Old 01-01-2017, 09:52 PM   #1
Dr-MorningWood
Dr-MorningWood's Avatar
Default Ls crossmember.
You guys that are running LS's in your 240s, just curious what everyone is using for mounts or crossmembers. Someone told me you meed a custom crossmember to clear the steering shaft and allow use of the normal pans. Also what headers are you using with your mounts?
I recently got an lm7 and am thinking of making something work.
Thanks!
Dr-MorningWood is offline   Reply With Quote
Old 01-02-2017, 12:03 AM   #2
volvo?
That One Guy
These work.
http://www.stsmachininginc.com/produ...x-motor-mounts
volvo? is offline   Reply With Quote
Old 01-02-2017, 12:43 AM   #3
AndrewEG
AndrewEG's Avatar
Thanks!
Modifying the cross member is unnecessary. Just use the mounts from STS and a Hummer H3 oil pan and pick up. You will have to cut the pan and reweld it as it's far too deep.
With transmissions like the 6 speed manual you'll have to clearance the tunnel slightly at the firewall opening. If you go with a manual then use the TR6060 as this has a remote shifter.
Header choice would be modified tri-y's from a HSV VE-VF / Chevy SS.
This thread documents a 6.0L very well. He's taken a minimalist approach and has turned out very clean: https://ozvolvo.org/discussion/4623/...-conversion/p1
AndrewEG is offline   Reply With Quote
Old 01-02-2017, 01:30 AM   #4
77volvo245
77volvo245's Avatar
We are using our STS ls motor mounts. You can use the Holley Oil Pan #302-1 fits without modifying your cross member. Hooker Cast Iron Headers #8501 HKR will clear the steering shaft, you need to run the TRW cam style steering rack for our mounts.
STSmachining
Old 01-02-2017, 02:05 AM   #5
Dr-MorningWood
Perfect. Exactly what i was looking for. Thank you guys!
Old 01-02-2017, 12:53 PM   #6
Dr-MorningWood
If you dont mind me asking waht are you usin for a trans and crossmember?
Old 01-02-2017, 03:43 PM   #7
volvo?
That One Guy
4l60E, stock crossmember, his mount. All that is on his website.
Old 01-02-2017, 11:47 PM   #8
77volvo245
77volvo245's Avatar
4L60E with the factory transmission cross member, we make a 4L60e trans mounts that bolts onto the factory Volvo cross-member.
