Hello I have some problem with my speed signal going between the ezk and the fuelbox.
From what I read it should be between 7-9v on idle, but I have only 4.8 volt.
Volatage from vr sensor to ezk is ok and I tried with another ezk box with same result.
I also have this weird thing that when I read the hz I can only do it if I connect to signal only, if I connect to ground it displays 0 hz, is this normal or is there bad connection to ground?
The problem that I have with the car is little bit rough idle, idle stays high sometimes and it seems the fuelbox thinks I’m at a lower RPM than I’m and therefore I get too little fuel around 3200-4000 rpm and then after 4000 it’s good again. I have temporarly fixed this by increasing the fuelpressure and it works, so there is not a problem to deliver enough fuel.
Problem with both ezk, or some wiring isssue, or the fuelbox? I’m clueless and need advise how to keep testing.
