#26 | |
![]() Quote:
#27 |
Vintage anti-ricer
![]() Join Date: Oct 2004
![]() Damn Mike, that's nuts! Or screwy?
Glad I put a little locktight on if I ever pull the plate, but still, wouldn't help with the snapped shaft...
RIP Doug Williams aka Mr. Doug 4/15/2009 Pete Fluitman aka fivehundred 7/14/2013 Mick Starkey aka TrickMick 1/10/14 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
#28 |
![]() If you don't mind spending ~$200, that head could be fixed if it's just the chamber that's beat up.
I wouldn't even tough the roof of the chambers, just clean up the quench pads. A little welding and some die grinder action, and a then get the head surfaced. I've fixed much worse damage than that.
Cult Person. Pissing in your Kool-Aid. |
#29 |
unbalanced chemical
![]() Join Date: Jun 2002
![]() Sounds like I will be taking this head to one of the local shops then and seeing what they quote me to fix it.
#30 |
Boosting along.
![]() I'd send it to culberro...
Local shop are mostly joke.
85 GLH 367whp 00 Insight 72 mpg 94 855 in hibernation |
#31 |
240 Ninja
![]() Sand down the top of the piston, shave the head and run it. (if it was a stocker
![]() -Patrick |
#32 |
An Anomaly
![]() Reminds me of when I re-installed a IC pipe and a piece of one of those little clips that hold the hose pipes in place broke off and got sucked into a combustion chamber. Same damage. I had the head welded to fill the damage and surfaced and threw a new piston in that hole.
1994 945ti | 15g @ 14psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, d088 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, Cherry Turbos upper/lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits. 1985 744ti | 13.8 @ 100.5 mph - Sold after 20 years. ![]() |
Thread Tools | |
Display Modes | |
