Old 08-11-2018, 01:46 PM   #1
haltechsupra
haltechsupra's Avatar
Post Lets Look at dynos!
Please share your dyno, temp, humidity, car, mods, engine, boost levels, type of dyno, video, charts can be saved on Imgur and shared for free. Its fun to see what others are making. Please share and sticky! Would love to be able to section this for the model of cars , or engines , whiteblocks, redblocks, V8. Please sticky this...
No records set here, but here is mine.
and Video.. https://youtu.be/WxffNEV2n_M
1993 Volvo 945, b230f 94 squirter block, 16 valve head + hx52 turbo, cx rods , Wiseco pistons, t56 6 speed manual transmission, custom manifolds and piping, supra mk3 turbo radiator, supra mk4 intercooler by precision power, stock valves, springs, buckets, fuel lines and fpr, no head porting at all.Blitz boost controller, devils own alcohol injection, 1000cc injector clinic injectors, walbro 450 lph fuel pump, 23 psi of boost in 56 % humidity and 91 degrees. Rough street tune by me , and 2 minutes of adjustments with Jason At AutoBanh Motorsports. Extra ac condensor for oil cooler.
If you had the audacity , to doubt my veracity, and even to insinuate, that I scrupulously prevaricate ,such an insignificant question. Then you must hallucinate before you comprehend.
haltechsupra is offline   Reply With Quote
Old 08-11-2018, 01:49 PM   #2
740atl
educator monkey
740atl's Avatar
More meaningful would be to share quarter mile slips.
Old 08-11-2018, 01:52 PM   #3
haltechsupra
For sure! One has to make power before the power is laid down. The most difficult part is making it all work. But we already have a east vs west thread on quarter mile times, sooo... Please share your dyno 740atl?
Old 08-11-2018, 01:58 PM   #4
740atl
educator monkey
740atl's Avatar
What’s your dyno sheet’s trap speed? (Quoting Sam’s t-shirt)
Dyno plots give an indication of power but trap speeds tell you what you have for real. What’s your trap speed?
Old 08-11-2018, 02:20 PM   #5
haltechsupra
I know you want to argue. I get it. This is just about dynos. If you dont have a dyno to share, please dont try to explian to all of us what you think is more important than title above . Smh.
Old 08-11-2018, 02:37 PM   #6
740atl
educator monkey
740atl's Avatar
I’m not trying to argue at all. I’m simply saying that staring at dyno numbers is like comparing sausages. Dyno numbers on the same car can vary even in the same day. Don’t get me wrong, they’re great tuning tools but that’s it. The real measure of power is making a trip 1320ft long.
https://www.google.com/amp/s/www.roa...-dyno-numbers/
If you want to just post pictures of dyno plots that’s fine I guess and I will depart henceforth.
Carry on.
Old 08-11-2018, 03:44 PM   #7
haltechsupra
Default Dyno not important , just sheets to look at?!
We all start with tools here sir. Thats how cars are built. Humor me and share your trap speed and et since you jumped right into opposition , not four minutes after I posted this. I don't mind. Actually , you bring up a great point, it would be really cool to see both. Anyone on here have a quarter mile runs, and a dyno run from around the same time? I know Linuxman51 does. That is really what tells the complete story. A dyno run not only shows power, but it shows torque, and what rpm all of it happens, along with other real world data. Not to mention you can set up the car for optimum power potential. A quarter mile trap speed and et tell the story of how good the power gets to the ground. ..I have been street tuning my car for a while. Its hella dangerous. Not very effective honestly. Alot more safe / time efficient, money efficient, to dyno tune, before you go to the track. It's the natural order of things. Some decide to go straight from the build to the track. For those that have already been to a dyno and sorted things out, the type of guys that just build and go to the track are a huge pain in the ass. They break everything, leak everything, and are a danger to everyone around them and generally the slowest. Thier lack of preparation shows how much they really care about what they are doing. The people that have dynoed , are ready to rip, they still break things, but keep in mind they have a bit more knowledge about almost all of it. They know thier a/f is right, and ignition timing potential is at its best! They know how much thier car makes and how fast it should be at the track, so now its time to tune suspension and brakes , right? Because they know where they should be- because dyno results!!! They know the engine will hold up when they mash the throttle... Time to figure out why it isn't making that et! When you dyno your car before taking it to a track you are much more ahead of the pack already . My 25 years of personal experience in drag racing, 1/8 and 1/4, wrenching and driving. Get the full story. Be ahead of the game at any opportunity. People have been wondering for years how fast my car is. They say, "Whats it make? "First question from everyone, other than "is that real?" Up until now I said" makes me happy.". Now I can say 404 at the tires on a bad day. The rest is up to driving ability , street prep and suspension drivetrain prep, and consistancy. Most people use a dyno to know potential of power then pull out ignition timing to get traction, essentially detuning the engine to suit the surface. That says little about the cability of power an engine can make. Throttle by wire is a easier way to control power delivery but has its caveats as well. I think its also important to remember that dyno sessons are test and tune for future track time. A durability test, before the durability test. Show your numbers! Share your experiences! Having said all the above, dont let anyone bs you that dyno numbers are useless. They obviously just dont know any better. It took me this long to dyno my car, because I knew it wasnt ready yet. Thats why I dont have a track time yet. The natural order of things..
