in both directions. I seems it can.
I have a G80 in my 780. I must say the engagement while demanding traction on snowy/icey surfaces is not what i would call subtle. It locks with a clunck. But it works.
Old Yesterday, 02:29 PM   #12
Default Gm g80
I think I will pull one of them apart. I think its from a 2017'ish Sierra.
Old Yesterday, 02:52 PM   #13
sbabbs
sbabbs's Avatar
Okay here is the 1041K is beefier picture proof. It has a solid tube in the center. Smaller holes in the sides of the case.
Left is the rubbish 1041k with smaller hole, see the smaller hole harder for rubbish to get inside your rear. Anybody else wanna say it's rubbish now, if so you should go rubbish one out! You think it's the same as all the 1040's? Why did volvo make it different and call it 1041K and put it in 960's only place I've ever found them???? Why is the side of the case beefier with smaller little tight hole??? Why does it have a solid thick metal tube in the center where the axles meet??? Questions to BS around the tea pot while pondering rubbish holes to fish.
But the best is welded rear diff for sure! When I had a welded diff I broke about 6 axles. Put in the 1041K, haven't broke an axle yet.. Maybe the 1041K axles are better then 1041 rubbish ones??
Old Yesterday, 04:59 PM   #14
FreeEMSFred
Chill out sbabbs! Rubbish the way I used it simply meant "untrue". British English thing, probably.
Interesting photos. My spare non-K 1041 G80 is on the bench and IIRC looks different to both of those, but perhaps I don't recall correctly.
I wasn't very interested in whether the G80 aspect was stronger, more whether the ring gear and pinion were compatible or a different size/bigger/stronger. I guess you've answered that: Same diff gear strength, different G80 core. Cool :-) Thanks!
The reason I wanted to know that is because I want to swap a 240 3.783 ratio set into the 960 wagon so it can accelerate a bit better without losing too much fuel economy like a 4.1 would.
I'll have mine open sometime soon and will post some higher quality/resolution photos here of it and maybe the other one on my bench, too, if I can dig it out.
Old Yesterday, 05:02 PM   #15
sbabbs
sbabbs's Avatar
Plenty cold here, just razzin' ya..
