#1 |
Banned
![]() https://imgur.com/gallery/JpgEwpT
Note the odd chirping/ ticking noise? Motor has cleaned up 531. Head is decked, valves lapped (not by me), lash correct. Running the mis-ground iPd turbo cam from many years ago, was running at 2 deg advanced for years in stock 530 head. Timing seems off, I have modified dizzy to allow for the out of alignment keyway. Matches the original bad distributor, with new hall sensor wiring 89 b230ft, Lh2.2, leads, plugs, TPS reset and idle adjusted, new water pump, heater bypass valve, bypass hard pipe, yoshi turbo drain, phenolic inlets spacers. Vac is good, vacuum lost in time with that chirp/tick. Any suggestions? Last edited by RichGT; 11-20-2020 at 04:05 AM.. |
#2 |
![]() Join Date: May 2007
![]() The tick sounds like an exhaust leak. Chirp is likely overtightened belts. Also, reset your idle base settings. Also also, sounds like it's firing on 3. Definitely make sure the timing belt isn't off a tooth.
#3 |
Banned
#4 | |
Aero challenged
![]() Quote:
![]() @PDXvolvo on IG |
#5 |
Banned
![]() Yep, vac gauge to zero, I’ll be pissed with the machinist if that’s the case! Compression good
#6 |
![]() pull plug wire off one at a time. When you find the one that doesnt change anything. Thats the bad cylinder but, diffently sounds like something foreign in cylinder. I wouldnt run it anymore than you have to and pull head off. Good luck
90 Volvo 240-my current setup. B230ft rebuilt -8.8 comp. -Stage 3 rsi cam 3 inch ex.-GTX3076r turbo ballbearing. ebay intercooler-3 inch IC piping- Oil cooler with 10an hose. port stock intake (weak, having a custom intake by viking fab.) Megasquirt 2-1300cc injectors (running E85) 530 head with big valves ported and assemble by culberro sons car- 93 240-15g turbo-chipped-95,000 miles. Slick car Leave feedback- http://forums.turbobricks.com/showthread.php?t=355413 |
#7 |
![]() Unplug an INJECTOR one at a time to perform a cylinder drop test. Much safer.
No Start Thread |
#8 |
Aero challenged
![]() Remember that cool tool in shop class that would allow you to drop a cylinder at the touch of a button?
What is "out of alignment keyway?" Sounds bad... |
#9 |
Banned
![]() The keyway where the distributor drive dog fits into the cam. The early turbo cams from IPD where ground 20 deg out of alignment from correct ignition timing. No time for this with work being busy before Xmas. I will report back with findings
#10 |
Bored member
#11 |
#12 |
![]() Dropping a fuel injector is also safer for the kitty.
Thread Tools | |
Display Modes | |
