Old 11-30-2020, 04:05 PM   #1
ogamer777
Loading...
ogamer777's Avatar
Default Does the STS machining ac delete bracket work with teardrop PS pump?
I don’t remember if the sts machining ac delete bracket / ps pump relocation bracket works with the teardrop ps pump. For an 83 240 turbo k jet.
84 242 DL M46 212000Mi
82 244 GLT (15G) M46 243500Mi 23 Aug 2019
79 242 GT 1 of 600 Aussie RHD BW55 312223Km
83 245 TURBO M46 "117000Mi"
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
ogamer777 is offline   Reply With Quote
Old 11-30-2020, 04:14 PM   #2
RvolvoR
no, it is meant for late model (b230) pumps.
Old 11-30-2020, 06:42 PM   #3
ogamer777
Loading...
ogamer777's Avatar
Ok thank you
Old 11-30-2020, 08:43 PM   #4
Since TBricks search doesn't do 2 or 3 letter words (AC or A/C), try searching For Sale for something like: "delete bracket" or maybe just "delete"
e.g. http://forums.turbobricks.com/showthread.php?t=179746
Old 11-30-2020, 09:27 PM   #5
77volvo245
77volvo245's Avatar
It can. I modified the IPD - Air Conditioning Bypass Kit spacer and made another washer to fit with the existing steel brackets..
STSmachining
Old 11-30-2020, 09:54 PM   #6
ogamer777
Loading...
ogamer777's Avatar
I am not familiar with what washer you are referring to. I know the IPD spacer, but how did you modify it and what does the fabricated washer look like/do?
Old 11-30-2020, 10:35 PM   #7
77volvo245
77volvo245's Avatar
The small stainless washer or spacer I made is pictured on the top bolt between the black anodized aluminum bracket and the volvo steel bracket. I think I removed 1/4 off the ipd spacer to have the correct spacing to lineup on the crank.
20201130_182211 by scott Becker, on Flickr
Old 12-01-2020, 12:28 AM   #8
quillc
yv1a.com
quillc's Avatar
I run the factory bracket that the STS piece is a reproduction of on my 83 242DL and my 84 242 GLT.
Works fine.
Chris
www.yv1a.com
Old 12-01-2020, 01:41 AM   #9
ogamer777
Loading...
ogamer777's Avatar
Thanks for the clarification. Should be simple to replicate that.
Works fine.
Does your setup include a spacer like Scott's?
Old 12-07-2020, 12:55 AM   #10
quillc
yv1a.com
quillc's Avatar
Its part of the factory bracket.
Old 12-07-2020, 05:07 PM   #11
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Remember, there are three different OEM Volvo non-AC PS brackets. The 1976-77 ZF bracket for the early external reservoir pump, the 1977-84 style used with the P-type Saginaw pumps, and the 1985-on B230 bracket, used with the later style Saginaw pumps (both external reservoir and internal reservoir). IIRC, Scott's bracket is a replica of the B230 bracket, not the B21/23 bracket. The difference is that the B21/23 Saginaw pump bracket uses three bushings, instead of one.
Most common AC delete bracket is this one:
http://forums.turbobricks.com/showthread.php?t=214855
-J
@john242ti on IG
Old 12-08-2020, 11:41 PM   #12
swedishiron.com
I sell Volvo parts!
-J
Or these:
https://forums.turbobricks.com/showthread.php?t=179746
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
