Old 06-11-2012, 09:20 AM   #1
volvobrage
Default Volvobrage's widened 242 -- Alot of pictures every day!
Hey guys, girls and transsexuals!
I have a 242 project i have been working on for a bit over a yearThe car is a loong way from finish, but it is starting to look like something..I will copy the posts with dates from the norwgian volvoforum and try to translate them(my english suck)
Hope you enjoy my work!
The car is a 1980 modell 242 where I am the fourth owner..The plans for the car is a total resturation with a 2l turbo engine from v70 and a new suspension. The rest of the plans you can find out by following the project!
11.05.2011
On my way home with the carThe b21 was leaking cooling water and oil så i had to refill 4 times on three miles:p
Finally arrived at my work, where i was going to store it for a little while
Bad paintjob!
The snowcap will stay on when the car is repainted!
The orignial paint..It is not sanded down under the new paint
Some parts that are waiting for assemble
Frontplates for the 1976 front that is going on the car!
Had to weld many holes and straiten it out after some jerk ripped it of the car it belonged to..
Old type front lip
Original glass and the us type glassI will use the us type, but i need new ones since these are in bad conditiong..
Black floorcarpet from 1980 volvo 242
Black carpets for dash
All the parts for the roof in black from a 242 gt
The old type elctrical mirrors, complete with wireharness and controls!
Front!Everything is in VERY good condition!Never been painted and nothing is broken..
New front I'm going to send for blasting
volvobrage is offline   Reply With Quote
Old 06-11-2012, 09:25 AM   #2
volvobrage
Me and my friend decided to rip out the old engine since it was crap anyway..
Took of the hood and found the toolbox!
The engine on its way outMy friend is very happy since he got the permission to destroy the enigne after we took it out
A minor problem while I was cutting the gearbracket under the car, a 9" anglegrinder can be cruel..
Almost out!Went very good exept from the grinder accident and that the engine mounts where ****ed and would not go out..
After a few drops from 3-4 meters!The volvo engines are strong!!
Old 06-11-2012, 02:37 PM   #3
volvobrage
Got the body replacement parts for the car..They looked not so nice
The crossover for the radiator i ordered to have extra, dont now if I am going to use it..
Startet on the new torque rods!
After some time in the lathe:D
And finish
Pipe in the right dimension
Here you can see it will be stronger..NB! Not the right lenght on the new pipe, only for testing
Me, my father and my brother both this tig machine togheterA bit easier to produce parts in the garage then
I have also finished the test for welding so now I am a fully educated welder
Old 06-11-2012, 02:42 PM   #4
volvobrage
Took the car on the trucklift to check out the status on it
Took of the rest of the parts under witch is going to the trash
Started taking the gastank down, but didnt finish
The worst side!But no problem, I have seen it worse
The other side..Going to change the spare wheel "casing" and the lower pease of the rear fender here also
Here it looks good!
Also here after washing!
Some rust in the paint, but nothing serious
Old 06-11-2012, 06:17 PM   #5
doucheNozzle
doucheNozzle's Avatar
Subscribed
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 06-11-2012, 06:43 PM   #6
miguel.760ti
miguel.760ti's Avatar
Looks good!
Sell me the grille once you go to the single round setup.
1988 760 Turbo - garage queen, everlasting project
also
2016 Ford Fiesta ST - size small daily
1995 Ford F150 - size large daily
miguel.760ti is offline   Reply With Quote
Old 06-11-2012, 06:45 PM   #7
Homer
OEMplus++
Homer's Avatar
Glad you have a project thread now!
-Jacob:
2006 A4 - Comfy DD
Need something TIG welded? Give me a shout.
Old 06-12-2012, 01:57 AM   #8
volvobrage
Originally Posted by miguel.760ti View Post
Looks good!
I could do, but its not in a great condition:(But I have to grills laying around so its possible to mix them togheter;)
Thank you Homer!Hope you enjoy my work as much as I enjoy yours!!
Old 06-12-2012, 02:03 AM   #9
volvobrage
Started cleaning up the engine compartment!
Batteribox looked horrible so I wondered what was under
But it was not so bad!Will fix this whit blasting
Looked like this
And finished like this
Also started inside the car..This is how all the wiring looks like
This is going to be replaced by a sparco or r sport stearing wheel
Also got some parts!These to will be mixed togheter, electronic speedo and RMP gauge
3 pod in very good condition!
