I'm working on a '93 240 wagon, automatic transmission. The owner's complaint is that it won't go up hills and knocks.
I got in it and it feels sluggish and low on HP. It also spark knocks when you load it up. It had codes for the ECT and AMM burn off. It does go up hills but you have to give it a lot of throttle. The temp gauge reads a little low, but that could be the compensator board or a cooler thermostat.
I put an new ECT sensor and used AMM in it and it didn't change. I also checked the cam timing, which was fine, and the spark timing, which was 15* at idle. The codes didn't come back after 30 minutes of driving.
I also changed the air filter because it was filthy. I put new plugs/wires/cap/rotor on it about six months ago.
I ran out of time to work on it today but tomorrow I'm going to check fuel pressure. Do you guys have any ideas of what else I should look at?
