SEslayer
Dumber than I look.
- Apr 17, 2013
- New Zealand
Just finnished my CD009 swap on my 945, its sat for 4 months and now wont go, what a way to celebrate...
So, heres a list of what i have done and what i have tried. Please leave the swap questions, i have pictures and info (the juicy type) for a swap thread but need to actually drive it so i can review ratios.
Currently car cranks and tries to fire intermittently but wont actually run, i sounds like it wants to but doesnt have enough to keep it up. Everything screams timing to me. But i dont have a light and the belts and pullys looks fine to me. I could get one if i need to but they are quite pricey this close to christmas.
I have,
Removed m46, plugged shifter plugs back in to complete ground in that circuit.
Swapped out to a near new starter.
Ballsed up the flywheel orientation so pulled gbox and fixed that. 95% sure its correct. Dont want to pull box again just to find its right, (its a heavy boiii) but its the next thing i guess.
Checked coil. Pulses consistently. (Tells me cps is good)?
Pulled plugs, plugged into leads and tested against strut tower (good spark) (gapped to big though but definatly firing)
Checked compression (evenish across all 4) (120miles)
Unplugged injectors, car still wouldnt run with a good spray of brake clean. (Will go buy propper starter fluid tomorrow)
Pulled EZK (currently plugged in but not properly mounted)
I pulled turbo and manifold to fix gasket leak.
And i removed the intercooler and radiator. But replaced both.
I have checked cam timing and mistook it for being out. On first start there may have been a breaker bar attached to the crank pully. So i pulled the top cover to check the tbelt. Looks fine with all teeth present. I double checked to see it hadnt jumped a tooth. Looks fine to me. (Line on front pully at 0? dot on cam matches line on back cover, cams at 9,3) i checked compression after this.
Cheers guys. If i think of anything else i have tried i will mention it. I have a multi meter so i can check things as they are suggested. I am itching to drive this bitch.
I have,
