iHateVolvoPeople
- Feb 1, 2014
- Midwest
1993 245 with the K39200 speedo.
I’ve had an intermittently functioning odometer since i replaced the gears. I made sure all old broken gear pieces were removed. The odometer would usually not start during the first few minutes of driving in then all of a sudden on the highway it would start functioning. I also noticed that if I pulled the cluster out and pushed the speedo connection in the odometer would function. However, it only seems to work for about half of a mile and then it stops working again.
I took apart the connector in the cluster that plugs into the back of the speedometer and I clamped the pins closer to each other in order to make a tighter contact on the back of the speedo. This did nothing.
I would like to know if there is a way to apply voltage or something to this speedometer outside of the car in order to bench test it and check for odometer functionality.
