Old 02-20-2021, 12:14 PM   #1
RecycledEuropean
Default 1988 244, +T or install 1984 Turbo Motor
Hi Just like the title says, what is better install a 1984 Turbo Motor I have, or Plus T the 1988 Stock engine, it an M47 car Beige 244 totally stock
Thanks, TB
RecycledEuropean is offline   Reply With Quote
Old 02-20-2021, 12:19 PM   #2
740atl
educator monkey
740atl's Avatar
What are your goals? You can +T the engine in the car, keep it mild boost and have it run forever.
Old 02-20-2021, 12:30 PM   #3
90volvo
My guess would be; do the Plus T. Because its probably in better shape than the stock T. But kinda depends on the milage and which one is in better shape.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 02-20-2021, 01:37 PM   #4
RecycledEuropean
Hi Thanks for the answers so far, goals are just pretty near-stock (Same as an 85Turbo) boost, some more urgent acceleration, and fun, Miles on the Turbo engine are 150K and on stock around 220K
Old 02-20-2021, 03:10 PM   #5
Dann sind wir Helden
I would swap in the turbo motor, you won't have to make an oil drain for the turbo and it's a pretty good bet the turbo motor has better rods.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 02-20-2021, 04:14 PM   #6
gotboost
contributor
gotboost's Avatar
What did the 84 motor come out of? I think 84 was the year for the B23FT in the 7 series, and those have forged internals. If it is out of a 240 Turbo it should be a B21ft...in which case I'd do the +t.
Currently: 1993 Volvo 244 w/ 140k miles.
Previously:
1997 Volvo 850R Manual Wagon, The "Battlewagon"
1998 V70XC
1998 S70 T5M SE
1985 245 +t
2004 S60 2.5t
gotboost is offline   Reply With Quote
Old 02-20-2021, 07:13 PM   #7
Thr B21FT has the same internals as the B23FT just 92mm pistons instead of 96mm.