Old 08-11-2018, 04:39 PM   #8
haltechsupra
Here we can see the pros "compareing sausages" and making it to now the third quickest import in the world ! Great job Krister Adeen! Volvo 16v+t + $$$$ =Big ass moose stomp! BTW number 4 is also a Volvo, and its a 8v! !!
Old 08-11-2018, 08:14 PM   #9
tryingbe
Boosting along.
tryingbe's Avatar
Is non Volvo engine welcome?
85 GLH 367whp
00 Insight mpg > yours.
Old 08-11-2018, 09:46 PM   #10
haltechsupra
Yes. As long as car is Volvo.
Old 08-12-2018, 12:44 AM   #11
tryingbe
Boosting along.
tryingbe's Avatar
My GLH have a Volvo fan and couple of Volvo silicone hoses, so close enough?
Old 08-14-2018, 08:38 AM   #12
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
Any data is better than no data, any day.
3076R with an ipd turbo cam
I'll have to dig up some more.
edit:
16v turbo (needs bigger turbo and e85)
video:
https://youtu.be/n0MQMdimY2A
Megasquirt Tuning!
Old 08-14-2018, 09:21 AM   #13
Marvelous3
Who engineered this?
Marvelous3's Avatar
What's the build sheet on that 245? Basic 16 valve plus t or he's got fancy pistons/rods?
Old 08-14-2018, 09:54 AM   #14
linuxman51
linuxman51's Avatar
fancy stuff, all the fancy stuff. it's a nice car, it just really needs a bigger turbo with a bigger hot side.
Old 08-14-2018, 09:40 AM   #15
Tfrasca
Tfrasca's Avatar
Nice 8 valve numbers. Big valves or a just stock head with IPD cam?
Old 08-14-2018, 09:55 AM   #16
linuxman51
linuxman51's Avatar
I would guess stock, but honestly I don't know.
Old 08-14-2018, 10:33 AM   #17
Eviltwin
1983 Volvo 245 with 2004 Vortec LSx engine with bolt-ons/HP Tuners
open diff 1 wheel peel along most of track on useless 14" wheels
best was 14.6 @ 99mph
1990 BMW Hartge H35
1983 Volvo 245 *now with LS power!*
Eviltwin is offline   Reply With Quote
Old 08-14-2018, 12:42 PM   #18
haltechsupra
s-10 with 1600 hp at last dyno 8v redblockhttps://m.youtube.com/watch?v=vUt4mHmjLxY
Old 08-14-2018, 12:35 PM   #19
haltechsupra
Bamse underpants 450 wheel on 8v https://m.youtube.com/watch?feature=...&v=8-XR6ZIeveY
Old 08-14-2018, 01:01 PM   #20
haltechsupra
Ig Magistern 8v- 746/799
Old 08-14-2018, 01:04 PM   #21
haltechsupra
who can forget..https://www.youtube.com/watch?v=1zyDgepdRDY&t=
Old 08-14-2018, 01:08 PM   #22
haltechsupra
The boss...
Linuxman51
https://youtu.be/g9NZZSaeGDc
https://youtu.be/TAOQbM8ptIM
Not sure what the latest dyno was, or the fastest time..
Old 08-14-2018, 03:21 PM   #23
linuxman51
linuxman51's Avatar
hah I remember that. hit it with the smack before the engine warmed up all the way and it pushed some coolant. that video oughta be floating around somewhere
back in the proefi days. what a miserable system.
