For info for those wondering if this will work on 700s: I have installed now (and used) the front struts/discs/hubs/brakes/etc. from a '91 944ti (with ABS--the "Big Brakes") onto my '86 744ti. Direct bolt-up, no funky anything at all.
With that said, turbo16psi, do the R calipers bolt directly up to the 940 "Big Brake" (ABS) mount? Can I still use the "Big Brake" discs? If not, what sort of bracket did you need to make? Do you have any pics of the mount from behind (engine-side)? Close-ups? Pics of the whole lot disassembled? Have you had any on-road experience with them yet? If so, any noticible difference in pedal effort (I found with my "Big Brakes," I had to really stand on the pedal, which is why I'm convinced I don't like 'em. Of course, could be because I'm using single-feed ABS calipers on a dual-feed non-ABS vehicle...)?
I am considering adapting some Wilwood 4-piston or 6-piston calipers (Whoa! Let's not get ahead of myself!) (have found them for $120 each, sure I can find lower if I tried). But if the R brakes are direct bolt-ons, I may go that route.