The turbopressure will be replaced with a new VDO gauge with numbers
Old 06-12-2012, 02:05 AM   #10
volvobrage
Cutted the pipes in correct lengthNow i can adjust 4cm in and about 1cm out..The treads are m20 by 2,5..
Made the pipe fit good against the ends!
Old 06-12-2012, 02:06 AM   #11
Pro Sneaker Peddler
Wanting moar.
Old 06-12-2012, 02:08 AM   #12
volvobrage
Took out the old speedo and cleaned the housing
And put in the elctronic speedo with the RPM!
And I also did some welding on the torque rods
Finished one!
Old 06-12-2012, 02:09 AM   #13
volvobrage
This is going to make my day when the new engine is finished!
Old 06-12-2012, 02:16 AM   #14
volvobrage
First of all, this is how it looks at home!I have a very nice family
Transporting the car homeThanks to my friend how drove it home for me with my fathers 940 turbo
Finally home!
Started taking the front appart!
Some people should just stay away from cars
Looked good "under" the front
Also looked good under the front fenders
Brand new springs and koni struts on the car
Ripped of the bumper
Somebody towed it a little bit to hard
Looked like som hobo lived there many years
But after some cleaning it actually looked good again
Old 06-12-2012, 10:07 AM   #15
slow240
Home Schooled
slow240's Avatar
im gonna be watching this one, that front end "bodywork"
keep us posted, we need more projects like this!
I'll polish your face
'90 244. blue, tall, ghetto, fabulous.
http://forums.turbobricks.com/showthread.php?t=310740
Old 06-12-2012, 02:08 PM   #16
volvobrage
Yeah I love "bodywork"!Have a Amazon wagon also with a lot of work from the formal owner..Its sad!
I will!!
Have little bit over 500 pictures of the project till now
Old 06-12-2012, 05:02 PM   #17
amerbritcan
Hnnnnnng
amerbritcan's Avatar
get to the widened bit!
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 06-13-2012, 02:14 AM   #18
volvobrage
Easy now, I must start on the beginning!
26.09.2011
More parts!
Plenum for inntake manifold
Not sure what this is called, but its for the intake manifold, made in cnc lathe
Endplate and flange for the throttle
Flange from 6 sylinder enigne, Im going to cut the last sylinder off
i also have one of these!
Stainless plates cut with waterjet
Turbonetics rg45 wastegate
And fuelrail for the new intake manifold
And three bonus pic of a intake manifold I welded for a friend, made from the same pieces i haveI did not make the parts, only welding
Old 06-13-2012, 02:16 AM   #19
volvobrage
The last pieces for the gauges!
And i removed the rubber from the extra supesionparts wich is going for blasting
Old 06-13-2012, 02:19 AM   #20
volvobrage
Finished the first part of the other torque rod
Grinden the ????? for the rear suspension
Welding paint
Spotted the plate on when the paint had dryed
Finish welding!
And grinden over it
Cleaned the front fenders of turnsignal, trimmings and straitened out a dent
Old 06-13-2012, 08:59 AM   #21
550
Can you adjust ac balance on your tig?
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 06-13-2012, 09:37 AM   #22
Homer
OEMplus++
Homer's Avatar
Looks like he needs a bit more cleaning action
Old 06-13-2012, 09:50 AM   #23
550
Lol, I was thinking a little less. Atleast in some spots, it looks like the cleaning action extends out pretty far from the bead, especially on what looks to be non cast alum.
But I didn't go to school for welding, and his beads look better than mine easily haha, as do yours homer.
Old 06-13-2012, 09:56 AM   #24
volvobrage
Hmmm, homer what you mean?I need to grind more before the welding?As I said before, my english sucks
I normally dont grind so much on nice alu like that..Grind the edges all the way around mayby 5mm out and then i clean it with "red boose"
You mean the welding is to wide?Or that the metal is not clean enough?
Old 06-13-2012, 10:27 AM   #25
550
Well, when TIG welding, you are using an AC power source. The properties of the AC wave actually can clean the aluminum depending on how you have the AC balance set. (On my Miller, 3 is balanced.) But with the AC balance, you can adjust the amount of penetration vs amount of cleaning action needed. (More cleaning action for aluminum that is dirty, like cast aluminum tends to be)
There depending on the aluminum, you don't need as much cleaning action, which is indicated by the white border on the weld bead.
Doesn't mean anything is wrong, just think you probably don't need much cleaning on that aluminum.
