TeamTFR
- Mar 11, 2008
- Hagerstown, MD
My recently acquired +t 240 is running rich and won't idle on it's own until it's warmed up. According to the previous owner this started after installing a chipped ecu.
The car has a 3 inch amm, 440cc (greentop) injectors, and a 340 lph fuel pump. It was at 18 psi but an issue with the mbc now has it on just wastegate pressure (8 ish psi), which is where it will stay for right now.
Would it be possible to swap in the standard turbo ecu and ezk until I get the chipped ones figured out? It'd be great if it would run correctly while I fix the other issues with it.
