Old 02-21-2021, 09:18 AM   #1
CooperV
Default Oil line routing b230ft
Hello, this has been troubling me some but I cannot figure out where my oil feed line connect to the block of my b230ft. Does it connect in the hole in the front of the block? I’m wondering because I found a hole with a banjo bolt in it right behind the oil cooler, and was wondering if it should go there instead.
CooperV is offline   Reply With Quote
Old 02-21-2021, 10:11 AM   #2
Marvelous3
Who engineered this?
Marvelous3's Avatar
There is a feed on the front of the block.
Old 02-21-2021, 12:36 PM   #3
CooperV
Okay then can you tell me what the hole on the side of the block is for??? I cant find any info anywhere
Old 02-21-2021, 03:05 PM   #4
Acke
The ft/fk stock oil feed is connected to the side of the block with a banjo bolt. Sounds like you found the right spot.
Old 03-02-2021, 05:31 PM   #5
BoxDriver2
BoxDriver2's Avatar
you can sort of see it here for reference [googled]
B230 is on the side. Some tap the front for a +T etc.
88 745Ti // 06 Saab 92x // 71 Pontiac LeMans // 02 Avalanche Z-71 - All Modified
Towerymt: after you finally do part with the 745, will you still buy parts for it?
Towerymt: phantom car syndrome
BoxDriver2 is offline   Reply With Quote
