volvoracer82
- Mar 24, 2003
- Stock-Town
Gary, in your write up you said you added a tooth to your tone ring and it didn't throw off your speedo. I cant quite figure out how this is possible, as each slot registers as a fraction of a turn. I would imagine that it would change your speedo reading by a factor of (n+1)/n. On your tone ring that would not make much difference because it has a lot of teeth. I would imagine on the 12 tooth tone rings, it will read about 8% faster than it should be. Furthermore, that error will be propagated through an integral when the odometer integrates the speed signal into position.
How did you determine that it reads correctly?
Based on my understanding of how hall sensors signals are conditioned to determine speed, I believe you would have to have the same number of teeth as OEM. It might even be better to just leave a gap than to add another tooth, because it just knows n amount of impulses are in a rotation, and the diff spins fast enough the speedo probably wont notice the delayed impulse due to the gap.
they don't "count" the teeth, it's a frequency reading, the faster the pulse the sensor sees from the ring determines the speedo needle position.
